Question about Toshiba Qosmio G25-AV513 Notebook
I am getting an amber light instead of green light on two identically configured Gateway 500C CTO Desktops. The Power supply is a "160W Pwr Sply - P/N 6500582" and I am running Windows XP Pro, SP2. I have exchanged the cords between each other and still same response. Every once in a while, when I plug one in and it works fine. I originally thought it was the video card but I was able to update it and all the drivers, to no avail. I don?t want to purchase every new component as yet. How can I test weather or not I need which new component?
  • Diane McSwine
    Diane McSwine Dec 26, 2008
    I also own a Laptop, but I am asking now about my Gateway 500C CTO Desktop. Almost all of your solutions are for Laptops. Do you have any for DESKTOPS? I did not notice that they were using "My Products" in the submission of this question...
Gateway 500C: Dead. green PSU lite doesn't lite when pressing test switch
Obviously your Power Supply Unit is dead. You just have to replace it.
Feb 17, 2013 | Gateway Computers & Internet
Computer will not start up?
Sounds like an electrical issue make sure you have power to your computer then test your PSU or just replace your PSU
Jul 29, 2010 | Gateway /ton 160W Power Supply (6500582)...
Sleeps and won't wake up. unblug pwr supply won't shut down properly. when pwr supply is plugged back in, monitor like comes on blue then amber like in sleep mode. Nothing shows on monitor. ctrl /alt/del...
Hello
Thank you for using FixYa for your problem
Needs a techie toolkit disc to run HDD regeneration scan then try the repair mode in your install disc, (2nd repair mode)
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Feb 21, 2010 | Gateway GT5625E Refurbished Intel Desktop...
Emachine t3418 no video pwr sply goes and that's it no boot
If you have a desktop system and it is in a no power state, I'd replace the power supply (Or if available test with a known good) before I'd replace teh motherboard, Power supplies normally fail 1st
Jan 11, 2010 | E-Machines eMachines Desktop PC
Dell 4500 won't turn on,power light amber/green
Is the light more amber or more green? If you push the button and it goes amber, then you probably have a bad power supply. Try getting another power supply to test. If that doesn't solve the problem, then you probably have a bad motherboard.
Oct 22, 2009 | Dell Dimension 4500 PC Desktop
Amber light instead of green light
160w is a very marginal power supply. Have you added any hardware recently? Anything you add draws more power. You can test the memory. Take one stick at a time out and see if there is any change. Better yet try some different memory. You might disconnect everything that is not essential for the computer to operate (CDROM, Floppy drive, sound card, network card etc. Try to boot with just the hard drive,memory, graphics card and motherboard plugged in. That is the minimum to run the unit. Your new graphics card is probably drawing more wattage also. If this 160w supply has not quit yet, it will, probably sooner than later so get a new one.
Dec 26, 2008 | Computers & Internet
500c CTO will not boot
check the RAM, processor etc, disconnect all the hard drives and check the on/off controllers on the board
regards
Nov 21, 2008 | Gateway (4000274) Motherboard
Blinking Green power light
Unplug the power cable and press and hold the power button for several seconds to discharge the system. Then allow several minutes before reconnecting the power cable. If the problem still persists, it may be a failed power supply.
Nov 20, 2008 | Computers & Internet
Power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Sep 21, 2008 | Boston Acoustics MicroMedia Computer...
Toshiba Qosmio G25-AV513 Notebook Logo
60 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
