Question about Sharp R-9H66 Microwave Oven
Microwave Will not Run
I have a Microwave Oven ( Model R-510HKF). In order for My Microwave to work I would have to lift and hold the door. How do I ajust or realign the door so I will no longer need to hold the door the keep it running. HELP
  • Sharp Master
  • 9,100 Answers
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
You will need to remove the outer cover, then shut the door and then you can adjust the door latches.
Posted on Dec 26, 2008
Model: FMV156DCC Actual microwave cooking cease to work, yet the control panel does. lifted door, closed and worked temporarily. Appears the door sensor, switched, hinges may be source. How can I...
That would be a problem with the secondary interlock (bottom door switch) or its mount.
See our door switch help file: http://031d26d.namesecurehost.com/mwd/doorsw.txt
We have the service manual and have uploaded it to our site here to help you.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 06, 2011 | Frigidaire FMV156DC Microwave Oven
I have a microwave oven over the range ,brand Frigidaire , model CFMV156DC purchased in 2006 and stopped working , even the lights on the front panel are on when I press the start button it happened just a...
I have exactly the same problem. Everything works perfectly even fan, except microwave table won't turn. I just found out what's the problem... The door for some reason is sitting too low now, even though it is not obvious at all. It looks leveled with everything else, but it's not. Set your Microwave to let's say 30 seconds and turn it on. It will not do anything... but you just gently lift the door (while closed of course) few millimeters and your Microwave will start running like new. There is something wrong with those latches on the door, not touching the microswitches inside the Microwave. Doors must be properly closed in order for Microwave to work. This is due to poorly design. I yet have to figure out how to fix that permanently.
Apr 15, 2011 | Frigidaire FMV156DC Microwave Oven
I have a MMV4205BAB mounted microwave oven. One of the small latches that hold the door shut is broken so the oven won't run. Is there a way to replace just the latch or do I have to replace the entire...
Unfortunately on this model you would have to replace the whole door.
You can find handy exploded views and order parts by model number here.
Dec 16, 2010 | Maytag MMV4205 Microwave Oven
Microwave won't heat or turn off unless I press the door
That would be a loose door switch mount, a failing door switch, or both.
See our file on door switch help here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
May 31, 2010 | GE Microwave Ovens
I have a JVM 1650BB008 GE microwave oven. I am trying to replace the outer door frame and handle, which are broken. I have removed the door and have pried off the choke cover. Now I need to remove the old...
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You have to remove the door handle screw(s) and the door handle, then look for subtle clips that may be holding the outer door screen in place.
Some models have two screws holding the door handle, but some have only one. In that case, remove the screw, then you either lift or rotate the handle to free it.
If you still need help, please write me at prototech@usa.net for the service manual link (no charge, no obligation).
Sep 27, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
Microwave wont work
The microswitch operated by the door catch will need to be repositioned by a serviceman. Do not remove the microwave cover yourself as they are potentially lethal even when not plugged in to a power source because of a large capacitor holding high voltage charge.
Sep 21, 2009 | Frigidaire FMV156DC Microwave Oven
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Microwave will not run unless i jiggle the handle.
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here onFixYa:.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
Dec 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Clarification on microwave
That would be a bad primary interlock switch (bottom door switch) or its mount is loose or broken.
See this link: http://www.microwavedisplay.com/doorsw.txt
Dec 02, 2008 | Microwave Ovens
Microwave lights up, timer works, not carousel or cooking
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Otherwise, the best place to order Sharp parts is Tritronics.
You can also call them at 866-779-5835.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Microwave Ovens Logo
129 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
