SOURCE: Casablanca fan is not working!!
The controler board has gone out due to either a power surge, overheating or too much wattage in the lamps. There are two types of of controlers and both are subject to this kind of failure. Here's a troubleshooting link
http://www.lampdepot.com/service/intellitouch.htm
SOURCE: Casablance Ceiling Fan Trouble
itake it the light is still working if it is check the wireing from the pull switch to motor unless you have a neon live tester or volt meter thers nothing else you can check
SOURCE: Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
SOURCE: When the Casablanca fan remote
the button may get stuck or the sensor may be off.... also it could be that the setting is backwards on the fan to start on the fastest and end on the slowest
SOURCE: Casablanca fan only runs at highest speed
When I turn on any of the fan speeds fan does not come on. When I remove the blades and turn on the ceiling fan on and give it a push the fan stays running. What could it be?
