Whirlpool LSQ9500LQ0 will not drain water
I have Whirlpool LSQ9500LQ0 washing machine, it will not drain the water. I have already changed the timer, problem is when its done watching and its time to drain the water it doesn't drain. The sound of drain starting comes for 1-2 seconds then stops. Looks like a water pump issue but i am unable to access water pump cannot open the back cover. I don't see any screws. Any help on opening the back cover would be great or even a service manual.
Thanks in advance.
  • atif03 Dec 26, 2008
    watching = washing***
    Novelist:
  • 161 Answers
Access to the inside on this washer will require taking off the whole cabinet.
1. Remove two screws on the back side and on each end of the control panel.
2. The whole control panel will then pull forward then flip it back out of your way.
3. There are a group of wires coming from the control panel going down to a single plug, unplug them from the main cabinet.
4. Remove the two large brass colored clips on each side.
5. You can now remove the whole cabinet.
The water pump is in front and secured only by two clips top and bottom.
Posted on Dec 26, 2008
Spare part for chinese made whirlpool washing machine
what cycle are you using?there are a couple of things that cause the timer to stop,eg- water not heating - not draining etc. can you try a cold cycle if there is one on your machine. was the water in the machine getting hot?sorry to ask you these questions but you might not need a timer hopefully. have you tried the whirlpool website? please reply 4 more help.
May 24, 2010 | Whirlpool LHW0050PQ Front Load Washer
Kenmore topload washing machine that wont switch to drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
Washing machine fills, but will not agitate, drain or spin
Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
Dec 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool washer model #LSQ8520JQ1 won't spin or drain
there is a possibilty the drain pump maybe locked up by a small foreign object such as a small nail tooth pick drill bit or even a coin check that.if that does not solve them problem then the timer or control board may need to be replaced
Sep 17, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirpool Washer LSQ9500LQ0 Won't Spin or Drain
Your belt assessment sounds correct on the dryer problem.
If you can, restore the lid switch connections, and operate the switch during what should be spin. You should be able to hear a relay or solenoid clicking off and on with the switch.
Aug 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
It fills with water, washes, then makes a buzzing sound.
This is a failed timer mechanism. replacing this failed mech will fix your issue.
Jun 19, 2009 | Whirlpool Washing Machines
Whirlpool Washer Won't Drain
Did you replace the timer motor? The little motor attached to the timer that moves it thru the cycles. Also, I would check to see if the water level switch might be stopping it after the wash/rinse cycle. I've attached a URL that will show you the various components. If you need more help, feel free to post.
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Washing-Machine-Parts/Whirlpool-Parts-LLC7244BZ0.cfm
Nov 08, 2008 | Washing Machines
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Washing Machines Logo
    258 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
