Question about Kogi L7CH Monitor
Monitor doesn't work
I have a Kogi 19" LCD monitor and compaq pc. had power outage 10 times in one day... came home -- monitor black.. power light didn't go on (at any color). (pc works fine) thought i blew the monitor.. took it to best buy (with the power cord)-- they plugged it into their pc (with their cord to connect monitor to pc) and it worked fine.. ok -- then thought it could be videocard... hooked up another monitor to pc -- worked fine.. so i figured videocard is fine... thought it couldn't be anything else except the cord that connects the monitor to the pc... took that to best buy -- they plugged one of their monitors to one of their pc's and it worked fine... i'm stumped? someone told me possibly the drivers were lost during the storm... if so, where do i find the drivers and how do i install them? any help would be GREATLY appreciated. Note: connections were checked to make sure they were tight and tested all electrical plugs -- they were working fine... sr
  • sewut Mar 15, 2008
    I have an L7YH and I have a similar problem. When we are expecting an electrical storm we shut down and unplug our computers. The monitor won't come back on. My husband usually can get it going by fooling around with it, unplugging and plugging back in, turning on and off etc. and gets it going. This time it won't work.
When you got the pc, you should have been given a starter pack with some CD-ROM's in the pack, one of them should be the drives for the monitor, you might need to use anothermonitor to see the instructions, but the basic graphics card should power the monitor enough to set things up, until then you won't be able to adjust the settings.
Posted on Apr 17, 2007
SOURCE:
Screen is black when computer is turned on. Tthe monitor power button blinks, but when you push the button, the light does not stop blinking and the screen stays black.. The monitor was working and last...
Try a different video card or disconnect the one you have in your PC and use the VGA monitor connection on the motherboard. If it works your video card is gone.
Dec 22, 2017 | Envision 19" Widescreen Flat Panel LCD...
Kogi L9CH monitor - black screen
return for a replacement, the screen is broken
Sep 13, 2009 | Kogi L9CH 19" Flat Panel LCD Monitor
When I turn my monitor on a "Going to Sleep" message is displayed on a black screen and then the screen goes all black. We had a power outage acouple of nights ago and the pc was on. Since then our power...
It will be video cable or related.
Responding to prior post,
Fuses have nothing to do with the video proper.
If you have a message on the screen, which says the monitor is basically working or saying the fuses and inverter is working.
That message appears with lack of video, so it can be the cable itself, possibly the video card on the computer.
Dec 20, 2008 | HP Compaq 1501 15" LCD Monitor
X2GEN MONITOR LIGHT ON AND CLICKING
Hi...there,
Well, it is seems your monitor backlight inverter got burnt... need to replaced a new one or repaired it.
Dec 01, 2008 | X2Gen MG19MY 19" LCD Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
My KOGI L7VH 19 in. monitor stays black. The green light no longer turns on. Any suggestions?
Could the power cable be loose at the back/bottom of the monitor? I'm assuming that you've checked the connection at the wall or surge supressor. And some monitor power cables have a converter "brick" in the middle of the cable - and the cable from the wall may be detachable from the brick. If your monitor power cable is like this, check the connection on the "brick" as well.
Feb 28, 2008 | Computers & Internet
Kogi L4AX 14" LCD Monitor.
jim
my supply has the following specs.
LIEN CHANG
BSA-35-115
AC input- 110-240v 1A  47-63Hz
DC output 10-17v  3.5A
Nom. V 12v
Nom current 2.9A
output power 35A max.
With this you can likely find a universal "brick" that covers your needs
Jay
Oct 14, 2007 | Kogi l4ax 14.1" Flat Panel LCD Monitor
Problems After Power Outage
Sounds like the power outage damaged the video interface could be damaged. You might have had a spike that effected the red input of the monitor. You can try to order a video interface, or like I suggest to others, look for the same monitor but broken on ebay and swap out the interface board. Chances are this will fix your problem. Good luck
Oct 02, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
Kogi L7CH Monitor Logo
108 people viewed this question
Top Kogi Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
