Onkyo CR-505Dab - no sound!
My Hifi turns on and all the controls work apart from one. The volume won't go up / down. When it worked the remote moved the sound dial - now it doesn't. My dad (who is a boffin) checked the insides and all parts have power as far as he can tell. I would like to get a circuit diagram so we can try to figure out which chip / component is unwell. I haven't blown the amp (honest) it just stopped working one day. It did used to go straight to clock setting when powered up but I just put in a CD and it generally worked. On some occasions I had to turn it off and on with the CD button pressed down. I should have contacted richer sounds when this first happened - doh. It's out of warranty (I got it for my 40th and I'm 43 and a bit). Any ideas would be much appreciated. BTW the beastie is at my dad's and he won't be back until the 1st Jan.
  • jimothy2008 Dec 28, 2008
    Thanks for the reply wierdal. I've tried the knob on the hifi and it doesn't work so its not the remote. I emailed onkyo to try to get a bit of help - maybe a nice tech guy will be full of christmas cheer (maybe not and I'll have to get my hand in my pocket). Happy New Year - Jim
    I'm new to online shopping - where should I look? or should I stick with Richer Sounds in town.
  • 24 Answers
The problem could be with the remote itself. The volume buttons on remotes usually get the most use and therefore wear out. Try using a universal remote programmed for your Onkyo and see if that works.
Posted on Dec 28, 2008
Volume control not working properly on my remote control, all other buttons are fine, do I need a new remote or canI get it repaired if so where? Onkyo HT550 unit
Did u tried disassemble remote control and clean PCB with clean cloth? Also u can take rubber part of remote and wash it carefully in soaped water . While u have it disassembled check for bad solder connections at IR LED on remote controller . Regards .
Oct 01, 2012 | Onkyo SKS-HT500 System
My Onkyo TX-SR806 remote has recently lost its mind. The On/Standby switch no longer turns receiver on or off; must do it manually on the receiver. The Volume control is now reversed: when you press the UP...
Hello, the most used buttons can wear out over time. On/standby and volume are the ones that are used most often. I suggest purchasing a new remote. It is available at shoponkyo.com. Thank you, Onkyo USA
Jul 08, 2017 | Onkyo TX-SR806 Receiver
While wathching TV, the typical volume level
Cleared all AV settings and reprogrammed.
Jan 30, 2010 | Onkyo TX-SR703 Receiver
The Vol button on my Onkyo RC-588M remote doesn't work
It probably can be fixed. Dirt and such gets on the contact pads...take it apart by carefully unscrewing it and remove the top half with the buttons facing you. You will likely see that the buttons are made of molded sheet of silicone, lift that off. Beneath where the mold was for the volume control you will see the actual buttons that control the volume, inspect it to see if it simply got pressed down too far and try to operate it that way and clean anything that needs it while you have it open. If it works without the silicone button cover panel on it, then you can take a small peice of paper wad and tuck it into the mold for the volume button so that when you press on it, it always makes contact.
Dec 14, 2009 | Onkyo TX-SR702 Receiver
Volume control
Oh, sorry for the clarification post! I must have hit the wrong button!
Oct 11, 2009 | Sony STR-DA2ES 6.1 Channels Receiver
The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
May 10, 2009 | Sansui HDLCD3210 32 in. LCD TV
Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Dec 26, 2008 | Onkyo TX-SR573 Receiver
Onkyo htr 330 universal remote codes
I have the HT-R570 Receiver and here's what I ended up doing to use the Verizon FIOS DVR remote to turn the receiver on and off with volume control. Know that Onkyo uses 2 codes 1 for on and 1 for off so use the AUX for ON with Volume control and the DVD for OFF. (I rarely use my DVD and when I do I use the DVD remote that came with the DVD)
Use the AUX and codes 1347 or 1558 to turn the receiver on with volume control. Press AUX and OK together and release. Enter the code. it should now turn the receiver ON with volume control.
To use the DVD button to turn the Receiver OFF, you have to use the search method to capture the code. Tried every code I could find on the internet and their is no universal code for OFF and ON.) With the receiver ON, push down DVD and OK together and release (should get 2 flashes of all component keys) enter 922 and with remote pointing at the receiver press the >" (forward/pause button) then press and release the >> (fast forward button) until the receiver turns off. If you go too fast and go past it, quickly turn receiver back on (within 20 seconds) and press-release the <<(backwards button) slowly until it turns off again. Then press the OK button to store the OFF code in the DVD function button. Any questions...E-Mail me at MrBlueOcean@verizon.net Lots of Luck!
Nov 30, 2008 | Onkyo HTR500 Receiver
112 people viewed this question
 Grubhead
Grubhead
