Sunbeam Oster Fast Feed Hair Trimmer Logo
Posted on Sep 14, 2012
Clippers wont come on
Barely used fast feed clippers wouldn't come on for some reason....no power!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 14, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
177
Points
14
Mine has a reset button on the plug
Oster fast feeds snagging clients. how do I remedy the problem?
Hello, Albert -
Clarification: You are asking about an Oster brand Fast-Feed hair clipper. Apparently when you use it on hair cutting clients, the clipper "clips" their skin.
If I am correct in my guess, then . . .
I have found some reviews of the hair clippers which mention the clipper guard combs, which come with the clippers , which may cause problems.
These are links to 2 reviews:
https://www.myhairclippers.com/oster-fast-feed-adjustable-pivot-motor-clipper-review/
and
https://choicebarber.com/oster-fast-feed-review-2017/
The second review includes a recommendation to purchase other clipper guards to use instead of those which come with the hair clipper.
Some of the "clipping" problems may be user error (you), too. You may wish to find and watch some instructive videos. To find such videos, use your favorite search engine (Google, Bing, Yahoo Search, etc.) and the following search phrase, using quotation marks as shown:
"Oster fast feed" demonstration video
Best wishes.
Very little power at wire
try to use bare .032 wire and co2 shielded gas, If the equipment does not have a gas solenoid you may have to wire a solenoid to the trigger mechanism to get the gas to flow while the wire is feeding. The bare wire usually copper coated burns much hotter than the flux core when there is a gas shield. Also a .032 bare wire with a gas shield burns a a lower amp range and will get better penetration.
You may have to experiment with the feed rate and gas flow to get the correct setting, but the bare wire has a lot less resistance to current flow than the flux core and will burn a lot hotter when you use a gas shield.
At 115 vac there is not a lot of amperage left to create an arc and run the feeder and the rest of the unit , and the flux core wire takes a lot of amperage to burn both the wire and the flux . .
Oster blade no. 913-50
http://www.ebay.com/itm/Oster-Blade-Set-913-50-Fits-Fast-Feed-17-tooth-76913-506-New-/130803957423
Andis master clippers lose power
Oil the blades and then adjust them. You will need to add oil while grooming from time to time and then clean & oil them again when finished.
How do I reduce my clipper's rattling noise and still be able to cut properly?
The power screw is the correct way to adjust the problem you describe. If you have attempted to adjust it as instructed in the user manual and have not had satisfactory results, there may be a problem with the clippers.
Most Wahl clippers have a 1 year or longer warranty. You can call Wahl for warranty service at 1-800-334-4627
1helpful
2answers
WASHER TURNS ON FOR COUPLE OF SECONDS THEN TRIPS BREAKER.PROBLEM WITH MOTOR ???.
Is it tripping the breaker on your home's electrical panel? If this is the case, you need to know what that breaker is also feeding, how much amperage it can handle, and what the load demand is. Your washer needs 1700W which is around 15 Amps. If you're on a 15 Amp breaker that is already supplying power to something else, such as incandescent light bulbs, then you're going to trip the breaker each and every time. You'll want to plug it into a 20 Amp circuit that's being used by little to no other electrical devices. A quick alternative is to unplug or power off all other devices before using the washer... or plug it into the same outlet that you use your blow dryer.
I replaced the blades on my Oster fast feed clippers but now the I can not get the blades to tighten''
You can call into 800-830-3678 and they will walk you through how to take care of this issue.
2answers
NEED PARTS FOR OLDER OSTER CLIPPERS
I found this site useful and complete with schematics and parts lists.
http://www.clipperrepair.com/inventory.htm
2helpful
3answers
Top Sunbeam Health & Beauty Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sunbeam Health and Beauty Expert? Answer questions, earn points and help others
