Ip connection not happening
I cannot connect to http://192.168.1.1. which is the Ip address for web connection for my router
  • Anonymous Feb 25, 2009
    I cannot connect to the IP address, but my router is new bought.
    Genius:
  • 2,785 Answers
Plz check the cables and the lan card, if every thing is ok then your router might be having problem
Posted on Dec 26, 2008
Need password to my cisco wireless router
For that press RESET button of your router for 10 seconds then it will automatic restart and reset. then connect router to computer lan port with lan cable. then you can access it with default ip addresshttp;//192.168.1.1 or http://192.168.1.2 Type user as 'admin" and password as "admin" or "1234" or "password" or blank then you can see configuration page of router. Then click on wireless->security then note down the password.It's your password to connect wireless.
Let me know if you need further assistance. thanks for using fixYa.
Oct 17, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I want to install my D-link wireless
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 10, 2010 | Computers & Internet
Router connection
> router should be turned off after use
Nonsense. The router uses DHCP (Dynamic Host Configuration Protocol) to obtain (only!) one IP-address from your I.S.P. Each IP-address comes with a "lease", i.e., "use this IP-address for the next NN hours, and after that time, send a request to 'renew' the IP-address for another NN hours". This should(!) happen automatically -- without a need to restart the router.
So, if only the two "wireless" laptops are having the problem, the problem is inside the router.
Connect to the web-server "inside" the router, and look at the "status" web-page, and then the "log-files" web-page, to see what error-messages have been recorded.
Jul 03, 2010 | Belkin (F5D8231-4) Wireless Router...
I recently got a Mac desktop and my Linksys router disk will not open up. Do I need a router that is made for Macs or is there a way to configure the Linksys?
Hi, You are correct. The CD is not compatible with Mac. What you have to do is Configuring the Router Manually using the Web Based Configuration panel.
How to:
  1. Open your Web Browser
  2. Type http://192.168.1.1 in the Address Bar and hit Enter
  3. If you have changed the address somehow you have to enter that (Router's IP - Default Gateway)
  4. Here is a small guide to Fine your routers IP address in case of that you are unable to access
  5. Enter the user name (default user name is blank- means no user name. Just leave it blank), Default password is admin.
  6. Now you can configure the Router using the Menus.
  7. Make sure that you have Saved your settings before Exit the Web Based Setup.
  8. Make sure that you have changed the Default Password.
  • If you can’t access the router’s web-based setup page, please check the following: cable connections, router’s LEDs, IP address, and connectivity.
  • Connecting Devices Together
  • Ensure that you have an Active Internet Connection and connect the modem to the router’s Internet port and the Mac to any of the four Ethernet ports.
  • Checking the Router’s LEDs
  • After connecting your modem and Mac to the router, check the lights on the front panel of the router.
  • Checking the Router’s IP Address
  • To find a Linksys router’s Local IP address, you have to check the IP settings of the Mac
  • Checking the Mac’s Connectivity with the Router
  • Ensure that the Mac is properly connected to the router.
You can download the Manuals from here to learn how to do Advanced, Customized Configurations.
Note: Please select the appropriate Hardware Version.
Thanks for contacting Fixya! Feel free to ask any questions if you face trouble with the setup. Please rate the answer as well!
Jun 22, 2010 | Linksys Wireless-G WRT54GS Router...
IP address invalid
8360169.jpg music studio 12 deluxe installed correct on vista openns to studio but wont finish loading computer locks if i click on any tabs ???
Dec 18, 2009 | Computers & Internet
I do not get a login prompt when I enter the address of the netgear mr314 in the address bar of mr browser. Is it using a different port?
I assume you're trying to access the unit with something like http://192.168.1.1 or whatever the default address is. And what happens then? A page-not-found error? Can't connect? The most likely causes for the problem are
  • The wireless adapter (or Ethernet adapter, if you're using that) on your computer is not set to obtain an automatic IP address and is not on the same IP network as the router
  • The router's IP address has been changed from what you are expecting
  • If you can ping the router but not connect to its web interface, your browser may be configured to use a proxy; that should be turned off when connecting directly to the router.
Sep 26, 2009 | NetGear MR314 (MR314NA) Wireless Router
Configuring nbg334w router
To configure the wireless router it is recommended the it is connected directly to router.
Please follow these steps to fix your issue
1. Reset the router using reset button on the back of the NBG334W router
2. Configure or change the laptop ehternet adaptor setting to "Obtain IP address automatically.
3 connect laptop and router using ethernet cable. check the ip address using ipconfig command in DOS prompt. If IP address is 0.0.0.0 or 169.X..X..X run command
ipconfig /release
ipconfig/ renew
best way restart the computer
4. if you still have issue in getting ip address double check ethernet cable and try reseting the router again.
5. Still problem persist install new firmware on the router. you can download router firmware from
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420070320142921
Please vote if this information is helpful in resolving your issue
Dec 27, 2008 | Zyxel Prestige 334 Router
No web page for installation
just try to reset your router and then make sure that your that ip address was obtain automatically by the router. you can check it by opening the "control panel" then double click the "network connection" then right click the "Local Area Connection" then select "properties" then on the connection type, select the "Internet Protocol (TCP/IP)" by double clicking. then make sure no ip address is manually inputted by selecting "Obtain an IP address automatically" and "Obtain DNS server automatically"
that all.
Dec 03, 2007 | D-Link AirPlus DI-524 Wireless Router
DPR-1260 ... prints but cannot access web config page
To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Help connecting Cable Internet through D-Link DI-514 Router
what may be happening is the wireless pc as it was; needs the dns and ip address flushing, also the pc you connected the router to as you must have conflicting ip addreses Click start run then type ipconfig /flushdns. You should ensure that the router is set to enable DHCP to assign ip addreses and make sure your'e network cards on all pc's are set to obtain ip address automaticaly in the TCP/IP properties. Restart the pcs and type 192.168.0.1 in your web browser and get into your router setings and check in the DHCP section that all pc's have been given an ip address. If all fails you may need to reset the router
Sep 03, 2007 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
