Question about Whirlpool GD5SHAX Side by Side Refrigerator
Tripping when turned on after moving house
Can you give any clues as to what might be wrong with the fridge. Is was running fine up until the move. Now it trips every time we try to turn it on.
  • 700 Answers
It sounds like the outlet that you are trying to plug the unit into is somewhere conected to a GFIC plug that may be weak. either that or when you were moving the unit a wire may have been pinched underneith the refrigerrator causing it to short out. I woudl reccommend call for a service person to come out and check both of these solutions out for you. Have a Happy New Year and I hope that you enjoy your new place.
Posted on Jan 05, 2009
Please help my side by side ge fridge freezer is tripping our power I have had it for 2 year we moved houses I left it unplugged for three days in our garage then moved it into the house and plugged it in...
Check to make sure that in the process of moving a "hot" wire under the refrigerator did not come loose and now is contacting a metal part of unit.
U have a classic short circuit which accounts for the breaker popping immediately. It is not a short in the compressor because that would have popped the self resetting clixon and not the house breaker.
May 01, 2017 | Refrigerators
With the unit unplugged remove the machine compartment and visually inspect for and burnt marks or frayed wiring. if non is seen, remove the wiring connectors from one component at a time and re test by plugging the unit back in. This will help you isolate the issue hopefully.
The machine compartment is on the back and the power cord is attached behind it. It is usually connected with 1/4" screws so a socket or nut driver will help you gain access.
Apr 22, 2014 | Refrigerators
Rcd tripping
Either the start relay in the compressor is grounding electrically or the defrost heater is (most likely start relay). To replace this yourself is difficult as it requires technical knowledge. If you are located in California, bay area I could help you personally
Apr 21, 2014 | GE Profile PSW26P Stainless Steel Side by...
Fridge freezer tripping rcd
Ensure it fully dries out before trying it again. Water in the electrics will throw your trip instantly. If it's dry now, and you are having the same problem. check the electrics for a short circuit or earth fault. Usually a compressor earth fault is to blame.
Apr 21, 2014 | Refrigerators
Upright freezer trips circuit after moving across room
If compressor is hot, it could be an issue with the starting components. Let it cool down for about an hour an it is room temperature to the touch. If the breaker trips when the compressor attempts to start, I would look at the start components. It may be just a case of unusual timing that they went bad at this time. Make sure there is nothing else on the circuit you have it plugged into. Could be an overloading issue of the circuit.
Aug 04, 2017 | Refrigerators
Fridge keeps tripping the circuit breaker
Your fridge should draw no more than 5amp. Presuming your breaker is at least 15amp there's a problem. Move to a different circuit first. If the condition persists check the start relay on the compressor. I have a suspicion the circuit may have another item you are not aware of.
Mar 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Front leveling wheel broken-Can't move Fridge
go to good hardware shop of fridge retailer and there you will get small trolleys that you put the fridge on and then it rolls to where you want it
they come in a pack of 2 and fit under existing feet and rollers
Jun 06, 2017 | Refrigerators
Kenmore side by side not cooling after a move
go to the back of the fridge see if it has a white relay on the compressor that's the piece that plugs onto the compressor if it does un plug the unit take it off and shake it if it rattles and little black stuff falls out of it replace it with a three in one relay from an appliance repair parts store just follow the instructions on the part its easy don't worry about water in the ice maker it will fill when it starts cooling if it doesn't have the relay try turning it off for 24 hours to give the oil time to run back down to the compressor and advise me further
Mar 30, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerator trips GFI outlet
unlikely to be the defrost timer. more likely to be the defrost element. try disconnecting the element and see if it trips then. could be of course a wiring fault - frayed wires etc
Jun 18, 2007 | Viking VCSB423 Side by Side Refrigerator
Whirlpool GD5SHAX Side by Side Refrigerator Logo
42 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
