Question about Onkyo HTR500 Receiver
Sound not coming from left side surround sound speaker or my right side front speaker
There is no sound coming from my left side surround sound speaker. and no sound coming from my right side front speaker,while watching my jvc tv or playing a video tape. when I play my reciever or a music cd they all work. does amyone know what may be going on. This just all of a sudden started all of a sudden. When I place my right side front speaker wire on the left side front speaker connection the right side front speaker works. Thanks Billy
  • 1 more comment
  • Anonymous Feb 28, 2008
    sound disturbens
  • Anonymous Mar 27, 2014
    when i turn on receiver it has no sound on front right speaker but when i switch the balnnce to right side only and turn up the volume it plays sound
  • Anonymous Mar 31, 2014
    radio ok speakers have no power unless i conect live to block only left side works then can you help please
It is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Posted on Aug 28, 2007
  • brian May 05, 2013
    thanks i will try that
SOURCE:
Tip
The Best Place to Put Your Surround Sound Speakers
If you can’t feel the vibrations everywhere—in your cheeks, ears, toes—you’re not getting the most from your surround sound system. One easy way to improve surround sound quality is to focus on speaker placement. Crutchfieldadvisor.com has a detailed tutorial, offering such tips as:
  • Place your center channel speaker directly above your TV—centered if possible. Align the front edge with the front edge of your TV screen to reduce distortion caused by sound reflecting and diffracting off the TV’s cabinet.
  • Position your front left and right speakers in front, and at equidistant points to the left and right, of your primary listening spot. Your front speakers should be at a 22°–30° angle with respect to your television.
  • The tweeters should be at ear level when you’re seated.
  • Position surround sound speakers so that they’re ear-level when you’re standing.
on Dec 18, 2009 | Audio Players & Recorders
How to set up surround sound
Not sure what you are looking for
But if 5 speaker setup have your front left and right speakers on the appropriate side of the television, your center speaker in the middle of the tv, Either mounted on the wall or underneath or on the shelf, try to have the center speaker set back from the front speakers. Subwoofer usually I mount behind the entertainment center. Your rear right and left speakers optimum position is behind you on the left and right.
If its a 7 speaker setup everything is the same except side right and left speakers go in the middle somewhere between the right and left front and rear speakers
I will make a example the the cursors [] Speaker *TV
LF[] CT and TV*[] RF[] []Subwoofer behind tv
SL[] []SR
LR[] RR[]
Hopefully that helps
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 15, 2013 | Audio Players & Recorders
Hi, I hve JVC TH G30 and i have connected my DishTV receiver (not HD) to the Aux port of the device. I can get sounds only on the front left and right speakers.. Is there an option to get surround for...
This is a 2-part question. You can get ALL speakers to SIMULATE a surround experience from ANY input, even 2-channel analog.
If there is an optical digital audio output on the Dish TV receiver use THAT and the TH-G30 can decode the surround audio properly.
Read up on surround modes in the manual.
Jun 07, 2011 | JVC TH-G30 Theater System
I would like to use my jvc home theater while watching tv. But i have no idea how or what wires to use to make this work.
You will need a 2RCA to 2RCA audio cable as shown below. Connect the audio out socket of your TV to the Aux or TV/SAT input of the JVC. When you want to hear the TV sound through the JVC system just select the appropriate input on the JVC. If you want the surround speakers to work, select ProLogic or All channel stereo on the JVC's surround settings.Because by default the radio or TV sound is only stereo, so only the front left and right speakers will work. PLII will convert 2 channel to 5.1.
Apr 26, 2011 | Audio Players & Recorders
Surround sound not working with PS3..
hook your front speaker wires up to the A side and on the front of it make sure only the A speakers are playing but leave the rear speakers plugged into the B side then hit the listen mode button and you should be rocking
Apr 24, 2009 | Kenwood VR-407 Receiver
7.1 speaker setup: no sound coming from right front/surr speakers
Solution to having no sound coming from certain speakers in a 7.1 speaker setup for TX-SR606 receiver when playing a DVD.
Review the cable setup for the DVD player since it was identified as the source of the problem. Best to unplug and plug in the cables to ensure they contact the back of the receiver's RCA jacks. Redo the microphone setup for Audyssey 2EQ calibration. A good chance that it is the cable that may have caused the malfunction and loss of sound from the speakers. The cables can come loose during setup and not plugged all the way to the back of the RCA jacks or a defective cable causing signal loss.
Apr 15, 2009 | Onkyo TX-SR606 Receiver
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
No sound from all speakers except front left and front right
Check the cables from the DVD to the Amp and make certain your in Dolby Digital mode on player.
Jan 24, 2009 | JVC TH-G30 Theater System
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
Onkyo HTR500 Receiver Logo
2,543 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
