Question about IBM ThinkPad A22m 2628 Notebook
Require bios password
After a few power blackouts, I swithched my laptop on and was slow in starting / stopped responding for a while and suddenly it had to reboot again.
I chose a few of the options 1. Start windows normally, 2. Safe mode, 3. Last known good configuration and it keeps comming back to temporary boot device.
A password is required for IBM bios set up utility which I do not know. Is there a solution to this problem? Can anyone help???
Ron
  • IBM Master
  • 32,281 Answers
IBM BIOS power on password, hard disk password are stored on an EEPROM chip and is almost impossible to crack. There are no backdoor passwords available.
These password protection are set to stop unauthorised access to data on the laptop, also moving the hard disk to another computer to read the data off the hard disk will not work either.
There is a way to hack into the EEPROM, but requires electronic hardware skills to build a reader device, a working computer and software.
For details on IBM password hack go to :-
www.sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Posted on Dec 26, 2008
Display driver stopped responding and has recovered error after freezed screen and blackout
Sounds like the GPU on your computer is having some issues. You might need to clean up the dust in your computer, as well as have the GPU's plug tightened on your laptop. If that's not the case you might have a nasty virus. Either way, it will require some work by someone with a technical background in laptops.
Feb 24, 2013 | Lenovo G550 PC Notebook
While updating bios for toshiba satellite L500 un plug the electricity switch laptop stop responding any thing. now how to install bios again
Well, sorry to hear about that. It is usually advised to keep the ac adapter plugged in for continouos power supply while performing BIOS update. Reason beyond is that, sudden power interruption or power shortage can totally damage your computer, allowing you not to use your computer anymore.
Please contact your laptop manufacturer for further assistance.
May 06, 2011 | Computers & Internet
Reset password cmos toshiba satellite A65-s1064
The only way to reset the cmos battery is to remove the battery from the back, open the bottom of the laptop and remove the button battery for 3-5 minutes. Replug in the battery and close up the case. Once completed, you can then create a new password.
Apr 08, 2011 | Toshiba Satellite A65-S1065 Notebook
How do i reset the bios password for my lenovo a310?
User passwords:
Power on
BIOS execution can be controlled by a Power On Password. This password is set in the BIOS Configuration screen, accessed by pressing the F1 key after pressing the power on switch to turn on the PC. If the person at the keyboard does not know the Power On Password, then BIOS execution halts.
Hard drive
The hard drive is controlled by the Hard Drive Password. After the Power On Password is entered, the person at the keyboard must be able to enter the Hard Drive Password, otherwise the disk drive will not spin up for use. Like the Power On Password, the Hard Drive Password is set in the BIOS configuration screen.
Administrative passwords:
Each of the two user passwords can be controlled by a Master or administrative password. If the administrative password is not set, then anyone who knows the user password can change it in the BIOS configuration screen. If the administration password is set, then it is impossible to reset the user password unless you know the administrative password. The Supervisor Password is the administrative password for the Power On Password. The Master Hard Drive Password controls the Hard Drive Password.
Password Recovery is a feature of Client Security Solution 6.0. This makes it possible for an end user to recover from the problem of "I forgot my Power On Password or Hard Drive Password."
c.gif fw.gif Client Security Solution
Mar 13, 2011 | Lenovo IdeaCentre A310 Laptop
Password solution for hp laptop
Every laptop has a different configuration and hardware setup so knowing what your brand and model is helps. Unless your computer is part of corporate inventory there is no reason to set a bios password. Check ebay for bios password as there are store fronts that can help you unlock it for a fee. Some places require you to send the machine in as it can be complicated to reset this security feature. If you want security then buy a notebook lock and put a power on, user and screen saver password but never enable a bios password.
Mar 11, 2010 | HP Pavilion dv6000z Notebook
Cmospwd does not work in resetting the HDD (BIOS?) pwd for a Gateway Solo 1450 with a Phoenix 4.5 Bios. I cannot get into DOS without the password. I have also tried all the backdoor passwords and they do...
u may need to "FLASH" BIOS with a new firmware/software that goes into the BIOS chip, that will require a hardware engineer to do, else to reset BIOS you can try removing the COMS battery from the Motherboard and reinstalling it after 2 - 3 hrs, also in that time keep pressing the power switch of you PC for few minutes without the power supply and without the power cable attached to the PC.
Dec 06, 2009 | Gateway Solo 1450 Notebook
Acer extenza 5620z mouse not responding as it should keyboard input slow and not responsive cannot input all digits of my password to get computer started
How long since you've run the computer? Might it be processing and update like when it reboots after installing a service pack? That might be making the computer run slow for a few minutes. Give it a little time to get started and see if your mouse and keyboard begin to work.
Jun 01, 2009 | Acer Extensa 5620-4020 Notebook
I lost my BIOS password
You will have to contact Gateway (or the manufacturer of the laptop) and ask them what you need to do to remove the bios password. Without an exact model number no one here can provide you with a 3rd party solution.
Most laptops made in the last few years require you to send the laptop back to the manufacturer and provide proof you are the origional owner of the laptop to remove a BIOS password as many BIOS passwords set up to prevent data theft.
Jan 19, 2009 | Gateway Computers & Internet
Removal of bios level password
Some laptops are passworded default at'oooo' or 'ooooo'. The bios re-set is the 'JBAT1' terminal, from jumpers 1-2 to 2-3 for a few seconds and then back to 1-2 again, but where the terminal is exactly on your motherboard i do not know. You may also try removing the bios didc shaped battery for 15 minutes or so, then replacing.
Jan 06, 2007 | Toshiba Satellite M105-S3001 Notebook
IBM ThinkPad A22m 2628 Notebook Logo
573 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
