Question about Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer
Rocks in machine
This washing machine has been getting noisier and noisier up to it sounding like a jet taking off in the kitchen. Now when it spins it sounds like it has got a drum full of rocks. I dare not use it again as the last time i thought it was goung to blow up. any ideas of what is wrong with it?
  • Anonymous May 14, 2008
    MY WASHING MACHINE SOUNDS LIKE A JET TAKING OFF WHILE SPINNING. I EVEN TRIED TO SIT ON IT TO STOP IT FROM TAKING OFF...LOL.. BUT IT DIDN'T STOP THE AWFUL BANGING,THUMPING SOUND. THE DRUM FELT LIKE IT WAS BOUNCING OFF EACH SIDE OF THE WASHER WALLS. ANY ADVICE WOULD BE APPRECIATED.
    New Friend:
In addition to above comment it could also be the drum seal which needs replaced.
Posted on Dec 30, 2012
Hi, I have had the same problem but its a really easy fix. Put the machine on its side, remove the bottom, you will see 2 spring struts fixing the drum to the bottom of the chassis. These are fixed to the drum via 2 bolts and the same on the bottom. These gradually work loose and will need tightening with a 13mm spanner.
Thanks
Posted on May 25, 2008
    Scholar:
  • 121 Answers
Does the drum seem to be loose? If it is old/has been used a lot it might be the bearings holding the drum that are defect. try spinning the drum by hand and see if it makes grinding noises from where the drum is conected to the back.
Posted on Apr 17, 2007
Why is my front loader noisy at end of cycle in spin?
Most likely the rear main bearing is bad
Jul 13, 2015 | LG Washing Machines
SOUNDS LIKE JET PLANE WHEN IT GETS BY RINSE AN SPIN TIME
I assume you mean it sounds like a jet plane when it spins, if so, I suspect a bad tub bearing. Depending on age of the machine, probably too expensive to repair.
Mar 07, 2015 | Maytag Neptune Washing Machines
701 smart drive washing machine leaking but working no error
is the leaking water brown if so with it being noisier on spin it will prob be the drum bearing are on there way out
May 28, 2012 | Fisher and Paykel Washing Machines
I have a loud knocking sound coming from the back with every evolution during spin cycles. It is my girlfriends machine and I have looked at taking the back off but am not sure how it comes off and don't...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 17, 2011 | Samsung Washing Machines
The machine sounds like a jet during a spin cycle. Seems to be getting worse as the time goes by.
kitchen ranges dont have a spin cycle.......
if you mean washing machine.... could be main bearing on the drum..........
cheers
Mar 26, 2011 | Kitchen Ranges
Hi I have an Aqualtis AQGMD149 which is getting noisier and noisier on the spin cycle, the instructions say to check it is level, is there anything else I can check?
Yes you can check the play in the drum bearing, by '"rocking" the inner drum up/down against the outer, there should be very little play. If it moves a lot your drum bearing needs replacing. Also take lid off and physically wobble/apply pressure the outer drum and inspect to make sure the springs and dampers are not allowing excessive movement which would allow the drum to 'crash' around as it tries to spin. A bit like checking car suspension. DISCONNECT MAINS BEFORE REMOVING LID
Easier to do all that than explain!
dont forget to vote thanks
Feb 03, 2011 | Hotpoint Washing Machines
Washer sounds like it has rocks in it during spin cycle.
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 13, 2010 | Whirlpool GHW9100L Front Load Washer
Aquarious wd63 washing getting grey stains at end of wash cycle
Hi.
Can you tell me? Does the washing machine sound noisier than normal in spin? Does it sound rough?
The grey marks could be drum bearing wear causing oil from the bearing to enter the washing machine. Sometimes you may see grey or black dots on your clothing.
If this is the case then repair cost is typically around £100 depending on where you live.
Hope this helps
Aardvark Repairs
Nov 18, 2009 | Hotpoint Aquarius WD63 Front Load...
Spin cycle sounds like a jet plane, machine rocks and rolls. have had washer for one week.
washer was under warrenty. called whirlpool and a service man camed to the house.i did have a wonerful response from your site and will call the appliance service man, when washer is no longer under warrenty,who called me yesterday and gave me lots of information. thank you!
Aug 01, 2008 | Whirlpool Washing Machines
Hoover Nextra HNWF 3135 Front Load All-in-One Washer / Dryer Logo
225 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
