Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Not Filling with water
My Hotpoint WD63 is having troubles! I recently cleaned out the filters and now it will not fill with water. I can hear the water trickling into the soap dispenser and it does try and fill, but, the majority of the water ends up down the drain. I have tried it on spin only and I've boil washed but both have had no effect! Help, I have 2 children and a dirty husband!!!
  • Deby Yates Apr 17, 2007
    You are possibly my new best friend! Thank you very much for that. It worked a treat.
  • 247 Answers
Suggest you have a look at where your drain hose is going. The highest point in the hose needs to be higher than the "minimum drainage hose height" line marked on the back of the machine. Washing machines don't have valves to keep the water in - they simply rely on the pump pushing water over the hump in the hose when you want to empty them, and the water not being able to climb the hill on its own the rest of the time. A.
Posted on Apr 17, 2007
Dispenser draw filling with water, i have been told there is no filter i can clean!!? The part of the draw where you put your fabric conditioner in.
You have been ill advised, there is a filter that you can clean.
Remove rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove top cover., check the hose from dispenser to drum is not blocked with powder..
If the dispenser drawer still fills up, then it is possible that the condenser is blocked with fluff.
This a major job to put right, you would be well advised to call an engineer if this is the case.
Hope this helps.
Dec 13, 2009 | Hotpoint Aquarius WD63 Front Load...
My service washing machine keeps filling up with water even on spin cycle
Your Fill valve Solenoid has failed.
Some machines have an all-in-one type fill valve
(hot and cold on the same valve - but different solenoids)
some have seperate bodies for the hot and cold.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 10, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WT540 1400 spin Washing Machine stuck on cycle
Could be a sticking water level switch, which controls the water level, or a blockage in the hose to the switch, or a trapped or split hose to the switch. the hose in question is about 6mm in diam,and goes from the sump hose to the pressure switch,if u remove the hose from the preesure switch chamber, check for a blockage there, and blow down the hose to see if it is clear, u should hear the switch click if it is clear, if no click and hose is clear, then I wud say the switch is faulty.
Plz rate my comments.
Thanks
Dec 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Machine stuck on Cycle and wont cancel
Chances are it is the filter that is blocked, you must remove it completely to check,
Pull ******* the filter to remove it,at worst you may have to break the filter to get it out, it would just mean replacing it with a new one.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
WD63 washer dryer
your inlet valve is not opening properly and needs to be replaced. this is quite a common fault with inlet valves
Mar 08, 2008 | Hotpoint Aquarius WD63 Front Load...
My Hotpoint Aqaurius WD62 is filling but wont drain or spin
try replacing the interlock first then check the the continuity in the interlock lead
Mar 06, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius wf740
Sounds like water pressure could be low or inlet pipe is kinked.
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Don't forget to rate!
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Problem with our washer/dryer
sump/filter is blocked instead of flushing on dry cycle is filling as not pumping well. ring hotpoint to reorder pts cheaper then anyone
Jan 06, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius deluxe1000 WM22 Its not working........
Surely by now you've checked to see if your water inlet into the machine is good, ie turn on the taps. The machine wont start if there is no water coming in. Try the spin only function, it works??
Sep 17, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint washer dryer
daidan, If you unplug the washer and it still fills you have a bad inlet water valve. If you post the complete model number we would be able to help you better...Catriver...post back
Aug 21, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
46 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
