Question about Fisher and Paykel E522BLX Bottom Freezer Refrigerator
Frigde not cooling bottom freezer all frozen up on back plate
Fridge Upside down freezer on bottom
Not cooling bottom of firidge all frozen up
  • Fisher and P... Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 29, 2010
Why does thick ice form regularly on bottom of my samsung frost free upside down fridge .
The drain line in the bottom of the freezer is frozen over. Remove the back cover boil some water and slowly pour it down the drain to clear it.
Mar 02, 2014 | Refrigerators
I have a Dometic fridge model number RM2612 in a camper that i just purchased used and the fridge isn't cooling. The freezer section seems to be okay. The metal plate in the freezer gets cold but
Make sure it is level, has proper airflow out through top vent. Also check baffle, or stack where flame sits under and blow it out good with compressed air to make sure it's clean. If you smell a hint or strong smell of ammonia, shut it off, it has a leak in cooling unit. If all ok in that area, shut it off, disconnect and plug propane line, disconnect power and remove the fridge. Turn the fridge upside down for a day or 2, then re-install and let it sit 24 hrs before turning it back on. Quite often that will take care of any blockage in flow of cooling liquid, and get things back to normal if cooling unit is still good.
May 22, 2012 | Dometic RM2620 Refrigerator
Freezer works but frigde isn't working
once ice forms on the freezer coils there is no air flow. I had the same thing. I suspect your defrost cycle is compromised. Could be the bimetal switch, defrost timer or defrost heater element.
Nov 25, 2017 | Pds GE Profile Bottom-Freezer Drawer...
Fridge not getting cold
Your evaporator is iced over, this could be due to a couple different components
1. defrost timer is bad,
2. thermostat is stuck and continually cooling
3. fan that blows over evaporator is not working
You will need to check each component to know for sure.
But to save your food from going bad in the refer, remove the food from the freezer, remove 4 screws in the back of the freezer (from inside the freezer) and you will see a frozen aluminum block which is your evaporator. Defrost it thoroughly by turning off the freezer and blowing the evaporator with a hair dryer.
This will allow you refer to start working again for a few days, until you can figure out what the problem is and get it repaired.
May 25, 2009 | Bosch Refrigerators
Freezer drips water into frigde filling up ottom tray
Hello, If it is a top mount freezer then there is a drain that runs from the freezer to the drain pan that gets gummed up sometimes and if that happens then the water has no place to go but the fridge. Look all the way in the back of the fridge and you'll see a yellowish colored tube. You can just pop that out and take it to the sink and clean it out.. Hope this helps
Feb 18, 2009 | Kenmore 62232 / 62234 / 62239 Bottom...
FREEZER ACCUMULATED WATER FROZEN NOW DRIPPING THRU TO FRIDGE
The drain in the freezer is blocked. Just below the cooling coils is a drain, when the defrost heater cycles on the water is suppose to go down the drain and into a pan under the ref.
Feb 13, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
GE Side By Side top portion of fridge and freezer not cooling
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Liebherr frost free fridge/freezer
Try these solutions in these order:
1. Switch off the fridge and leave the door open overnight. Switch it back on in the morning.
Explanation: The sensor inside the fridge gets frozen and cannot control the temperature properly.
2. Switch off the fridge. Unplug it. At the back of the fridge (behind the unit, not inside) there is a large grid. Clean it with a hoover thoroughly. Open the fridge. Dry the back of the fridge if wet (inside the fridge). If frosted wait for it to defrost and then dry it. Plug in the fridge. Switch the fridge back on. This one worked for me.
Explanation: The dust in the grid deprives the fridge from cooling down and the unit can't control the temperature in the fridge section.
3. Switch off the fridge. -Unplug it. Empty it. Turn it upside down. Plug it in. Switch it on for 24 hours. Switch it off. Unplug, return to normal and switch on.
Explanation: This has to do with the pressure of the gas inside the compressor. I have not tried it but this advice as given to me by a qualified electrician when I commented the (in)famous F2 problem in Liebherr fridge/freezers.
Hope it helps. Regards. Albert
Sep 07, 2008 | Liebherr KGBN 3846 Premium BioFresh Bottom...
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Fisher and Paykel E522BLX Bottom Freezer Refrigerator Logo
300 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
