I need a timer motor for the silver series rainsoft water filters. The part number is 19032, can't seem to find.
  • 15,935 Answers
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
How do I operate Culligan 01011289?
That is a serial number NOT the model #. We need the model number to help you.
Example: Culligan Gold series, Silver, Medallist, Mark 100, etc.
Here is a link to help you find your model:
http://eculligan.com/service-manuals/manuals.php
RJH2O
Aug 06, 2014 | Culligan 34" Whole House Water Filter...
I need replacement timer motors for T 103 Intermatic timers.Where can I order them from?
1) Copy fo0llowing links:
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html#clock
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#Hz
2) The suffix, -1 and -3 are not important.
3) WG733 is 208-277 Volt clock motor, normally found on sprinkler timer or T1900 series. WG430 is 120Volt clock motor normally found on T1400 series.
4) T103 timer is stock 120Volts, but can be changed into different voltage timer by changing clock motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 21, 2013 | Intermatic Hardware & Accessories
One of the gears on my intermatic timer broke. I've been trying to find a supplier to purchase the gear from,but have been unable to.It's a Rainsoft water softener.I contacted the local Rainsoft dealer and...
You might try contacting Intermatic directly:
http://www.intermatic.com/customer%20service.aspx
As a serviceman myself, I can tell you that selling parts for stuff ends up with serviceman spending time on the phone helping to repair the thing for free. Not just that, but servicemen have to salvage parts and know which parts to salvage, and then inventory the parts, and remember where all that dang stuff is ... and with overhead, and cost of labor and trucks, the part costs the same as a service call. So hire the guy or buy a new one.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 11, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Don't know what is it used for,and how it operates?I don't have any instructions for it.
You posted under T101 timer.
Most box timers have model number and instructions pasted on inside of door.
Instructions can seems a foreign language sometimes.
If your timer is different than T101, then add a comment with timer number.
I have extensive files on timers.
Box timers are generally used for heavy amperage loads like outdoor lights, swimming pool pumps, water heaters, parking lot lights and lighted outdoor signs.
They are surface mounted near breaker box, or in attic or basement, or garage.
Box timers are used in schools to ring bells, and inside factories to run processes and fans.
Some are complicated electronic devices used to control machines with one second precision.
Mechanical box timers are noisy when turning on-off, so are generally not installed in living area of house.
T101 timer is least complicated of any timer.
It is used for ordinary household 120V circuit.
Timer has 120Volt clock motor, and controls 120Volt circuit.
For example 120Volt water heater, or 120V grow lights, or aquarium, or any application up to 2 horsepower, for example timer can be located inside garage to control outdoor lights.
T101R is raintight outdoor box, with rubber gasket on door that seals tight when closed.
Raintight boxes are installed outdoors to operate 120Volt spas and pool pumps.
When box timer is rated for indoor, there is no rubber gasket on door, and that box is called NEMA 1 enclosure.
My local Lowes sells T101 T103 T104 > and each is for slightly different purpose and each wires differently.
Link below shows wiring and manuals for T100 series timers.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Here's how T100 series timer works:
Lift and rotate yellow dial until current time lines up with silver pointer.
Clock motor rotates dial as time passes.
Clock motors are accurate for years, but current time has to be reset after power outage.
ON-OFF trippers are placed on outer edge of dial.
Trippers push a lever, and lever turns circuit on-and-off.
ON tripper pushes lever one direction.
OFF tripper pushes lever opposite direction.
Each time lever is pushed, manual-override lever clicks back and forth with audible sound.
Dec 01, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
Need manual to set timer
You posted under T-100 series outdoor timer
If you have different timer, add a comment with timer model number located inside cover.
T-104, T-103, T-101 timer manuals show on following page:
If your timer has R suffix, like T-101R, that means box is Raintight for outdoor use.
T-101R and T-101 mechanisms are identical except for box. T-101 box is indoor use.
Click model number and drop-down menu reveals link to manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
If you need simple wiring diagrams, and explanation for each T-104, T-103, T-101 timer:
Here's how to set Intermatic T100 series timers:
Silver pointer is stationary at 6 o'clock position.
Put ON-OFF trippers on dial at times you want ON OFF functions.
Minimum on-off is 1 hour because of tripper width.
If timer is not working, add a comment and we'll troubleshoot.
These timers have replacement trippers and clock motors at Grainger
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How timer works:
Clock motor, located on back of mechanism, rotates yellow dial.
Trippers on dial push lever that turns power ON and OFF.
Off tripper pushes lever one direction.
ON tripper pushes lever opposite direction.
When lever is pushed, manual override lever clicks back and forth with audible click sound.
Nov 29, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I have a Kenmore Refrigerator: Model Number 106.50254001, Purchased 1-24-2001. It has a water and ice dispenser on the front. I purchased a Rainsoft Water Softening system, with a Reverse Osmosis System...
The water pump probaply is switch on by a flow switch. So the solution is to install a pressure tank after pump so to have stable pressure and not a pulsing one.
Sep 27, 2010 | Kenmore Refrigerators
Replacement timer motor needed
If you have Intermatic timer, then clock motors are available for most hard-wire box-type timers. Most pool and spa timer modules are available or have same/similar replacements. If you have plug-in timer, including power pack or portable outdoor timer or indoor plug-in or in-wall timer, then no clock motors are available.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
If you have Tork timer, then clock motor is available for 1100 series.
http://waterheatertimer.org/Tork-timers-and-manuals.html
If you have Paragon timer, clock motors will be hard to find
http://waterheatertimer.org/Paragon-timers-and-manuals.html
If you have other brands of timer, then clock motors are not available except Deihl, DIGI and Grasslin timer modules, but post brand and model number of timer so I can search my files.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Sep 11, 2010 | Intermatic WH40 - Water Heater Time Switch...
My Culligan Silver Series broke elecctronic panel
Unplug it for 2 minutes and plug back in, this may reset it if it is not burned out.
RJ
Feb 06, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Kenmore 90 series doesn't spin out all the water
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Kenmore 22422 Top Load Washer
Water in water out ??
rainsoft.com is the site. water usaully enters rear, depending on model
Feb 26, 2009 | Plumbing
Washing Machines Logo
408 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
