WE HAVE A SAMSUNG B1445 WASHING MACHINE. WE HAVE HAD IT OVER 18 MONTHS NOW WITH NO PROBLEMS.TYPICALLY ON CHRISTMAS DAY MY WIFE DECIDED TO PUT THE WASHING MACHINE ON.WHEN THE LOAD HAD FINISHED SHE ATTEMPTED TO OPEN THE DOOR AS SHE NORMALLY DOES AND IT WOULD NOT OPEN.SHE SAID SHE HEARD SOMETHIND DROP.I HAVE HAD A LOOK AT THE HANDLE AND IT DOES SEEM TO BE A BIT SLACK/LOOSE.I THINK THIS IS A MECHANICAL PROBLEM RATHER THAN A ELECTRIC ONE.PLEASE COULD YOU ADVISE ON HOW TO SOLVE THIS PROBLEM.THANKS TREVOR
  • 15,935 Answers
This advice is for front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Drain pump isn't working properly or mystery clog
I would replace the drain pump if you are sure there are no obstructions to the water flow.
May 19, 2017 | Washing Machines
Error code 3e Samsung washing machine b1445
Please check if there is power to the motor during the cycle or if the motor is warm. If so the capacitor to the motor can be faulty as it fails to start.
If there is no power to the motor then the control panel is faulty as the relay or drive has failed within.
Jul 04, 2012 | Washing Machines
Washing machine leaking
This is called the "drain hose" or "discharge hose" -- it connects to the outlet port on the water pump.
May 07, 2009 | GE WBSR3140DW Top Load Washer
Cycles continues all day
Whatever the prob is, my advice to you is to call Hotpoint service for attention.
If you do anything yourself, you will make your guarantee null and void.
As it is only 6 months old, it will not cost you anything to get it put right.
Or ring the Hotpoint help line for advice, you will find the number in your handbook.
Please rate my advice to you.
Thanks.
Apr 15, 2009 | Washing Machines
Bearings on Hotpoint
the unit is only 18 nmohths old then what you need to do is contact the manufacture and explain to them what is happening and if they are having simuary isssues with that particular moidel number. Possibly they are and you may be able to have it repaired on their dime! 18 months is not that long for a washer to start having these problems if you have not abused the unit by overloading the washer or over filling it with soap. Good Luck
Jan 05, 2009 | Hoover AAA160 Front Load Washer
How do i get into the machine to change the door to tub seal
dan some of the washer are easy to change some are not need model no
Feb 24, 2008 | Hotpoint WMA58 Front Load Washer
Whirlpool Washing Machine is going to explode(shakes and shimmies)
put your level on the machine Adjust the legs so when you push down on any corner there is no rocking - easy
Nov 07, 2007 | Whirlpool LSQ9600L Top Load Washer
Washing Machines Logo
280 people viewed this question
Top Washing Machines Experts
