SOURCE: the picture become upside down
You need to change it to front/ceiling in the menu function of the projector.
SOURCE: picture become reversed
In the menu functions there is a place you can change the way the image is projected on the screen. If the projector is mounted in the ceiling you need to change it to front/ceiling, but if you scroll through the options you should be able to find the one that will work for you.
SOURCE: lcd projector projects images upside down???
if you go through the projectors setup menu you will find the option to invert / flip and rotate image adjust as required
REgards Al "alastech"
SOURCE: picture upside down after installing on ceiling
Try Uninstall the projector and install again.
luciana44
SOURCE: my projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Press the Menu button.
Select the Advanced menu. You see the features and their settings on the right side:
Press Enter and use the directional buttons and the Enter button to set the following option:
Projection
Front: Projector is in front of the screen
Front/Ceiling: Projector is in front of the screen, mounted upside-down from the ceiling
Rear: Projector is behind the screen
Rear/Ceiling: Projector is behind the screen, mounted upside-down from the ceiling
