Question about Dell Inspiron 6000 Notebook
Dell Inspiron 6000 not picking up wireless signal
Two laptops, Dell Inspiron 6000 and Inspiron E1405.
The E1405 picks up the signal in our house when the 6000 does not.
Details: 6000 has Intel PRO/wireless 2200BG card
E1405 has Dell Wireless 1500 DRAFT 802.11n WLAN card
Router: ipTIME G504 in "office" (sandwich panel construction--Styrofoam between sheet metal sheathing)
Laptops in "home"--steel container next door.
Is the Intel card inherently weaker than the Dell 1500? This problem seems to be worse than usual (there are days when I have no problems with the 6000). Right now it's bad and the weather is clear but below freezing. Other times when I have problems are during stormy weather--that makes sense to me.
Any ideas how to improve reception. Is it time to get a new wireless card?
  • Ben Torrey Dec 27, 2008
    Thanks. I'll take a look at these. Picking up the signal fine today...
  • Ben Torrey Jan 01, 2009
    Thank you. I will look into this as it will provide more flexibility regardless of what I do with the card. I am thinking about changing it as well.
    New Friend:
    Problem Solver:
  • 10 Answers
It is never a right time to get a new wireless card, unless you have absolute compatibility problems - which is reducing by-the-year, or you want further reach and faster connection .
in your case it may be solved tweaking firmwares on both ipTime G504 and/or Dell inspiron 6000 with Intel PRO/wireless 2200BG card : meaning even back-tracing to an earlier firmware if you have the latest on both .
Posted on Mar 29, 2015
    Problem Solver:
  • 10 Answers
There are lots of problems of using wireless LANs in metal buildings, especially if you are trying to go outside the building and into another building. What I have had to do where I work is put an external antenna on the wireless router and use that to transmit the signal beyond the metal shell of the building.
If that still does not yeild satisfactory results, you can set up another wireless router in the "home" location with an external antenna to act as a recieving point for the other router in the office ... essentially this is setting up a site to site network. With both routers working together you should resolve the wireless drop out issue.
Bestbuy also sells a Wireless Booster, this works the same way as I explained with using two routers however if you go that route be sure you have the option to either add an antenna or you can place it near a window (glass cuts down on your signal than steel).
If this fails look at replacing the wireless card; this setup will still provide benefical even if you need to replace the card as it will provide stronger signals in stormy weather as well.
Posted on Dec 31, 2008
Dell inspiron e1405 cant acquire a network address?
Call Dell customer support phone number 1-800-204-4427 to get online help for technical problems related to Dell computer, laptop, printer, scanner and tablet Dell Laptop Support Phone Number 1 800 204 4427 Tech Help
May 17, 2017 | Dell Inspiron E1405 Notebook
My dell inspiron e1505 tells me that it cannot pick up wireless networks. My computer was picking up wireless earlier today in front half of house. we extended the signal via ethernet cord and plugged in...
Depends apon the signal and how you have the computer settings some of the older computers have programs where differant places will not be picked up !
Did you check your internet options in your control panel?
1.Check your internet options and see if your lan settings have a check mark in the top box for lan atuomatic detect settings click ok then your internet should pick up ..... if you are still haveing prombelms please let me know ... Lala linda
has a check mark on the top box so there is a
Dec 24, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 6000 cant tell thats a blank dvd r is in the drive
did you try a + Dvd?Can you format the disk or add data to it ?
Oct 04, 2009 | Dell INSPIRON 6000 CENTRINO...
Dell inspiron 6000 connects to the wireless modem but does not keep the connection
Check the connection signal strength, if the signal is low move the wireless unit to a better height to improve signal strength
Sep 04, 2009 | Dell Inspiron 6000 Notebook
Will Dell Inspiron laptops pick up 802.11 wireless network?
I'd get the N-wireless card. It makes your signal much stronger, you pick up more signals, and you have less interruption. You won't get to see the full benefits without an N wireless router, but you will still notice an increase with a G router. I have an N wireless USB adapter hooked up to my desktop right now and I get 1-2 extra bars than I do with my laptop in the same spot (which has a G wireless card).
Aug 28, 2009 | Computers & Internet
Dell Inspiron 6000 PC Notebook, No Wifi Radio Signal
Open Intel Proset Wireless or Dell wireless utility from start>all programs. Make sure the the checkbox for 'enable radio' is checked.
Jan 01, 2009 | Dell Inspiron 6000 Notebook
Inspiron 6000 has trouble picking up wireless signal
Some wireless cards are better than others at picking up weaker signals.
The problem with any wireless transmissions is that radio signals cannot pass through metallic surfaces.
You should position your wireless router away from metallic surfaces/walls and position your laptop so it can receive the radio signals without it passing through any metallic walls. If possible place the wireless router higher than at desk level.
Dec 26, 2008 | Dell Inspiron 6000 Notebook
Computer internet problems
You can or cannot pick up wireless? Are you trying to use your nieghbors wireless from your house?
Jul 09, 2008 | Dell Inspiron 2200 PC Notebook
Wireless router
well..the wireless will pick up any signal..if you want one inside your place, you'll need a signal converter(wireless router) and a cable or dsl(phone com) internet service providor.
May 28, 2008 | Dell Inspiron 1501 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
1,019 people viewed this question
Clive
Clive
Alun Cox
