Question about Dryers
Hotpoint CTD00 Door Catch Replacement
My CTD00 tumble drier needs a new door catch. How do I get the old one off?
  • 3,463 Answers
If yuo are referring to the catch on the door, then undo all the scews holding the 2 halves of the door together, and prize apart, fit new door catch.
If you mean the door lock, then you will have to remove the top cover and right hand side panel to access the door lock.
Hope this helps.
Plz rate this solution.
Thanks.
Posted on Dec 26, 2008
  • djcairns9 Nov 21, 2010
    There is no need to take any panels off . The mechanism has a retaining flange at the top. Simply remove the screw, slide the mechanism down and swing it out from the top. Replacement is the reverse.
Hotpoint condenser dryer door catch
http://www.repairclinic.com/vwo6/Shop-For-Parts/a8/Dryer-Parts
Oct 20, 2014 | Hotpoint Tumble Dryer Door Latch & Catch...
How to get the lid of Hotpoint tumble drier Model PCF780
Usually the lids are released by a putty knife in the corners, releasing a catch.
Dec 01, 2013 | YouTube Videos
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Jan 12, 2013 | Washing Machines
Door catch has broken on the tumble drier
you will need to order a new on, do not know what type but here are two websites, Good Luck Tim:
eBay:
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=dryer+door+switch&_sacat=See-All-Categories
repairclinic:
http://www.repairclinic.com/Dryer-Switch-Parts
May 22, 2011 | Dryers
My door for a hotpoint ctd40 tumble drier wont stay closed. The spring latch seems ok but not holding dooe closed. Any ideas since it dont say anything in my manual about it and its 2 yrs old. cheers andy
Hi andy.
the fault is likely to be in the roller catch mechanism. Hotpoint have modified these. Part Number is C00257618.
It includes both door latch and catch.
If you have problems obtaining one please email me on: aardvark.repairs@btinternet.com or call me on 01733 307019
Regards
aardvark repairs
Nov 18, 2009 | Hotpoint Dryers
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
Tumble dryer hotpoint ctd00
Unscrew all screws that hold the 2 halves of the door together, then with a screwdriver or similar, prize apart the 2 halves of the door, be careful the door glass does not fall onto the floor.
Fit new parts, reassemble door, and hey presto!!!
Dec 16, 2008 | Hotpoint NWXR473EV Dryer
Hotpoint bwm12 intergrated washer drier
BEST YOU GET A TECHNICIAN ITS E VERY HARD JOB TO OPEN A STUCK DOOR CATCH.GOODLUCK.MOHAMED.AND ITS NOT CAUSED BY COIN DAMAGE ITS JUST WEAR AND TEAR ITS A ELECTRICAL COMPONENT THAT CAN MALFUNCTION AT ANY TIME
May 31, 2008 | Hotpoint BWM12 Front Load Washer
How to reassemble door catch of indesit tumble drier
Very difficult to explain with out pictures, the pin should go through the spring it really is a matter of fiddling until you get it right or go back to where you bought it from and ask them how it goes.
Nov 30, 2007 | Dryers
Dryers Logo
759 people viewed this question
Top Dryers Experts
Marvin
Marvin
