Question about Black & Decker 1/2" 13MM, Heavy Duty Vsr Drill, 0 - 850 Rpm, Helical Cut
Red wire came out of my black & decker vsr 7190 type 2 drill
I was replacing the power cord. The red wire, which is attached to the white wire on the power cord, pulled out while I was repairing. I cannot figure out where it goes back.
  • Roeh May 11, 2010
    can you give me the model number and the type?
  • 8 Answers
SOURCE: I Own a U21 Black & Decker Drill Type AH070865
Go to www.2helpu.com which is the Black & Decker after sales service site. Most, if not all diagrams are located there, including manuals
Posted on Nov 17, 2009
rowdy45176
  • 2176 Answers
SOURCE: Black and Decker corded drill won't tighten around a bit.
the chuck sounds like it is bad or maybe stuck from rust, what you can try and do is spray some WD-40 on the jaws and then try and holding the collar with a glove and run the drill SLOWLY in forward/reverse and see if it loosens up if not you will need a new one.
Posted on Jan 23, 2010
  • 313 Answers
SOURCE: Loose white wire in B&D 7190 Type 2
If you look at the switch you will see a hole with a brass coloured contact inside. These are grip type connector where you push the wire in and it grips it. Try pushing the wire into the hole and see if you can pull it out again gently. If it holds you have fixed it.
Posted on Jul 26, 2010
  • 22 Answers
SOURCE: I need wiring diagram for a Black&Decker DR550
An electric meter can be used to find where wires go to switch
Posted on Jan 23, 2011
SOURCE: When replacing cord on black & decker 7190
If you look at the trigger/switch mechanism, you'll note little lettered ovals on either side at the bottom/base where the wires go. The black (hot) wire from the plug goes to the side stamped "LINE", and the white (neutral) wire goes to the side stamped "LOAD"
Posted on Jun 03, 2011
I have a black and decker rotary hammer drill i can only read 3 numbers of the model it is 045 but its the last three sn number 0481121 under pat 3309541 need parts manuel for
Your one sounds like this one
http://www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-c-4167_7879_17406.html
However there are three variants on this page.
http://www.ereplacementparts.com/black-and-decker-hammer-drill-parts-c-4167_7879.html
Black and Decker Hammer Drill Parts ' Great Selection ' Great Prices ...
  1. Cached
  2. Similar
Black and Decker 22738 Type 1 1/2-Inch Hammer Drill Parts. 22738 Type 1 Black ... Black and Decker 27106 Type 1 3/4 Rotary Hammer Parts. 27106 Type 1 ...
Black and Decker 5045 Type 100 Rotary Hammer Parts
www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-...
  1. Cached
  2. Similar
Black and Decker 5045 Type 100 Rotary Hammer Parts .... Drill Parts Hammer Drill Parts Rotary Hammer Parts. Search within model. SEARCH. Discuss ' Repair ...
Black and Decker Hammer Drill Parts & Repair Help ' Fix.com
https://www.fix.com/parts/power-tool/drill/hammer-drill/black-and-decker/
  1. Cached
Shop for Black and Decker Hammer Drill parts today. Find genuine replacement ... (Type 100). Variable Speed Reversible Rotary Hammer · 5014. (Type 100).
Black and Decker Parts - Tool Replacement Parts ' Tool Parts Direct
www.toolpartsdirect.com/brands/blackdecker.html
  1. Cached
  2. Similar
Black and Decker Drill & Driver-Drill Parts · Black and Decker Hammer Drill Parts ... Black and Decker Rotary Hammer Parts Model Schematics and Tool Parts ...
Black and Decker 5043K_TYPE_3 ROTARY HAMMER KIT Parts ' Tool ...
www.toolpartsdirect.com/blackdecker-5043k-type-3-rotary-hammer-kit.html
  1. Cached
Find the Black and Decker blackdecker_5043K_TYPE_3 ROTARY HAMMER KIT parts you need at Tool Parts Direct. Shop thousands of Black and Decker ...
Black and Decker Rotary Hammer Parts ' Tool Parts Direct
www.toolpartsdirect.com/hammer/rotary-hammer/blackdecker.html
  1. Cached
Replacement Black and Decker Rotary Hammer Parts online. Tool Parts Direct has thousands of Rotary Hammer Parts to fix Black and Decker tools. Shop by ...
www.toolpartsdirect.com/hammer/rotary-hammer.html
  1. Cached
  2. Similar
Tool Parts Direct carries the largest inventory of replacement Rotary Hammer Parts for thousands of make and models. Buy Rotary Hammer Parts online for all of ...
Black & Decker Replacement Parts - 1800ToolRepair.com
https://www.1800toolrepair.com/tool-repair-parts/black-decker
  1. Cached
Black & Decker replacement parts for all Black & Decker tools. ... Black & Decker Cordless Circular Saw Parts ... Black & Decker Electric Hammer Drill Parts.
Beyond Parts - Black & Decker ServiceNet
servicenet.blackanddecker.com/Parts/Detail/29096
  1. Cached
  2. Similar
Available, Add Parts to Cart ... Model #, Model Description, Parts Diagram. 5041K Type 1 · MACHO I ROT HAM KIT · 5042-09 Type 1 · HD ROTARY HAMMER.
black and decker rotary hammer drill Google Search
Dec 25, 2016 | Rotary Drills
Where does the green wire from the power cord attach to on a dewalt dw 236 drill
The green wire is always the ground wire. It should be connected to the ground pin on the power connector.
Hope this helps.
Feb 28, 2015 | Dewalt Dw236 1/2" Heavy Duty Vsr Drill...
How to replace power cord
REMOVE SCREWS IN DRILL WHOLE UNIT OR JUST HANDLE WILL SPLIT IN HALF INSIDE YOU WILL SEE YOUR WIRES PLUGED IN OR SCREWED IN . PUSH ON STKONS MYBE ON WIRE ENDS IF YOU CAN REPLACE THEM GREAT.IF NOT JUST STRIP BACK WIRES AN WRAPE AROUND SCREWS AN SCREW IN TITE REPLACING WIRES GREEN TO GREEN RED TO RED BLACK TO BLACK & WHITE TO WHITE SCREW UNIT BACK TOGETHER AN DRILL
Aug 30, 2012 | Makita & 1/2 Inch Drill
My porter cable 19.2v model 8605 battery charger
Porter Cable has not offered a replacement for their poorly designed 19.2V chargers. I had the same problem and happen to like my drill and circular saw. I found a universal charger called a model number CHUN-2420. Google it--I got mine for $27 plus shipping. All you need to do to make this work is splice 3 wires.
My charger is a PC model 8624, so the instructions might vary slightly between the chargers. Remove the six screws on the bottom of your PC charger. Remove the bottom section. Remove the screw(s) that attach the circuit card to the plastic housing. Disconnect the 3 pin white charging connector from the circuit card, and cutoff the connector. Discard the circuit card and power cord. Cut the 3 conductor (red/yellow/black) cable coming out of the Chun-2420 approximately 2' from the charger. Splice these three wires to the three wires in the charger housing that connect to your battery. In my situation, Red/Red, Yellow/Yellow, White/Black. To verify, red=positive, black/white=negative, yellow=temperature sensor. Wrap the red/yellow/black cable with electrical tape where it exits the PC charger through the power cord hole. Re-attach the bottom.
Jul 24, 2010 | Porter Cable 19.2V Drill Kit
Jul 20, 2010 | Black & Decker 1/2" 13MM, Heavy Duty Vsr...
When replacing cord on black & decker 7190 type 1 electric drill i dropped the drill one of the wires pulled free and im unable to visibly tell how it is to be rewired correctly need diagram displaying...
Jul 02, 2010 | Drills
Drill works in only one position
You most likely have a loose connection inside somewhere, when you turn the drill to another position it creates a gap in the connection, therefore breaking the circuit.
Jun 05, 2010 | Black & Decker 1/2" 13MM, Heavy Duty Vsr...
B&D drill parts search
actually you can find any almost-similar carbon brush and reshape them with sand paper..couple things to consider is the spring structure and the way copper wire connected to the carbon..some connected at the **** and some at the side...
trust me,find bigger carbon and reshape with sand paper..it work!!good luck
May 30, 2009 | Black & Decker 1/2" 13MM, Heavy Duty Vsr...
Need wiring diagram for dw505-2 trigger
Here is your parts diagram just in case you need it.
http://www.ereplacementparts.com/dewalt-dw505-type-hammer-drill-parts-c-1009_9661_2281.html
And here is the number to a factor tech which could answer your question on trigger wiring. There is no diagram available but, I'm sure a tech will get you up and going.
(702)889-6025 ask to speak to a tech.
Mar 31, 2009 | Black & Decker Dewalt No.DW505 Heavy Duty...
Black & Decker 1/2" 13MM, Heavy Duty Vsr Drill, 0 - 850 Rpm, Helical Cut Logo
224 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
