Question about Radio Communications
Motorola Talkabout FV700 not transmitting nor receiving
A set of identical two-way radios (walkie-talkies), set to the same channels and interference eliminator codes (IEC), cannot communicate with each other. I have read the manual, gone through all the settings countless times, and these radios simply do not communicate. Both receive on the weather channel, but they do not respond to neither the PTT (push to talk) buttons, nor the ''transmit call tone'' buttons. A friend of mine has a more recent model, and when transmitting from his radio, on the same channel/IEC, only *one* of my two radios received -- but even that radio still could *not* transmit and be heard/received. Have you had similar no-communication issues? Please advise. Thank you.
  • abatz Dec 27, 2008
    Thanks for your reply, but I've tried that already, and the radios are still not working. Oddly, they are brand new -- I opened the package two days ago. I've tried both radios on:
    • channel 1, interference eliminator 0 (zero)
    • channel 1, IE 1
    • channel x, IE 0 (zero)
    • channel x, IE y
    Also, in all cases, I've tried QT on and off, and iVox off.
  • Anonymous Mar 16, 2014
    xtni set to channel 6. I could transmit but could not receive.
Had the same problem...took out nimh...replaced with triple A...works great!!
Thank you!!
Posted on Oct 13, 2011
  • Radio Commun... Master
  • 1,654 Answers
To troubleshoot: Unlock your keypad lock, then reprogram your radios to the following settings. (Check function after each change)
1) Shut off the Interference Eliminator (set to zero).
2) Turn off the Qt filter.
3) Vox setting to off.
By shutting off all the "bells and whistles" of the radio, you will take it back to being just simply on a frequency. If your radios do not communicate with one another then, or with your friend's radios, you have radio which is failing to operate.
If the radios do work in this simple mode. One by one add the special features back until you discover the culprit.
Posted on Dec 26, 2008
  • eradiostore
    eradiostore Dec 27, 2008
    Sounds like you have at least one defective radio. I suggest returning them for an exchange or refund. If this is not possible, contact Motorola using the number in your user manual, and they will help you with replacements. Have your serial numbers handy when calling.
  • viking946 May 16, 2011
    i had two fv700 do the same thing. i replaced the nimh battery packs in both radios and replaced with triple a batteries and both started working properly
I have a set of Motorola T5720 walkie Talkies. I cannot determine if one of them is not receiving or the other is not transmitting.
One radio works properly, the other can receive. I assume there are more than two by the question. Check and then rotate you batteries, mark on the working unit battery that it is GOOD. Transmit takes a great deal more power than receiving. Batteries, even un-used only last 18-24 months typically. If no joy, then check your programming but I think that is unlikely. It really sounds like a power/battery issue.
Aug 28, 2016 | Motorola Talkabout T5720 (7 Channels)...
Just bought motorola 4 Talkabout MH230R they are working fine except for one which is only receiving the voice and not transmitting anything. I tried Ringing other Walkie Talkie and thats not working and...
is it water proof? did you dip it in water?... if you did that's why the mic isn't working, the call and mic isnt working
make sure the channel is on the right channel for the walkie talkie
Mar 14, 2014 | Motorola MH230R Two Way Radio
One of my walkie talkie's transmits but doesn't receive...WHY?
Your speaker is blown. The microphone still works but you can't hear any audio. Take it back if there not to old.
Nov 01, 2012 | Motorola TalkAbout T6530R (14 Channels)...
I have a pair of talkabouts fv700's they will receive but I cannot transmit
Check the programming of your frequency, interference eliminator code and Qt filter (if any). Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/FV700%20FINAL%20-%20%20All%20Rights%20Reserved%20and%20call%20center%20email%2004-24-07.pdf
For basic operation turn off any special features, and set the code to zero (off) and the Qt filter (if any) to zero (off). This would allow you to test the radios in a simple mode, with just the frequency number needing to match between the two radios.
Best regards.
Oct 17, 2010 | Motorola Walkie Talkie 2-Way Radio
Talkabout T4500 (7 Channels) 2-Way Radio: A Motorola T4500 (small) walkie talkie makes a sta...
One of my T4500 radios does the same thing. When I transmit or the radio is receiving, the interval is interrupted and it takes another 12 seconds to make a popping noise. Weird! I tried to post this as a comment but FixYa kicks out an error so apologies for posting it as a solution!
May 17, 2010 | Motorola Talkabout T4500 (7 Channels)...
My motorola xtr446 has an icon stuck on it and no one else can hear me when i speak out? how do i get rid of the icon? the icon is a mini walkie talkie
The mini walkie talkie emblem has a variety of meanings. If the emblem has parenthese around it your PTT (push to talk) button is depressed, stuck or partially depressed. If the emblem does not have parenthese your radio is in receive mode, awaiting a call.
It is possible you do not have your radio programmed identical to the other radio(s). Your frequency and interference code eliminator must be identical to those used in the other radios. Here is a link to the manual where you can check this http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=103 Look around page 7 for instructions.
Also, if you find your radios are programmed identically, the other problem might be bad or low batteries, as it takes more energy to transmit than to receive.
Best regards.
May 15, 2010 | Motorola Walkie Talkie 2-Way Radio
Can Receive but not Transmit
1) Double check your interference code eliminator and the Qt filter. Make certain they are all set identical.
2) If you are still having trouble, shut off the Qt filter.
3) Then if you still have trouble shut off the code. (Off is sometimes "zero" or "n" for no.)
4) If the above steps do not help you have either a defective radio, or a bad battery. Switch the batteries out of the working units to the non-working and see if the problem switches to the other units. If so, replace the battery packs. (Note: it takes more battery power to transmit, so the problem would first show up in the transmit area.)
Best regards.
Nov 10, 2009 | Motorola Walkie Talkies 2-Way Radio
Won't transmit
First I would check the interference code on both radios to see if it is set the same. It is possible you have one set to zero and the other set to another number. This would cause the problem you describe. The interference eliminator is designed to block out transmissions from radios whose settings do not match it.
If all your settings are identical, and you have only 2 radios, it is not possible to tell which one has the problem. You either have one with no transmit or one with no receive. The only way to tell which you have is to get a 3rd radio involved, set to the same settings.
Sep 06, 2008 | Motorola FV200AA GMRS/FRS 2-Way Radio...
Radio Communications Logo
4,302 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
