Question about Acer TravelMate 2300 Notebook
Laptop blank screen and is in projector mode...
No power during laptop connected to projector...then after turning on, when i logged in, it is in projector mode. but after log in, it is blank screen. I pressed Fn F6 but i can tell from cursor it is in projector mode. But screen is still pitch black...why
After I log-on to my acer laptop the screen goes blank
try starting the laptop in safe mode. that will use the default VGA driver vs the driver that gets loaded after the log on screen. If VGA mode works then you have the wrong video driver installed.
Aug 28, 2014 | Acer 12V-13.5V (Input), 18V-20V...
When I connect to projector laptop screen becomes blank and display comes only in projector
Depending on your laptop you will have to select FN button along with F4 and change the view mode to PROJECTOR + Laptop.
Aug 10, 2011 | Acer Computers & Internet
I have an HP DV9000 laptop and did a presentation yesterday. When I arrived at the site I had to attach the display to an LCD projector. I connected the project via a porft connector, I believe that...
I think it's probably FN+F8 that may do this on the HP laptops. The key should have a little icon on it in the same color as the function key (typically blue) that will toggle the screen from the laptop screen to the external. There are usually 3 modes to this toggle
1. Laptop screen only
2. External screen only
3. Mirrored on laptop screen and external screen
So try toggling with the FN+F8 key combination.
Also you can probably start up in safe mode to disable the external VGA toggle.
When you see the HP Splash screen, start tapping the F8 Key to bring up the boot menu. From there choose safe mode and see if you get the video back in safe mode....After that reboot and see if it will bring up the video in normal viewing mode.
Good Luck
Mar 23, 2011 | HP Pavilion dv9005us Notebook
I have a compaq paserio notebook and when I boot up the computer, either I get a blank screen or I get a very faded image that I can't hardly see so I can't log on. Most of the time I just get a blank...
Have you checked the brightness options for the screen using the HP function keys? Fn +F7 or Fn+F8 should adjust the brightness of the screen for that C306 model laptop. If adjusting the brightness has no response then try the next steps.
What happens if you turn the computer off, plug it into an external monitor or projector, and then turn the computer back on? If the video displays correctly on a computer monitor or projector, but it stays dim on the LCD screen of the laptop, then the laptop LCD Screen Back-light or inverter is probably going out. You'll need to contact HP for a replacement part or take the laptop to a certified repair center.
Nov 05, 2010 | HP Compaq Presario C306US Notebook
Logged into laptop but get blank screen
OK thank you for the information, can you connect this via ethernet?.. Hard wire then get into safe mode with networking, so we can get you onto the internet to run some scans? nancie1186@optonline.net
Jul 11, 2010 | Gateway M-7315U Notebook
Dell xps 1530 will get to log on screen and go blank
try logging in safe mode first upon turning system on tap on F8 then select safe mode, once logged in safe mode to a system restore to the date before this issue happend if system restore gives an error it failes tr going back to system restore in safe mode the do a disc defragmentation click start, accessories, system tools, system restore then select restore my computer to an earlier time then select the date when everything was working fine
Jun 04, 2010 | Dell XPS M1530 Laptop
Delay/ whitescreen when projecting video from laptop
1.
Connect the external display port on your laptop computer to the projection system, and then turn on the projector. For information about connecting external devices to your laptop, see the documentation for your laptop computer.
1.
Set the display resolution of your laptop computer to match the resolution of the projector system. First, on your laptop, open the Display Properties dialog box by using the Display icon in Control Panel, and click the Settings tab. Then, in Screen resolution area, move the slider to adjust the display resolution of your laptop. If you don't know which setting to choose, try 800 x 600 pixels; this is a common setting for many projector systems. YOURS sounds like 640x840.
3.
If you have audio in your presentation, connect a cable from your laptop's audio output jack to the audio input jack on the projector, and then test the volume by playing a file that contains sound.
4.
Start the Player on your laptop. If you want to only display the Player on the big screen, and not the desktop background, maximize the Player or set it to play your video using the entire screen (full-screen mode).
Jan 08, 2009 | Dell 3300MP Multimedia Projector
My laptop is showing blank screen after restarting
try starting your laptop in safe mode by presssing f8 during the booting process, then check whether its boot or not
Oct 28, 2008 | HP Compaq Presario F750US
Trying to connect Inspiron 6000 to TV
If there is no display on your TV, HDTV, or Projector, please make sure that all of your connections are set up properly and that you have enabled the display in the Catalyst Control Center. The connectors that you will be using would be Svideo for TVOUT, DVI-to-HDTV (Component video), VGA-to-HDTV (Component video) for HDTV, and DVI, VGA, or Svideo for the projector.
737-22474-1.jpg Here are the steps to properly setup and enable TV, HDTV, or Projector:
  • Turn off your PC and your TV, HDTV, or Projector.
  • Ensure that your card was installed correctly, as per the Getting Started Guide.
  • Determine if your TV, HDTV, or Projector has a S-Video (for TV), YPbPr for (HDTV), or VGA/DVI for Projector.
  • Looking at the back of your PC, locate the needed connector or the supplied adapter cable; attach one end of the cable to your graphics card and the other to your second display.
  • Turn on your second display then your PC.
If you are connecting an HDTV to your video card, please Click here for detailed instructions on how to set it up correctly.
Starting Windows with TV or Projector Display Enabled The TV screen may become scrambled during the initial Windows® logo display. This is only a temporary effect and your screen will be restored within a few seconds. During start up, your RADEON will go through a sequence of mode settings, during which your TV display will remain blank. This process takes only a few seconds and helps program the TV display.
  • To enable the second Display
  • Right-click anywhere on your desktop
  • Click Catalyst Control center
  • View
  • Advanced view
  • Display manager
  • Detect Displays
  • You should have the second display picture under “Attached displays currently disabled
  • Drag it to the box on top of it
  • Apply
  • OK
If for any reason the second display does not get detected, please do the following:
  • Open the CATALYST CONTROL CENTER
  • Go to Display options
  • Check “Force TV detection” *
  • Apply
  • OK
* Force TV: Allows you to force TV detection if the ATI driver does not automatically detect TV-out connected to the graphics accelerator.
Possible issues:
In case the users display does not natively support HDTV display timings in the EDID, you can add standard HDTV modes so that the usual HDTV resolutions (720p, 1080i, 1080p) are listed in the Display Manager resolutions. You can also create custom HDTV timings to solve any kind of over-scan options (for cases when the windows desktop appears to not fit on the HDTV screen, and the outside boarder is cut off).
For more information on connecting your second display to your Video card, including supported output device combinations, please refer to your user’s manual.
Jan 23, 2008 | Dell Inspiron 6000 Notebook
Won't power off when pressing power button, just goes to standby mode
With most projectors you have to press the power button twice to confirm that you want to turn it off. When you press it the first time it waits for a bit and then turns itself back on assuming you hit the power button on accident.
Jul 23, 2007 | Compaq iPAQ MP2810 Multimedia Projector
Computers & Internet Logo
465 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
