Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
Ive tried to set up my bluetooth but it aska for passcode; Inever tried it before so ican't go on anymore. How can you clear the old one and reset it
  • 231 Answers
Try 0000
It's the standard passcode for Motorola Bluetooth devices
Posted on Dec 26, 2008
How to reset passcode on bluetooth
Most of the time there is no easy way to set a passcode on Bluetooth headset. Try passwords 1234 and 0000 - most of the time those are the ones set by default.
May 06, 2016 | Radio Communications
I am wanting to change my motarola H12 to my new phone and i don't know my passcode for this device how to i find it is it on my old phone?
The factory set passcode is 0000 (zero's not O's). If you changed this then you will need to reset your bluetooth to go back to the 0000
Apr 20, 2011 | Motorola Mobility Motopure H12 Bluetooth...
I purchased the Jabra BT2035 Bluetooth Headset from a long time.... The first time I tried to connect, it connected easily with the passkey or passcode - 0000. One time, I accidentally deleted the...
you need to intorduce again the jabra blutooth to your device. deleting jabra from the list make it forget the connection.
set your jabra to find mode by pressing the poer button for more than 5 seconds wait to blink, and find it using your device. it will again ask for a passcode and it will connect afterward.
Nov 10, 2010 | Jabra BT2050 Bluetooth Headset
Bluetooth passcode
To find a bluetooth passcode click tis link bp
to change passcode click tis cp
to reset rp
  • Step 1 Look on the back of your headset or speakerphone for the Bluetooth passcode for the device. Typically the pairing code for headsets is printed on a sticker that is then placed on the underside of the accessory.
  • Step 2 Go into the Bluetooth menu on your cell phone to find the passcode for your cellphone. The Bluetooth menu for your phone is typically located under the "Settings" menu. In the Settings menu there should be an option to "Get code" or something comparable, which would allow you to find the code for your phone.
  • Step 3 Go into the Settings menu for your computer to find its Bluetooth passcode. Some laptops will randomly generate a new Bluetooth passcode for you each time you want to pair them with a new device. In that case the menu setting you're looking for is something like "Generate new pairing code."
  • Step 4 Look in the instruction book for your Bluetooth accessory if you cannot find the passcode attached to the device or in its menu. Many manufacturers will print the passcode for devices in their instruction book. If you still can't find the passcode, try using all zeros.
  • Read more: How to Find a Bluetooth Passcode | eHow.com http://www.ehow.com/how_5169210_bluetooth-passcode.html#ixzz0vcmCZd00
    Aug 04, 2010 | Apple iPhone Smartphone
    Ive lost my instructions for my headset device i need to know how to turn my phone to headset pairing mode
    Hello my friend,do these steps
    Pairing with another Bluetooth device
    By pairing your KU990 and another device,
    you can set up a passcode protected
    connection. This means your pairing is
    more secure.
    1 Check your Bluetooth is On and Visible.
    You can change your visibility in the
    Settings menu.
    2 Touch Paired Devices then New.
    3 Your KU990 will search for devices.
    When the search is completed Refresh
    and Add will appear on screen.
    4 Choose the device you want to pair with
    and enter the passcode then touch OK.
    5 Your phone will then connect to the other
    device, on which you should enter the
    same passcode.
    6 You passcode protected Bluetooth
    connection is now ready.
    Using a Bluetooth headset
    2 Follow the instructions that came with your
    headset to place your headset in pairing
    mode and pair your devices.
    3 Touch Yes to Connect now. Your KU990
    will automatically switch to Headset profile.
    If you have any questions you can try reading the manual here
    http://www.in.lge.com/Product/Manual/KU990.pdf
    Jan 11, 2010 | LG KU990 Viewty
    Sync iphone with plantronics bluetooth
    Bluetooth on iPhone:
    On iPhone:
    1) Go to Settings
    2) Go to Reset
    3) Select "Reset All Setting" (Make sure you save passwords. Data is safe.
    On Plantronics BT:
    Clear all previous pairings.
    Once iPhone reboots, turn on Bluetooth. Type in BT passcode.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Jun 11, 2009 | Apple iPhone Smartphone
    Passcode
    wats the passcode for a 9xx plantronics bluethoot
    Feb 02, 2009 | Plantronics - Bluetooth Headset Plus Base...
    Don't know the pin to set up my bluetooth
    Most Motorola bluetooths have a default passcode of 0000 and cannot be changed.
    Mar 14, 2008 | Motorola Mobility RAZR V3
    Bluetooth
    what you have to do is master reset the phone
    menu
    settings
    master clear 000000 - default security passcode
    if that does not work you may need to have the firmware reflash on your phone.
    hope that helps :)
    Dec 26, 2007 | Motorola Mobility RAZR V3
    Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
    47 people viewed this question
    Top Motorola Mobility Radio Communications Experts
    Coss
    Dennis
    Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
