Igxprd32 error error regarding video (blue screen)
  • Dick
    Dick May 11, 2010
    Any update to your issue yet?
  • Dick
    Dick May 11, 2010
    You should attempt to update to the latest video driver. System specifications would be helpful. Some of the ideas here might help you -
  • 56 Answers
Hi guy,
In fact,
To manually edit registry is kind of risky and inconvenience, so it is recommended to apply special designed professional error repair software to fix igxprd32.dll error completely. Just follow the below instruction:
* Step1: Free Download Award-Winning DLL Repair software.
* Step2: Install the software in your computer with ease.
* Step3: Click Scan button to diagnose dll error on your computer.
* Step4: Click Repair to fix dll error and other found PC errors in seconds.
Posted on Nov 28, 2011
    Problem Solver:
  • 18 Answers
Try this
Posted on Dec 31, 2008
Igxprd32 error
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 13, 2012 | Computers & Internet
Blue screen regarding File IGXPRD32
This is a graphics card driver problem. Did you or windows recently update the driver? You can do a system restore back before the driver was updated and that should fix your problem.
Another way is:
If you cannot boot into regular mode to the desktop then
try safemode F8 when computer first turns on hold down F8 key should get a screen with a list of choices, choose safemode.
1. Go into device manager, under display find the graphics driver right click on it, properties, and try rolling back driver...if this wont work then proceed.
2. Once at the desktop, go into add/remove (control panel) and uninstall display driver.
3. Go into device manager, and under display if its there uninstall the driver there too.
Now restart your computer and it should find the video card and reload the drivers.
Hope this helps. I would appreciate your feed back.
Oct 01, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
How can I fix this blue screen error STOP: 0X0000007B (0XF7A4F524, 0XC0000034, 0X00000000, 0X00000000, on my DELL Optplex 320 desktop using Win XP? Will appreciate your input
Maybe you can take a try of this rescue program called BootSuite. I came across similar blue screen situaiton on my HP laptop (win 7) and ended up with eliminating it. Hope it helps with your case. Regards
Jun 07, 2011 | Computers & Internet
Blue screen
Hi, you have two options.
1. use the recovery disc to reinstall. This will erase all the data.
2. try BootSuite, burn a boot CD to enter your black screen windows and rescue data first of all and fix the error yourself.
It is your choice. Best regards.
May 18, 2011 | Computers & Internet
Get blue screen and igxprd32 error on hp dc7700s
1. Fresh install winxp sp3
2. Copy igxprd32.dll to windows/system32 folder (ver.
3. Install Advanced PC Tweaker ,use once, scann and fix system and registry
4. Install all updates from microsoft, restart, then
5. Chipset sp38488 ,HECI sp34743 ,Audio sp39852 , and Network sp51788 (with error,but ok from divace menager/update driver)
6. Finally, install Gpaphic adaper sp42426 ,from HP support site
all drivers from above :
Jan 18, 2011 | Computers & Internet
Blue screen Dell Dimension C521
This problem occures when ther is an conflict with drivers, so try to updat your Bios from dell web site orm you may try to update the video driver or have an option to replace it and try Try to boot the system safemode and chk if you get the same BSOD if not then its the video drivers
Samson Ved
Feb 05, 2010 | Dell Dimension C521 PC Desktop
Blue screen showing igxprd32 error
If anyone else is having this issue here is how you can resolve it.
Open regedit, find these two keys HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0000 and HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E968-E325-11CE-BFC1-08002BE10318}\0001, then delete the InfPath entries under them.
Reboot and install drivers direct from the manufacturer.
This worked. Nothing else on all other forums worked at all. I have changed the PCI bridge, attempted to reinstall the driver (both in and out of safe mode), and a multitude of other things. This is it. End of story.
Apr 16, 2009 | IBM ThinkPad R52 Notebook
AVIC-80DVD video problem
hi sounds like your unit needs a new laser, you could try a cd cleaner disc.
Jan 18, 2007 | Pioneer AVIC-80DVD Car DVD Player
Computers & Internet Logo
2,187 people viewed this question
David Payne
David Payne
