I have a constant 70ma drain from thebatteries when turned off. I insert the plug into the external 5vdc to disconect the batteries from the camera and this splves the problem.
I now find that the time and date have to be entered or just press OK for the camera to operate. Is there a second internal battery for the clock alone. Thank you Richard
I suggest using XD cards. Depending on the age of your camera there may be a factory fix available to improve this issue, you'll have to contact the Fuji repair center.
The manual states there is some small constant drain by design but 70mA seems high. There is no internal battery to retain the date, but with 2+ hours of the batteries inserted (or power supply attached) it is supposed to retain data/time for up to 24 hours (internal capacitance holds it). If you have a CF draining that will probably use all of the stored energy up though causing the date/time to be lost. Try it with the CF pulled out if that is the memory you are using.
Plugging in the adapter will cause a power-interrupt according to the manual. Be sure the camera is off when plugging or removign the supply.
FWIW I have switched to Duracell pre-charged NiMH hybrid cells in my S7000 and the "shelf-life" is much better than typical NiMH, took hundreds of test shots and views over a period of a week and there was still plenty of life in the cells. (They are rebranded Sanyo "enerloop" cells, google them up for more info).
looking for a place to get the door to the battery compartment repaired. it will not latch. probably...
(More)
looking for a place to get the door to the battery compartment repaired. it will not latch. probably needs a new door put on.
My camera will not focus on auto when zooming. Also the shaken hand will only turn off if the flash...
(More)
My camera will not focus on auto when zooming. Also the shaken hand will only turn off if the flash is on
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
