Question about Bose Companion III Computer Speakers
Bose Companion 3 series II speakers aren't producing sound (imac)
I just took my Bose Companion 3 speakers out of the package and hooked up everything to my iMac 20" exactly as described (I've re-done the assembly a couple of times and re-checked every connection - they're all fine). For some reason, my speakers don't make a sound.
I can see that there's power to the speakers - the light is on. I can also see that my iMac headphone jack works because if I plug headphones into the jack I can hear music. I even tried hooking the speakers up to a new macbook and they don't produce any sound there either.
Any help would be greatly appreciated!
  • 4 more comments
  • ebear2222 Dec 26, 2008
    Just to be clear - these speakers connect through the computer's headphone jack. There is only one headphone jack on an iMac, it's in the back of the machine. Because these speakers connect through the headphone jack, I don't believe that drivers have any applicability to this problem.
    Of course, if I'm wrong about this, please let me know. Again, I welcome any help or suggestions!
  • ebear2222 Dec 31, 2008
    Yes, I know about tapping the control pod. The pod is on, it's just not producing any sound. Thanks for the suggestion, though, I appreciate it. Further suggestions would be appreciated if anyone has any ideas.
  • wolbo Jan 03, 2009
    I have the same problem with my Companion 3 on Vista. At first the sounds was there but after a few days there is no more sound.
  • deecoker Jan 06, 2009
    Sometimes my C3"s suddenly stop working. When I press any of the 2 speaker buttons on the keyboard the speaker icon displays along with a mute looking symbol. I called Apple. They told me to shut down and unplug for 3 minutes. Turn off the C3"s as well. Then fire up the iMac and then turn on the bose. Don't know why that works but it did for me.
    Let me know if this helps.
  • jedediah454 Jan 23, 2009
    yep.. i have the saaaaame problem and i got a PC. I updated all the drivers now and i now the sound doesnt even work at all! it would ouly play some of the music on youtube. and sometimes thge same music didnt play. then while in a game, i could hear just fine sometimes the base didnt work though,, but other times it did. But when i talked to someone in a game (oblivion) the voice wasnt there. It seams to be completely random.
  • sozsozsoz May 11, 2010
    Did you tap the control pod? That turns them on.
From what I've read, the imac has a 3.5mm (.138) jack while the Bose jack is 1/8 (.125). very small difference in size (.013), but enough to cause problems.
Posted on Nov 18, 2010
  • 600 Answers
Go to sound in  system prefs, you should be able to select them in the output section
Posted on Aug 24, 2009
Bose Companion 3 Series 2 Multimedia doesn't work.
Maybe a tranformer burnout, this is the most common cause, refer to a Bose service center
Jun 15, 2014 | Bose Companion 3 Series II Multimedia...
Can you use your tv remote on the bose companion 3 series 2 multimedia
Unless it came with a remote, there is no way to hook these up to a remote.
May 03, 2011 | Bose Companion 2 Series II Multimedia...
Can I hook up the Bose Companion 2 series speakers to my HDTV and get acceptable sound?
Well if you currently find the sound of the Bose acceptable and your inbuilt HD TV speakers poor, then the answer is yes. Should you not like the sound of the Bose, plugging them into an HD TV won't make them sound any better :-)
Just use the headphone out of your HD TV to connect. You may find you need to enable the headphone socket/volume via the menu settings on your HD TV
Dec 14, 2010 | Bose Companion 2 Series II Multimedia...
Hooked up my Bose companion 3 series II speakers but cant get sound. Which input hole do I put the audio cable? I put in the speaker jack that the original ran off of but its isnt working I have a dell xps...
Hi there , and happy new year ... The Cables are usualy Colour Coded , so try plug the Green Color coded Wire into the Green Jack Socket ...make sure it isnt connected to the Microphone socket..
Hope this Helps Bud
Have a Great Year: )
Dec 30, 2009 | Bose Companion 3 Series II Multimedia...
Loud hum when Bose Companion 3 Series II speakers are turned on.
I had the same problem for many months. I asked a sound & video professional and he suggested I move the subwoofer away from any power source. I had the subwoofer next to my UPS. Once separated and moved all wiring away from the power supply (about 12") the low bass hum was practically gone.
Jun 28, 2009 | Bose Companion 3 Series II Multimedia...
Loud hum with static when speakers turned on
There is def. a loose connection somewhere in your system. This is a grounding problem within the system if nothing else. Def. a "lazy" connection somewhere.
gurutim
Mar 10, 2009 | Bose Companion 3 Series II Multimedia...
Bose Companion 3 Series II not working (Mac)
The speakers seem to be muted by default - you'll see that the LED is yellow/amber. Tap the control pod - the LED will turn green and speakers will work. I felt like such an idiot after I spent almost an hour trying to figure this out. (This feature should be more prominent in the manual.)
Dec 20, 2008 | Bose Companion III Computer Speakers
Bose Companion  III Computer Speakers Logo
3,621 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
