Question about Philips 27RF70S 27" TV
Philips 27RF70S125 I have a 2002 Philips 27RF70S125 and it keeps shutting off by itself. I will turn on again in 1-10 minutes but shuts back off again after a while. I looked at the CRT circuit board and do not see any resistor with R3340. Any other ideas? Thanks
  • Russ42 Feb 10, 2008
    have a 2002 Philips 27RF70S125 and it keeps shutting off by itself. I will turn on again in 1-10 minutes but shuts back off again after a while...
    Dealt with this problem for a year, then replaced Small Signal Board ($100 new online) on professional's advice. Solved the intermittent shutdown problem, but now have some pinchushioning I'm trying to solve....
  • 56 Answers
Check for a pot on the chasic board or check yoke if crt.
The problem is most likely you have a bad capisitor or cold solder joint in the primary circuit.
It will look like a half moon shap are dull looking, but look for swollen capacitors first and then cold solder joint second.
a capacitors stores electrons and release them as it need power to the circuit and if it's damage (leaking or swollen it wont ) do so.
Are the regulator break down under a load.
A shorted horizontal output transistor will power up and shutdown with in a few seconds or blow the fuse.
Just a short summary of what's what
Posted on Sep 03, 2010
    Genius:
  • 1,074 Answers
Your problem is intermittent in the pwer or related circuits have a tech check your tv good luck
Posted on Apr 18, 2007
SOURCE:
Hotpoint Condenser Dryer Shuts Off After 5 Minutes
what is your model number is then we can get started then okay
Feb 01, 2013 | Dryers
TV keeps shutting off
Its the power pack located inside the TV, it needs replaced. contact manufacturer for parts or service.
http://www.support.philips.com/support/html/index_global.html
Nov 14, 2007 | Philips 50PF9431D Television
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
Tv shuts it self off after one minute i turn it back on it shuts itself again ater 30 sec
Hi, That sounds like a blown capacitor on the motherboard in the TV, if you take it to a local television repair shop they'll be able to fix it for you.
Aug 28, 2011 | Philips 42PFL5332D 42 in. LCD Television
My almost new Keurig (which I LOVE) keeps shutting down
I am having the same problem and will report back here if I find an answer. If I keep turning mine back on, wait for it to go off by itself. Turn it back on again...and again. Eventually I can get a cup of coffee. But my one-minute coffee cup usually takes 15 or 20 minutes.
Mine was a gift, so I'll probably just see if I can swap it out.
Cuz that's some good coffee.
Dec 13, 2009 | Keurig B100 Coffee Maker
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
TV Turning on and off by its self
You have problems with a condenser that allow the power supply to maintan an acceptable level of voltage in order to keep the TV on. take to a tech to be fixed. unfortunatelly, this problem needs a tech to take measures in the circuitry to find the component that causes the problem.
Nov 06, 2008 | Philips Magnavox TS3260C 32" TV
Philips 42PF9630A
Go to philips website and download the latest firmware and install via usb. The fw corrects random power on and offs. If that doesnt fix your problem, the tv is going into error protection mode do to a voltage problem detected by the power supply.
That will be hard to diagnose as everything will test ok as it works before shutting off. The best way is to run the set and use a temp gun to find out whats overheating and go from there.
Aug 04, 2008 | Philips 42PF9630A 42 in. Plasma Television
Keeps turning off-Philips 50PF9431D
63 inch samsung plasma turn off then back on buy its self
Philips 27RF70S 27" TV Logo
173 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
