I post a solution for this problem see: www.fixya.com/support/t2748127-false_door_open_reading_aficio_350
Comments:
Oct 27, 2009
- Check the fuse FU1 y FU2 in the power supply board FU1 display open door Without
saying as.
Comments:
Aug 22, 2009 - The flat cable of the
laser also can cause the fault of open door,
cut or badly connected this also it can be indicate door opened without indicating
as. El
cable plano del laser cortado o mal conectado, tambien puede provocar
la falla de puerta abierta sin indicar cual de ellas está abierta.
Oct 18, 2009 - For that
they visit this post… nothing costs to be thankful…
how to setup a eStudio 210c to work on a network. Do you plug it into the router or a PC? How do you...
(More)
how to setup a eStudio 210c to work on a network. Do you plug it into the router or a PC? How do you set the IP and so forth
hi.... canon np7160 need to reset after service??? counter reading indicator was blinking....how to...
(More)
hi.... canon np7160 need to reset after service??? counter reading indicator was blinking....how to solve this......
Trying to make 2 - 2 copies. Machine has message "duplex unit not set". I don't know where...
(More)
Trying to make 2 - 2 copies. Machine has message "duplex unit not set". I don't know where the duplex unit is, much less the metal tab. Please start from the beginning!
