Question about Proton R5A Clock Radio
Proton Model RS-420 clock radio lost power back-up
Radio works fine except the power back-up function has ceased to operate - was OK for about 12 years. Now, whenever there is a power glitch (even for a millisecond) it looses the time and all presets. A real chore to reset ever time and if the glitch occurs during the night I don't get my wake-up music. What component has gone bad? Can you specify it and its location so I can get a new one and replace it? I have never opened up the case since I purchased it. Proton Radio Model RS-420 and S#RS420008283
  • 1 more comment
  • mrpauls Mar 31, 2008
    Same problem. No battery backup but original box says built in rechargeable battery. Also, I need to recall how to set what radio station comes on when you use the alarm. email me at mrpaul@tampabay.rr.com if you have the answer. Thanks
  • asureyes Jan 12, 2009
    Yes the back up battery has lost its ability to holds a charge, I need to find the circuit boad power supply and replace the batter. Anyone with a schematic on the curcuit ?
    Note, the alarms (both) default to the last station tuned to from the normal operatoin tuning, not the pre set keys.
  • adamsusa Feb 15, 2009
    Same problem - loses settings after power outage (and boss is getting pissed about me showing up to work late ;)).
    I just opened up my unit, don't see anything that looks like a battery. Any help here available?
The battery is located on the display circuit board at the front of the unit. It's a bit of a pain to get to.
You'll need to open the case, unplugging the wiring harness plugs so you can take the two halves apart. Next, remove the strip of circuit board at the top where the snooze/alarm and other top button switches are. Then you will be able to get to all of the screws holding the display circuit board to the front of the case. The battery is soldered to the board. I'm not sure what type or voltage it is, but it's probably a single-cell NiCd at 1.2v. I think the best replacement would be a supercapacitor but I need to figure out exactly what the battery is first.
It's a great radio that's worth fixing. If anyone can tell us what the battery is, please post! Mine says "860" on it.
Cheers,
- Phil
Posted on May 31, 2009
  • wapco46
    wapco46 Nov 02, 2012
    My battery is a Varia 11DK, and you could read that other number as 098 or 860. Have you come up with a replacement yet? It's too good a radio not to fix. Thanks
Lost power to my house, came back on outlet has power clock on radio works radio has no power. wall clock on same outlet works fine
There is a battery backuo in the radio. This is probably powering the clock. It looks like the radio power supply is either fried or the hardwired fuse is blown.
Take a look at the manual. If you take out the battery back up does the clock still work? GPX MP3 Player KC232S user manual
Apr 12, 2015 | Audio Players & Recorders
Radio does not work
check first for any fuse blown
Aug 18, 2008 | 2001 Chrysler Town & Country
The alarm display in the lower right corner on model #RC40-A keeps blinking and will not stop. This happens with both wake 1 and wake 2 options. I fixed it once by unplugging the unit but it this did not...
Hello
Just reinstall the battries and adjust the time once again.
Battery back-up operation
* This clock radio is equipped with
a memory holding system that can
be powered with 2 "AA" batteries
(included). The power failure
protection circuit will not operate
unless battery is installed.
* When normal household power
is interrupted, or AC line cord
is unplugged, the batteries will
power the clock radio to keep
track of time and alarm settings
programmed into memory.
* When the battery backup functions,
the digital display will not light,
however, the function of alarm
still occurs during the power
interruption if remaining battery
power is adequate.
* Normal operation will resume after
AC power is restored so you will not
have to reset the time or the alarm
To install batteries:
1* Remove battery compartment door
(located at the bottom of the radio)
by applying thumb pressure to the
tab on battery door and then lift
the door out and off the cabinet
2* Insert 2 AA batteries (included).
3* Replace the compartment door
Replace batteries every year.
Power is fed to the unit even
when it is not functioning. To
cut the power supply off, the
power cable must be unplugged
OK.
Jul 10, 2011 | RCA Rc40 Clock Radio
My Proton 320 radio has stopped working, although the clock function still works. Is this a simple fix? Where could I find a manual?
Unfortunately, Proton discontinued these a very long time ago. There is not very much information available about them. The cause for the radio malfunction could be a number of things. One possibility is the switches. There is a foam gasket around the switches that degrades over time. If pieces of it get stuck inside the on switch, or lock the off switch, it would prevent the radio from working. You could try taking it apart and use a can of compressed air to clean out the switches. I had a problem with the radio turning on all by itself and the compressed air cleaning solved it.
Oct 23, 2010 | Proton R5A Clock Radio
Lost my 'off' ' button on my Proton 320 clock radio!
No need to worry, you can buy adjustable knobs and at radioshack and ebay. However if the button broke off you need to go in and replace it.
Sep 29, 2010 | Proton R5A Clock Radio
I have a ten year old Proton Clock Radio RS-330, now Sangean RS-330. The flourescent display seems to be about half out, and the time display is barely visible in the dark. Can this be repaired, and by...
The display itself may not be the problem which may be related to the power supply for it instead. Some technical skills and a decent multimeter is the minimum you should have to determine the source of the problem.
If you are looking for a local service company, you should always post your ZIP code so a tech in your area is likely to respond.
Jun 28, 2010 | Proton R5A Clock Radio
The FM tuner picks up only a few stations and those are very faint. Two other Proton model 320 radios work fine in the same area. I live on Long Island where the reception is rather strong.
The tuning module within the radio is getween the base circuit card and the display. A shot of tuner cleaner into one of the ports will usually bring back the FM performace (I just got done diong my own). Also, it goes without saying that you need to make sure your radio still has its antenna wire and that the vacuum didn't eat it. If this is beyond your skill level, find a computer geek (there are few radio geeks any more). Commercial repair would cost more than the value of the radio.
Jun 11, 2010 | Proton R5A Clock Radio
Proton 320 clock radio won't stay off. Comes back on by itself!
check power switch if not block and i good position. and also monitor by multitester if the continuity of that switch cut in off position.
Apr 13, 2010 | Proton R5A Clock Radio
Remote ceased working for Bose MODEL AWR1-1W. Are new remotes available for this model?
My problem was simply a remote pad ceasing to function. I don't need to pay for a plan to replace.
Thanks,
Nov 05, 2009 | Bose Wave Radio
Smarset clockradio
Sorry it took so long to answer your question about the Clock/Radio. This look like a problem with the Clock/Radio's Microprocessor. You will need to reset the microprocessor by removing all power sources to the microprocessor. This means removing the Clock/Radio from the A/C power source and removing the internal battery (CR2430). After removing all the power sources from the Clock/Radio, let the Clock/Radio set for a period of about 3 hours. This will let the power completely drain from the microprocessor and reset it to the factory settings. You can then reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio should have reset and the functions returned to normal operations. If The Clock/Radio functions have not returned to normal. You will need to let the Clock/Radio's microprocessor drain off the power again and put a new internal battery (CR2430). Then test the Clock/Radio's functions again. The Clock/Radio functions should have returned to normal operation. If you are still having problems getting the Clock/Radio to return to normal operation. You can call the Emerson customer support at this telephone number 1-800-909-1240- Call them between the hours of 8am to 4:30pm central time USA. Give them the make and model number of your Clock/Radio and ask them for their assistance. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Apr 29, 2008 | Emerson Smartset Clock Radio
Proton R5A Clock Radio Logo
1,178 people viewed this question
Top Proton Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Proton Audio Player and Recorder Expert? Answer questions, earn points and help others
