Question about Acer Aspire 5610-4648 Notebook
Keypad incorrect to get the @ character I have to hit shift and " and viceversa
  • jacqui_carte Dec 26, 2008
    it just says the keyboard is working correctly...has been doing this since I bought it...:-(
  • 177 Answers
Restart your computer and if this doesn't work use ON-SCREEN KEYBOARD or go into:
CONTROL PANEL> KEYBOARD> HARDWARE> TROUBLESHOOTING
See if that helps...
Posted on Dec 26, 2008
Grap line 01 code 403 error
403 is defined as the Field Separator is missing. This is the ' character and can be found as the shifted character on the \ key, typically, above the enter key.
Sometimes this character is incorrectly represented as a A6 when viewing it with a hex editor, and it should actually be a 7C. If you're able to use a program like Notepadd ++ and the hex editor plugin, you can validate if your ' is a 7C. If not, you can replace all of those characters in your datastream and resend the file. If you're using a 3rd party software that creates the datastream and it is the software that is incorrectly creating this character, see if there is a way to change the character in their software or drivers, or contact them directly to see if they can help. This is a data error and not a printer error. The printer is basically telling you that it cannot find the character that tells you where one line of data ends and the next one begings. And because it starts on line 1, it should be on the line that starts with something like looks like:
{F,1,A,R,E,200,200,"TAG01"' <--- This is the character that appears to be of issue.
May 30, 2013 | Monarch 9855 Thermal Printer
How do i access the characters/symbols
you need to press alt and insert ascii char code for the marks.
Oct 17, 2008 | GE USB Retractable Number Pad HO98462
Delete key doesn't work
The ". del" key on the Numerick KeyPad will delete if you use the SHIFT key at the same time. It is easier to use the DEL key on the main keypad.
Jul 07, 2010 | Microsoft Computers & Internet
What is the keyboard combination for Ñ in a
Alt+0241
On Windows, the Alt key functions as a modifier like the Shift key. To make special characters, hold down the Alt key and type in the numbers from the numeric keypad. Note that on the some small keyboards (e.g. laptop keybaords) the “numeric keypad” is found by pressing the NumLock key and then looking for the keys on your keyboard that double as numeric keypad keys when in NumLock mode.
Jun 23, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
How do I get rid of "FN" on my notification taskbar;which key does it refer to? Does it have something to do with the keypad?
FN is the function button usually relating to the blue characters on the keyboard. It is used like the shift key when wanting to use the secondary character on the keys.
Nov 26, 2009 | Toshiba Satellite A135-S2276 Notebook
Is there a problem with my engine
E = error. Have dealer run scan test for fault codes.
Electronic Transmission Error Indicator
The vehicle is equipped with a redundant electronic gearshift indicator. This character appears with the key in the RUN position and displays the same gear selection as shown on the selector lever floor console next to the range selector lever. If an "E" character flashes or remains on this indicates that a transmission malfunction has occurred.
Visual Inspection Chart Mechanical Electrical
  • Shift lock actuator
  • Transmission control switch
  • SST (+/-) switches
  • Shift cable and bracket
  • Park sense switch
  • Central junction box (CJB) Fuse:
    • 204 (5A)
    • 205 (5A)
  • Damaged wiring harness
  • Loose or corroded connections
  • Powertrain control module (PCM)
Diagnostic Trouble Code Chart Five Digit DTC Component Description Condition Symptom Action P0815 SST +/- SST +/- circuit input signal failed. PCM has detected an incorrect voltage SST input. May not be able to shift in manual mode. Go To Pinpoint Test C . P1780 TCS TCS input incorrect per selected position. TCS voltage incorrect. No overdrive cancel when range selector is moved. Go To Pinpoint Test A .
Apr 24, 2009 | 2001 Lincoln LS
Wheelwriter II characters above the numbers print incorrect.
You may have an unusual printwheel that has special char. on the P/W, or you may be in the language mode hold code and press "L" key.
DickyO
Mar 10, 2009 | Lexmark Wheelwriter 3 Typewriter
Cannot get backslash (\) character to display
To get a backslash, you need to print the upper ascii character 92 (decimal). On most machines you can get upper ascii characters by holding down the Alt key and typing the decimal value on the numeric keypad. On the little IBM machine I'm typing this on, there is no numeric keypad, but if I switch on numlock (by doing shift-scroll-lock) the j-k-l keys become 1-2-3 etc. Now id I hold down Alt and type 92 (i.e.keys 9-k), this is what I get: \ Howzzat?.
Mar 16, 2008 | IBM ThinkPad 600X Notebook
Acer Aspire 5610-4648 Notebook Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
