I have a pioneer vsx-1016txv home stereo, i also have a hdtv, and a playstation 3 and xbox 360 (both im using hdmi cables for. i had them running straight to the tv before, and i was just using optical cable for the sound. What i want to do is put both the hdmi cables into the pioneer streo, and use a third hdmi as the out line to the tv. when i did this i at one point had picture but i could never get sound. i was told that by installing everything the way i want to i would get MUCH better sound up to 7.1, but it's becoming such a huge headache. If someone can walk me through what i am doing wrong and how i can fix it, i would be soooo grateful.
SOURCE: No sound from HDMI to PS3
go under system setting-->select sound settings-->select audio output settings -->hit x on hdmi-->hit x on automatic-->hit x to enter. This solved the issue for us :)
Posted on Dec 31, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: can't get sound through my hdmi
Try the easisest route first - unplug and replug HDMI cable into same port or the other hdmi port on the TV. Also, make sure the Monster cable isn't HDMI 1.3 - I'm not sure the HDMI ports on this tv are fully compat with 1.3.
If that fails, go to www.usasupport.philips.com, enter your model number, click on the verison of your model ending in /37, and click on "Software & Drivers"; click on the link that says "Firmware Upgrade - Software" - read the specs and see if it says anything about audio loss on HDMI - many Philips have issues with the HDMI ports - they are not broken, but just need a software fix. Instructions are on the same page - make sure you only transfer the .upg file, not the entire zip file to a portable memory stick.
Here are the notes I see:
BX23U-1.5.0.0_03531
Following problems are solved :
• Availability cablecard channel map.
• Improved info in the service menu.
• Improved picture quality and stability on HDMI.
• Installation of channels.
BX23U-1.4.0.0_03081
Following problem is solved :
• Issue related to intermittent video loss is solved.
Posted on Jun 09, 2008
  • 3 Answers
SOURCE: TV sound not playing through home cinema
When you say both cables, i presume you mean the HDMI. If so, yes, both need to be used. The HDMI is for the Video to the TV in full HD (which you will want because you tv supports full 1080P and the HT player upscales to 1080P) and also for the Anynet functions to and from the TV to the HT.
The Optical transfers only Audio to the HT from what evr device you have connected. In your case the TV.
Without going into to much detail. i use a switch so i can connect several devices to the HT giving me the best sound possible.
Hope this helps!
Cheers,
Posted on Jun 16, 2008
  • 53 Answers
SOURCE: am setting up a bose GSX 3-2-1 home theater
simplist solution, if the TV has an audio output just run that to the Bose system.
what type of TV are you connecting to?
Is the cable box an HD or digital box?
Posted on Jun 24, 2008
SOURCE: XBOX 360 Elite HDMI SOUND PROBLEM
First you have to activate the HDMI audio option in your Sony suround system options so as to activate it. Please try this and then tell me what happens.
Posted on Dec 18, 2008
NO AUDIO
If it is the radio you are trying to get make sure you have an antenna that is strong enough and can receive the signal. With a digital tuner it requires a strong enough signal to capture any channels.
Sep 30, 2014 | Pioneer Vsx-520-k 5.1 Channel 3d Ready...
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
Hi I just bought a pioneer vsx-42 cable box and was wondering how to hook my Xbox 360 up through there so I can play on the tv, I have an hdmi cord And will be playing on a Samsung smart tv
Hook your X Box into the Receiver HDMI input with your HDMI cable and another HDMI cable from the HDMI out on the receiver to the HDMI input on your TV.
Aug 02, 2012 | Audio Players & Recorders
Pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Sep 08, 2009 | Pioneer VSX-818V-K Receiver
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Mar 13, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
No sound from speakers after connecting to pioneer a/v vsx81
I had the same problem and resolved it last night. You'll also need to connect an audio cable (EVENTHOUGH YOU SHOULDN'T HAVE TO - to bad pioneer didn't fully implement the HDMI standard in this receiver) solution. I suggest using an Optical cable. This really annoyed me...see the manual on P.17 section #3.
Dec 28, 2008 | Pioneer VSX-818V-K Receiver
Component to HDMI
why dont u connect the xbox directly to the tv via HDMI cable? the output will be fantastic.The component cables just cannot give a better resolution than HDMI.
As for connections,i am not in favour of component and HDMI together.
May 18, 2008 | Pioneer VSX-92TXH Receiver
Hdmi cable connected nothing happens
Are you making sure to change the input settings on your TV/Home Theater System? You may have to instruct the receiving device to use the HDMI input.
Also, are you have to make sure that the settings in the XBOX are set to use the HDMI output instead.
I honestly don't own an X360 so I couldn't tell you for sure. This is a general principle one must keep in mind when using electronics in general, really.
But I did take some time to track down an instructional overview of using an HDMI connection. It's actually on MS's XBOX site. Perhaps this will help you?
Click HERE to see this site.
Also there has been the occasional report of the HDMI cable coming with the XBOX 360 Elite being nonfunctional. You may consider testing with a different HDMI cable.
Remember to make sure you are checking the OUTPUT on the X360...and the INPUTS on your HDTV. Or your Home Theater system...if that's where you're connecting it. Remember that you may need a second HDMI cable to go FROM your home theater system to your HDTV if that is the case.
Let us know what happens!
Cyryl
Dec 07, 2007 | Microsoft Xbox 360 Console
62 people viewed this question
 Grubhead
Grubhead
