Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Convergence I have a JVC model rm-c1200g it has went int a 3d type mode and i need help getting it back
  • JVC Master
  • 5,138 Answers
Replace Both of your STKs convergence ICs use Number on ICs if they are 110s use 180s if they are 020s use 040s.They are big Black ICs and will have on them STK392-110s for example.
Posted on Dec 26, 2008
Have a JVC AV-65WP74 that had convergence issues. Replaced the chips and one burnt resistor, no problem. Color is much better and I can fine tune the red in the manual convergence menu, but I do not have...
Been there, done that---JVC remotes are very expensive. I repair these sets as a sideline and I have a Samsonite case full of remotes--get your hands on the correct remote--check the flea markets or even EBAY.
I have a 57 inch someone gave me, told them unless that included the remote, forget it (it was the only major remote I did not have) Most of the remotes are 50 dollars or more at the wholesale level--check out EBAY as I have seen them there for much less.
If you lived in San Diego, I would loan you mine.
If replacing the chips and the usual one resistor made it better you just have to get into the tech menu and adjust and SAVE the adjustments--in the customer menu it does not save and if power is interrupted it may go back to whatever it was before you adjusted it.
Let me know if I can be of any help--I am here to help and have a lot of experience with these sets. My hat is off to you--not everyone can do that repair (yes, it is easy as the chips are up front) and you just need to go one step further. The exact or correct remote will allow you to do other things.
What I do in my own situation is keep the original remote in my case and use a universal for basic things.
REGARDS, SD TECH
Aug 17, 2010 | JVC AV-56WP30 56" Rear Projection...
The screen went to a 3d mode
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 27, 2010 | Toshiba 40H80 40" Rear Projection...
The blue crosses are too far right of center to adjust
you will need to install a convergence repair kit. You can get the convergence repair kit for your model at www.tvrepairworld.com which also contains the CD with step by step instructions for the repair.
Mar 28, 2010 | JVC AV-48WP30 48" Rear Projection...
My tv went multi colored take it as it looks like a 3d television
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | RCA HD61W66 61" Projection HDTV
Jvc 48 inch tv and the picture looks 3d
Convergence ICs have failed. You can get the convergence repair kit for your model JVC at www.tvrepairworld.com the kit contains both ICs the associated resistors and the CD with detailed instructions.
Jan 03, 2010 | JVC AV-48WP74 48" Rear Projection...
Convergence
Replace Both of your STKs convergence ICs big black ICs STK392-110s use number on your STKs for replacement www.electronix,com 1=800-223-3205 for Parts if they are 110s use 180s if 020s use 040s
Dec 26, 2008 | JVC AV-32D305 32" TV
Need Service manual to line up convergence
I went to JVC companies and a page came up and I selected services and I downloaded the manual.
Oct 30, 2008 | JVC AV-48WP74 48" Rear Projection...
JVC 56TH INC. IArt Rear Projection
If the red is colored outlines or 3d picture then it is a convergence problem.
If convergence is ok, then most likely screen/focus control assembly.
Easyab
Apr 21, 2008 | JVC AV-56WP74 56" Rear Projection...
I CAN'T GET THE CC OFF OF MY TV
Remote control original is part # RM-C1200G-1H ...best to
have JVC original......$25.00......................T.
Dec 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Red and Blue shadowing (Where are my 3d glasses)
There are two convergence IC's that are bad and need to be replaced, as this happens to almost every rear projectionj set ever made. They are stand up IC's , on a heatsink and they start with STK. They are soldered into place and this set has no user replaceable parts inside of it. If you have no solid state repair experience, you really should call out a trained tech to assist you in this repair. A TV set is no place to be diggin and experimenting inside of.
Sep 24, 2006 | JVC AV-48WP30 48" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
