Question about ViewSonic VE155b 15" LCD Monitor
Viewsonic ve155b Dead
Monitor dead power light on see faint line across screen cpu see it ok. Any tests and suggestions? Jon
  • Anonymous Feb 14, 2008
    Same problem-the monitor light is "on" (green) but the screen is completely black. All connections checked...
Shine a flashlight into the monitor, if you can then see what is usually on your desktop, then your backlight has a problem.
Posted on Jul 11, 2008
Hp P6000 fans stop after 15 seconds. Hard drive light stays on. nothing on monitor
dead PC, DESKTOP PC ,as old as 2009.
the fans tells you the PSU shut off, for cause.
fans, so you saw all fans turn off or just 1. or 2 of 3.
my pc has 4 fans many have 3;
CPU fan stops ,cpu overheats , PC goes slow or dead. clean the lint off it.
GPU fan , video goes dead. if it overheats.
PSU fan is inside the PSU if it goes bad, PSU is bad.
no monitor stated, is it CRT or LCD is it 15 years old.
if the monitor is 2002 or newer the OSD screen works
even with PC turned off, press the select button see that OSD screen ? telling you the monitor is not dead in 1second flat;
i caN NOT understand why the HDD lamp glows,
if the PSU shuts off , most LEDs go dead, on my PC
the standby LED on the MOBO glows, unless you pull the PSU power cord.
your HP PC came with 9 different mobo, during its production run.
at least. so answers come harder from that reason.
here are some simple tests.
test 1
power on, hear fans run
does the DVD drive (or cd) button eject work,.?
do all fans not just 1 or 2 worK? look for all fans clean the lent out
or things will overheat,
PSU can be bench tested or in the PC case.
using a jumper wire, even the HP service manual covers that.
power on the PC (after keeping monitor on for 5 full minutes)
test 2
the Screen must say, "hit ESC key to enter HP setup" BIOS.
press the ESC key on the monitor
if no text shows up that is a dead PC< "text above missing{"
if the PC told you to hit another key do so.
The ESC key , activates the BIOS brain. this cause
all those pages to work as seen in your service manual;.
if BIOS is dead that is a bad PSU (monitor ok)
or CPU is overheated.
bad ram, take all sticks out and test 1 by 1, ask how. !
The PSU will shut down on up to 12 or more faults
but never shuts down the standby power bus. unless AC line pulled.
IF the PSU has fan as most do this is the first place I look.
try this guide
https://support.hp.com/us-en/document/bph06788
Jul 08, 2017 | HP Computers & Internet
I have view sonic ve155b I turned the monitor off at the power switch on the monitor last night and this morning it will not turn on. I can't even get a light to show it is getting power. I have tried...
This VE155 uses wallwart 12vdc 3.5A power supply, you need to check first to see if it is putting out 12vdc.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 25, 2011 | ViewSonic VX2235WM Monitor
When i changed my old monitor with ViewSonic VE155B Black 15" LCD Monitor, the beautiful pictures previously stored on my computer appear too dark. i checked the settings of monitor, but the brightness n...
rubina576, I see you haven't looked at the "date of manufacture" on rear of your VE155B!!!! Retrevo .com lists unit as time to retire. The long,"very thin", "cold-cathode-fluorescent-lamps" that provide a "constant" bright, "white light" on the reverse side of the LCD PANEL, have "worn out" and are very "tired"!!!! You can see typical lcd CCFL's at: www.rexim.com and click on "products" you will see "lcd backlights" !!! YOU ARE NOT QUALIFIED TO CHANGE THEM. A technician will need to do it. Very time consuming procedure. If your ve155b menu button on monitor can't fix brightness for you, then your options are: 1. check with viewsonic to cost out a refurbed VE155b if you can. 2. Trade in unit for new wide-screen 2010 or 2011 lcd monitor. If this was of some help, please rate my response on fixya. By for now. 12fixlouie north of Windy City.
Oct 21, 2010 | ViewSonic VE155b 15" LCD Monitor
The view sonic VA1701WB display is totally white on the screen during up the computer and i check the CPU is booting up but at the same time monitor screen is totally white please reply the reason.
It can be due to:
Dead T-CON board on the LCD panel assembly due to blown fuse or just dead board.
Dead power supply on the logic board that supplys the power to the T-CON board.
Learn more here:
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 19, 2010 | ViewSonic VA1703wb Monitor
ViewSonic VE155b
this means that your computer is set to either a too high frequency or too high resolution. Try to lower the resolution setting of your desktop step by step, until the message disappears.
Jul 23, 2010 | ViewSonic VE175b 17" LCD Monitor
ViewSonic VA912 half screen dead after 30 minutes
first i confirmed that the problem was in lcd.then i predicted that some display chip on the motherboard are getting heat.due to which the display was performing irregular then i switch on A/C of my room.and the temperature was cool. and the monitor was working fine.
Apr 29, 2009 | IBM E54 (Pearl, White) 15 in.CRT...
No power to monitor despite being plugged in
Check your video card. Is your computer booting up?
May 25, 2008 | ViewSonic VX910 19" LCD Monitor
Power saving
Right click your desktop, click properties, click the screen saver tab, it'll say monitor power at the bottom, click power then choose which option you want. Good luck.
Aug 14, 2007 | ViewSonic VE155b 15" LCD Monitor
56 V - faint horizontal lines across the display
u can search problem in vertical section may be sum IC component was dry resold them .
Aug 02, 2006 | SAMTRON 55V 15" CRT Monitor
19"ViewSonic LCD Monitor wont work at all !!
If you have the pc on and the monitor light stays green, take a flashlight to the screen. If you can see the images while shining the flashlight into the screen, they will be hard to see but they will be viewable, then its most likely the back light. The vx900 takes 4 bulbs and they are about $12 US each. Anyone who knows how to solder should be able to replace them.
Jul 02, 2006 | ViewSonic VX900 19" LCD Monitor
ViewSonic VE155b 15" LCD Monitor Logo
131 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
