Question about Magellan RoadMate™ 1212 Car GPS Receiver
Magellan Roadmate 1212
I just got this for Christmas and am having trouble getting rid of a address that was in the unit when I opened it.I tried the instructions but no luck.I put in my home address and when I use that address for a route,it only uses it for an end destination.Any help would be greatly appreciated.
  • larry7186 Dec 31, 2008
    same problem; no help from toll-free support desk...no help from toll-free tech support except recorded voice "try again"'; no help from user manual; no help from on-line Maggie...maybe only solution is to try another make!! probably a very simple solution - can anyone help? thanks
  • nthpokt Jan 04, 2009
    Thanks abstracttech. I did however notice that when I actually hooked the unit in my truck,the home address started as my address so I guess it had to be activated and used in real time.I was putting in my home address just out of the box in the living room
  • 4 Answers
Instructions and POI software are on the CD that was packaged with your GPS.
Posted on Jan 04, 2009
I need a manual for my magellan roadmaster 1212
You can view and download the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 19, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Broken screen Magellan roadmate 1212
Hi.
It is actually much cheaper to buy a new unit than to repair it.
It cost around $150 and above, depends on how crack it is and what model of magellan you're using.
Jun 09, 2010 | Magellan RoadMate™ 1212 Car GPS Receiver
Once region is set how do I change it on the megellan roadmate 1212?
By default, the Magellan RoadMate has the region setting for the lower 48 United States. When the receiver is turned on for the first time it may ask you to assign regions. Select the map region you want to use by tapping on the item from the list.
If you are travelling in other regions you will need to change the map region by using the following steps.
1 From the Main Menu, tap on the right arrow to access the second page of the Main Menu.
2 Tap on User Options.
3 Tap on Region.
4 Tap on the map region desired.
The Region option will display the map regions that are available for the Magellan RoadMate you are using.
Also if you want you can download the user manual from this website
visit website
or
download
Hope this helps
thanks
Oct 01, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
My magellan roadmate 1212 is in French. I need to change it to English. How do I do this?
your manual here
http://www.magellangps.com/assets/manuals/604-0132-001_A_UM_1212_ENG.pdf
Jun 24, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
Missing SD Map Card on Magellan Roadmate 1212
Unfortunately even if you do find a card it will not work with your unit because the cards have to be for that unit.If it is from another unit the codes will not allow it to work. The only option I know of is to purchase your map for that unit and put it on a sd card
May 09, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
Magellan Roadmate 1212 won't stay on when unplugged
Man, I DO commiserate with you on that one, but did you specify to them that the battery should be checked?
as that is probably your problem, now that I know the unit has been checked and the worst possible outcome
from your buying an extra battery is that you will HAVE AN EXTRA BATTERY for those times when you need
total portability.
So, make sure you try a brand new battery and if that solves your problem, then buy several.
Apr 17, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
It came with no instructions could I have them emailed to me???
CLick here to download the manual
You can also right-click on the link above and click on save target as to download it without opening.
Regards,
Sai.
Feb 03, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
Press MENU then select USER OPTIONS the select SYSTEM SETTINGS then select POWER then select NEVER. This will never let the GPS sleep.
Oct 18, 2008 | Magellan RoadMate™ 1212 Car GPS Receiver
Magellan Roadmate 360 reset
Called Magellan tech support, According to them you can't delete previous addresses, the unit will just override old destinations as you put in new ones.
Dec 01, 2007 | Magellan RoadMate 360 GPS Receiver
Magellan RoadMate™ 1212 Car GPS Receiver Logo
90 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
