Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Ovens Error code F1 on my oven and keeps beeping. Elements work but the oven won't
  • Anonymous Mar 13, 2014
    model 1008309, the oven won't come on; we are receiving error code F1
  • Anonymous Mar 24, 2014
    Oven was on Grill - suddenly started beeping F1 on screen displayed.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 68 Answers
The F1 error message usually means a short somewhere in the touch panel keyboard. There has been a rash of problems with keyboards. Most of the time there is a simple fix that can be used. Please see my post of April 14, 2007 in response to the problem posted by OVENMAN on April 12, 2007. There you will find a suggested solution which has helped hundreds of folks who have had error messages with GE and Kenmore ovens. If this fix doesn't work, you will need a replacement touch panel. There is no practical way to repair the keyboard in ovens.
Posted on Apr 17, 2007
How do I fix my oven door keeps locking up and F1 comes up and starts beeping
Here is a detailed description of this error code. Your control can be rebuilt by fixyourboard.com. See article here on Kenmore/GE F1 Error Code: Oven Failure After Self Clean and F1 Errors
Aug 27, 2015 | Ovens
F3e2 error
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
Oven is beeping and showing f1
Hello Charlie,
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
GENE
Nov 06, 2011 | Neff B1421 Electric Single Oven
F1 code GE profile convection self clean wall oven (95?) oven beeps F1 code oven works when it is on bake etc. when touch key are pressed it goes off but starts to beep again
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Sep 19, 2011 | Ovens
What does error code "F-1"
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced GENE
Sep 09, 2011 | Ovens
My top oven shows F1 and keeps beeping what is wrong?
Aug 18, 2011 | Frigidaire PLEB30T8A Electric Double Oven
F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
Jun 21, 2010 | GE Profile JT952 Electric Double Oven
Error code F1 keeps poppig up with abeep
Bad control or faulty wiring. Check connections to control, If that does not do it then replace control or send it off to be checked HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 28, 2010 | Ovens
Dacor oven beeping
Keeps flashing F1 and beeping help! how do I make it stop?
Apr 25, 2008 | Ovens
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
211 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
