Question about Sony Blu-ray/dvd player BDP-S1
Sony blu ray player with distortion and haze on dvds played
I have just bought the sony blu ray dvd player 350 and have the older sony bravia lcd rear projection tv. whenever i try to play dvds there is double distortion on the letter images in the main menu. like ghosting around the words. when i play the blu ray dvd there is a yellow haze around the people etc and the picture is distorted. Please help.
  • 1153 Answers
SOURCE: Video inputs
How is this distorted? Does DVD only have Video/Audio jacks or do it have RF output connection and if so have you tried going inset that way? How does it looks with only Dvd Logo on? If Logo is ok then I would look for some other problem.
Posted on Sep 11, 2007
Ecollier2012
  • 3459 Answers
SOURCE: color distortion and arched picture
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 22, 2009
SOURCE: I bought a new DVD and it won't play in my sony blu-ray.
I had a similar problem and I solved my issue by upgrading the firmware to the latest version. Full instructions can be found on the Sony site.
Posted on Apr 11, 2009
  • 36 Answers
SOURCE: Our Sony Blu-Ray BDP-S300 will play older Blu Ray
Try to update the firmware on the player by going to this website http://www.blu-ray.com/firmware/firmware.php?id=10 the newest version is 5.20 fixes alot of problems including playback issues with some BD movies and safe the file into a flash drive and plug it in on the back USB port, go to menu/firmware update run the update.
Posted on Jan 12, 2010
  • 4 Answers
SOURCE: DVD playback distorted in Samsung BD-P1600 Blu-ray Player
I called Samsung with the same issue. After verifying the latest firmware was installed, they suggested I send the unit in for service. I expect it back sometime this week, and DVD playback will be the first thing I test.
Posted on Apr 14, 2010
I am having a sony blue ray dvd home thatre bdv e280 bought from switzerland and I came to India which I wan't to play some dvd's bought from India which is is blocked of region code. How to unlock the...
Works with most Sony Players
Step 1
Unplug the power cord of the Sony Blu-ray player. Plug the power cord back in. Turn on the Sony Blu-ray player. Turn on the TV to which the Sony Blu-ray player is attached. Wait for the "No Disc" text to appear on the front of the Sony's LCD display and on the TV's screen.
Step 2
Press the "Eject" button on the remote control. Wait for the disc tray to eject itself from the front of the Sony Blu-ray player.
Step 3
Press the "Disc Info" button on the remote control. Look for a number to appear on one of the upper corners of the screen of the TV.
Step 4
Press the "Disc Info" button repeatedly until the number "9" appears on the TV's screen. This number indicates that the Sony Blu-ray player is now set for "multi-region" and will play any Blu-ray disc that is commercially made.
Step 5
Turn the Sony Blu-ray player off using the remote control. Turn the Sony Blu-ray player back on using the remote control. Press the "Eject" button on the remote control to close the disc tray. Turn the Sony Blu-ray player off using the remote control.
Dec 28, 2017 | Televison & Video
Thompson DVD DTH271E refuses to play HD DVDs but fine normal DVDS, cant seem to get any help via Thompson, & think may need "firmfare" update? New machine but in Spain & language...
Hello there.
Push "Play/Pause" and "DVD Rec" on the dvd recorder a few seconds to see the service menu. There you can find your firmware version.
Post back the version for us.
Hope this helps.
May 06, 2008 | Televison & Video
I have a three year old SONY Blu Ray BDP-s350. I bought a new blu-ray dvd. When I try to play it, just initial picture with title is looping. No menu appears. My old dvds play well. I checked this new dvd...
I'm sorry for the difficulties you're experiencing in playing the new Blu-ray disc in the Sony Blu-ray Player. In most cases, the issue might be with the Java content on the new Blu-ray discs is making these issues. The Blu-ray technology is developing everyday and adding more and more features to the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the latest firmware update available from the manufacturer (who ever it is). Going ahead with the first step, please install the latest firmware update available for the Blu-ray Player.
Please click the following link to get the latest firmware update available for your Blu-ray Player:
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=6385&os_id=99&mdl=BDPS350
I'm sure, installing the firmware update should resolve the issue. If you need any further clarification/assistance, please let me know.
Thanks for understanding.
Jun 11, 2011 | Sony BDP-S350 Blu-Ray Player
Replaced blu-ray laser on ps3 games play but not dvds
thats becouse it a BLU-RAY it is diffrent i figured out the hrd way 2 :P
Dec 15, 2009 | Sony Playstation 3 (PS3) Console
When I put a DVD in it says ''loading,' but never plays It continues to display, ''loading''
See if you can use other DVDs and see if the problem still exists. If it does, use a lens cleaner and have the lens cleaned. See if it helps.
Dec 11, 2009 | Sony DVP-NS300 DVD Player
Apr 07, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Cant play region 1 dvd's on my sony bdp-s350 player
check these guys out; they offer a mod kit to unlock regions 1-6 for the BD 350
www.multiregionupgrades.com
Located in the UK but world-wide shipping available
Jan 24, 2009 | Sony BDP-S350 Blu-Ray Player
I think a connectivity problem with tv and dvd player
dvd playes or hd dvd players will not play blu ray diskd you must have a blue ray player to play blu ray disks
Dec 02, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BluRaywon't play back disk
That is one of the problem with manufacturers that don't clearly explain the consumers that most of the blue ray dvd player is designed to play blue ray dvds &regular dvds,but it wasn't never designed to back any DVD-R or DVD-RW.
Sorry,there is no way around it,because Sony enjoyed being exclusive in many things.
solutiondoct
Nov 13, 2008 | Sony BDP-S300 Blu-Ray Disc Player
SONY BDP-S300 unlock region code
DVD PLAYER SAYS CANNOT PLAY THIS DISC
Apr 22, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Sony Blu-ray/dvd player BDP-S1 Logo
69 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
