Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
Getting grey background on documents when copying
When i copy a document there is always a grey shaded background instead of a white background. apart from the fact this looks bad, it is using up all my black ink. can't seem to find the right button to hit to sort this out. can anybody help?
    Genius:
  • 2,985 Answers
If you are getting a grey back ground, this means you have the wrong setting- the scanner is seeing a 'photo' image. look at your controls for TEXT or LINE
Posted on May 09, 2007
Background on all white pages copies are gray
check printer settings or document settings back ground color settings
you can print a page color to any of the color bar settings so there is a setting that has been change to grey that is causing the problem
Dec 11, 2015 | Epson Stylus NX400 InkJet Printer
Xerox 4150 my paper is a light shade of grey, what can it be thank you
Giacomos,
Is the paper a shade of grey with no image? or is there an image with a grey background?
If there is a image with a grey background you should try a new toner module. If that doesn't resolve the issue, clean the xerographic drum, make 10 blank copies, if the cleaning doesn't resolve the issue than install a new xerographic module.
Hope this help.
Apr 05, 2011 | Xerox WorkCentre 4150 Black and White...
All of my copies and scans have a yellow background. This does not happen when I print a document directly.
You might be scanning and copying in full color even for regular documents. When you do this, it treats the document as a photograph or color document and therefore, the background, even if white, is scanned in as a bit yellow
Feb 28, 2011 | HP OfficeJet 7310 All-In-One InkJet...
I am trying to photocopy some pages of a document in black and white, but the copies come out as colored. what can I do in order to copy only black and white document?
A copy is a copy. you get what it sees.
I think you may be successful in scanning the picture to your hard drive, then print it in grey scale.
Feb 23, 2011 | Office Equipment & Supplies
Samsung 5935 copies black after changeing main board
Double check your cables/ harness especially to the document scanner section.
If you can print internal test pages ok, without the background, then a part of the document scanner is bad. The document scanner CCD JC96-05207A which is what reads the document.
Also, there is a "shading profile" adjustment, in case you just have a little grey background.
Whit
Item, Inc
Oct 27, 2010 | Samsung Office Equipment & Supplies
Is there a way to copy a document that has text on a colored piece of paper and have the background show up white and the text show up black instead of the background being grey and the text being black?
If the background color is light (yellow for example) you can probably play with the contrast and density settings to make it better, but otherwise you can't, unfortunately.
Sep 17, 2010 | Canon imageRUNNER C3220 Color Copier
Can the copy setting be defaulted to black and white document?
You can set it to B+W but it will revert to its default setting the next time you print.
Jun 30, 2009 | Lexmark X1150 All-In-One InkJet Printer
Printer leaves white vertical lines on document
I dont know what kind of copier you have but white vertical lines are virtually always caused by a dirty charge corona.There is usually a little plastic handle, blue, green or grey, that cleans the charge corona.pull it out ONCE, push it back in and try another copy.If you have an operators manual, it should have instructions for cleaning the charge corona.Good Luck, O'scope
Mar 27, 2009 | HP Office Equipment & Supplies
Scanned documents are very light
I have found that when scanning b/w documents, its helpful to start with a black and white copy, not a grayscale, pen written, or printed form a printer in grayscale mode copy, but a true black and white on the copier or fax copy. The scanner doesnt read shades of black so well and when scanning multiple page documents, my pixma tends to scan in lightly. I havent found a piece of software to do just this, batch darken what has been scanned (at least not for free). Copying before scanning is the work around. Hope this helps everyone who's had this problem. It also doesnt hurt to darken what your scanning down a notch when copying
Mar 21, 2008 | HP PSC1510 Printer/Scanner/Copier...
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
824 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
