In system Taskmanager is in diable how to sovle ?
I prees "contl+alt+num lock" at a time but the dilouge box shows "...
""""The ask manager has been disabled by your adminestrator""" ...
  • ramu s Jan 05, 2009
    not open taskmanager
    Sergeant:
  • 183 Answers
This happens due to spy ware / virus
so you need to get rid off them,
To active your task manager:
Click Start
• Click Run
• Enter gpedit.msc in the Open box and click OK
• In the Group Policy settings window
o Select User Configuration
o Select Administrative Templates
o Select System
o Select Ctrl+Alt+Delete options
o Select Remove Task Manager
o Double-click the Remove Task Manager option
and choose Not configured option then click on apply to ok.
if even you are not able access your Run command then follow the following option:
Go to the this web site
http://www.kellys-korner-xp.com/xp_tweaks.htm
scroll down until you see 113 number
one you reach on this number click on "Enable" to the task manager
and save it on your deskto
you are done with downloading then double click on it and follow the given instruction on displayed pane.
now you should be good.
Note: you must run full virus(up-to-date one) scan once you enable yoru taks manager because this happens due to virus, maleware, spy ware and trajons.
Thanks
Posted on Dec 26, 2008
Tip
Amazing shortcuts
Getting used to using your keyboard exclusively and leaving your mouse behind will make you much more efficient at performing any task on any Windows system. I use the following keyboard shortcuts every day:<br /><br />Windows key + R = Run menu<br /><br />This is usually followed by:<br />cmd = Command Prompt<br />iexplore + "web address" = Internet Explorer<br />compmgmt.msc = Computer Management<br />dhcpmgmt.msc = DHCP Management<br />dnsmgmt.msc = DNS Management<br />services.msc = Services<br />eventvwr = Event Viewer<br />dsa.msc = Active Directory Users and Computers<br />dssite.msc = Active Directory Sites and Services<br />Windows key + E = Explorer<br /><br />ALT + Tab = Switch between windows<br /><br />ALT, Space, X = Maximize window<br /><br />CTRL + Shift + Esc = Task Manager<br /><br />Windows key + Break = System properties<br /><br />Windows key + F = Search<br /><br />Windows key + D = Hide/Display all windows<br /><br />CTRL + C = copy<br /><br />CTRL + X = cut<br /><br />CTRL + V = paste<br /><br />Also don't forget about the "Right-click" key next to the right Windows key on your keyboard. Using the arrows and that key can get just about anything done once you've opened up any program.<br /><br /><br />Keyboard Shortcuts<br /><br />[Alt] and [Esc] Switch between running applications<br /><br />[Alt] and letter Select menu item by underlined letter<br /><br />[Ctrl] and [Esc] Open Program Menu<br /><br />[Ctrl] and [F4] Close active document or group windows (does not work with some applications)<br /><br />[Alt] and [F4] Quit active application or close current window<br /><br />[Alt] and [-] Open Control menu for active document<br /><br />Ctrl] Lft., Rt. arrow Move cursor forward or back one word<br /><br />Ctrl] Up, Down arrow Move cursor forward or back one paragraph<br /><br />[F1] Open Help for active application<br /><br />Windows+M Minimize all open windows<br /><br />Shift+Windows+M Undo minimize all open windows<br /><br />Windows+F1 Open Windows Help<br /><br />Windows+Tab Cycle through the Taskbar buttons<br /><br />Windows+Break Open the System Properties dialog box<br /><br /><br /><br />acessability shortcuts<br /><br />Right SHIFT for eight seconds........ Switch FilterKeys on and off.<br /><br />Left ALT +left SHIFT +PRINT SCREEN....... Switch High Contrast on and off.<br /><br />Left ALT +left SHIFT +NUM LOCK....... Switch MouseKeys on and off.<br /><br />SHIFT....... five times Switch StickyKeys on and off.<br /><br />NUM LOCK...... for five seconds Switch ToggleKeys on and off.<br /><br />explorer shortcuts<br /><br />END....... Display the bottom of the active window.<br /><br />HOME....... Display the top of the active window.<br /><br />NUM LOCK+ASTERISK....... on numeric keypad (*) Display all subfolders under the selected folder.<br /><br />NUM LOCK+PLUS SIGN....... on numeric keypad (+) Display the contents of the selected folder.<br /><br />NUM LOCK+MINUS SIGN....... on numeric keypad (-) Collapse the selected folder.<br /><br />LEFT ARROW...... Collapse current selection if it's expanded, or select parent folder.<br /><br />RIGHT ARROW....... Display current selection if it's collapsed, or select first subfolder.<br /><br /><br /><br /><br />Type the following commands in your Run Box (Windows Key + R) or Start Run<br /><br />devmgmt.msc = Device Manager<br />msinfo32 = System Information<br />cleanmgr = Disk Cleanup<br />ntbackup = Backup or Restore Wizard (Windows Backup Utility)<br />mmc = Microsoft Management Console<br />excel = Microsoft Excel (If Installed)<br />msaccess = Microsoft Access (If Installed)<br />powerpnt = Microsoft PowerPoint (If Installed)<br />winword = Microsoft Word (If Installed)<br />frontpg = Microsoft FrontPage (If Installed)<br />notepad = Notepad<br />wordpad = WordPad<br />calc = Calculator<br />msmsgs = Windows Messenger<br />mspaint = Microsoft Paint<br />wmplayer = Windows Media Player<br />rstrui = System Restore<br />netscp6 = Netscape 6.x<br />netscp = Netscape 7.x<br />netscape = Netscape 4.x<br />waol = America Online<br />control = Opens the Control Panel<br />control printers = Opens the Printers Dialog<br /><br /><br />internetbrowser<br /><br />type in u're adress "google", then press [Right CTRL] and [Enter]<br />add www. and .com to word and go to it<br /><br /><br />For Windows XP:<br /><br />Copy. CTRL+C<br />Cut. CTRL+X<br />Paste. CTRL+V<br />Undo. CTRL+Z<br />Delete. DELETE<br />Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE<br />Copy selected item. CTRL while dragging an item<br />Create shortcut to selected item. CTRL+SHIFT while dragging an item<br />Rename selected item. F2<br />Move the insertion point to the beginning of the next word. CTRL+RIGHT ARROW<br />Move the insertion point to the beginning of the previous word. CTRL+LEFT ARROW<br />Move the insertion point to the beginning of the next paragraph. CTRL+DOWN ARROW<br />Move the insertion point to the beginning of the previous paragraph. CTRL+UP ARROW<br />Highlight a block of text. CTRL+SHIFT with any of the arrow keys<br />Select more than one item in a window or on the desktop, or select text within a document. SHIFT with any of the arrow keys<br />Select all. CTRL+A<br />Search for a file or folder. F3<br />View properties for the selected item. ALT+ENTER<br />Close the active item, or quit the active program. ALT+F4<br />Opens the shortcut menu for the active window. ALT+SPACEBAR<br />Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4<br />Switch between open items. ALT+TAB<br />Cycle through items in the order they were opened. ALT+ESC<br />Cycle through screen elements in a window or on the desktop. F6<br />Display the Address bar list in My Computer or Windows Explorer. F4<br />Display the shortcut menu for the selected item. SHIFT+F10<br />Display the System menu for the active window. ALT+SPACEBAR<br />Display the Start menu. CTRL+ESC<br />Display the corresponding menu. ALT+Underlined letter in a menu name<br />Carry out the corresponding command. Underlined letter in a command name on an open menu<br />Activate the menu bar in the active program. F10<br />Open the next menu to the right, or open a submenu. RIGHT ARROW<br />Open the next menu to the left, or close a submenu. LEFT ARROW<br />Refresh the active window. F5<br />View the folder one level up in My Computer or Windows Explorer. BACKSPACE<br />Cancel the current task. ESC<br />SHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing.<br /><br />Use these keyboard shortcuts for dialog boxes:<br /><br />To Press<br />Move forward through tabs. CTRL+TAB<br />Move backward through tabs. CTRL+SHIFT+TAB<br />Move forward through options. TAB<br />Move backward through options. SHIFT+TAB<br />Carry out the corresponding command or select the corresponding option. ALT+Underlined letter<br />Carry out the command for the active option or button. ENTER<br />Select or clear the check box if the active option is a check box. SPACEBAR<br />Select a button if the active option is a group of option buttons. Arrow keys<br />Display Help. F1<br />Display the items in the active list. F4<br />Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE<br /><br />If you have a Microsoft Natural Keyboard, or any other compatible keyboard that includes the Windows logo key and the Application key , you can use these keyboard shortcuts:<br /><br /><br />Display or hide the Start menu. WIN Key<br />Display the System Properties dialog box. WIN Key+BREAK<br />Show the desktop. WIN Key+D<br />Minimize all windows. WIN Key+M<br />Restores minimized windows. WIN Key+Shift+M<br />Open My Computer. WIN Key+E<br />Search for a file or folder. WIN Key+F<br />Search for computers. CTRL+WIN Key+F<br />Display Windows Help. WIN Key+F1<br />Lock your computer if you are connected to a network domain, or switch users if you are not connected to a network domain. WIN Key+ L<br />Open the Run dialog box. WIN Key+R<br />Open Utility Manager. WIN Key+U<br /><br />accessibility keyboard shortcuts:<br /><br />Switch FilterKeys on and off. Right SHIFT for eight seconds<br />Switch High Contrast on and off. Left ALT+left SHIFT+PRINT SCREEN<br />Switch MouseKeys on and off. Left ALT +left SHIFT +NUM LOCK<br />Switch StickyKeys on and off. SHIFT five times<br />Switch ToggleKeys on and off. NUM LOCK for five seconds<br />Open Utility Manager. WIN Key+U<br /><br />shortcuts you can use with Windows Explorer:<br /><br /><br />Display the bottom of the active window. END<br />Display the top of the active window. HOME<br />Display all subfolders under the selected folder. NUM LOCK+ASTERISK on numeric keypad (*)<br />Display the contents of the selected folder. NUM LOCK+PLUS SIGN on numeric keypad (+)<br />Collapse the selected folder. NUM LOCK+MINUS SIGN on numeric keypad (-)<br />Collapse current selection if it's expanded, or select parent folder. LEFT ARROW<br />Display current selection if it's collapsed, or select first subfolder. RIGHT ARROW<br /><br />
on Jan 10, 2011 | Computers & Internet
Tip
Some Keyboard Shortcuts
Keyboard Shortcuts
Accessibility Shortcuts
explorer shortcuts
notepad = Notepad
wordpad = WordPad
calc = Calculator
Miscellaneous
on Dec 30, 2009 | Computers & Internet
My mom's computers task manager has been disabled and avg says no active components nor can I uninstall avg
go to start->run->gpedit.msc->user configuration->administrative templates->system->ctrl+alt+del option->remove task maneger->disabled
Sep 12, 2009 | Microsoft Windows XP Home Edition
How we will enable the task manager in windows xp
there are 2 ways..
1. just right click to you task bar (shown below) then click task manager.
20fd7c1.jpg 2. press ctrl alt del simultaneously, then click on task manager..
cheers!
Jul 11, 2009 | Microsoft Windows XP Professional SP2 Full...
Tip
Windows keyboard shortcuts
CTRL + C = copy
CTRL + X = cut
CTRL + V = paste
Keyboard Shortcuts
explorer shortcuts
notepad = Notepad
wordpad = WordPad
calc = Calculator
internetbrowser
For Windows XP:
Copy. CTRL+C
Cut. CTRL+X
Paste. CTRL+V
Undo. CTRL+Z
Delete. DELETE
Select all. CTRL+A
To Press
Display Help. F1
on Dec 24, 2009 | Computers & Internet
Desktop does not show after the logon
1.This is windows explorer.exe problem
when u r logon press Ctrl+Alt+Delete
taskmanager is open click applications > new task .write explorer.exe then click ok
show ur desktop icon
2. This is windows explorer.exe problem
taskmanager is open click new . browse click desktop and right click my computer click manage local user and groups then right hand side right click user and create new user account
then restart ur system
login ur new account
May 14, 2009 | Microsoft Windows Vista Ultimate Edition
My task manager has been disabled due to virus attack. help me
There is a registry hack to enable or disable Windows NT TaskManager. The same registry hack applies to Windows 2000 and Windows XP. Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Type: REG_DWORD
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
As part of the enhanced management available in Windows 2000 and Windows XP, rather than risking a registry change, as an administrator you can enable or disable Windows 2000 Pro or Windows XP Pro's TaskManager using Group Policy Editor. This can be applied to the local policy. Note: if you are trying to override your organizations group policy, you can't. As soon as you re-authenticate to the domain, the domain or OU Group Policy will rewrite the registry setting. But if the TaskManager was accidently disabled or you need to control this item for a set of standalone boxes this is for you:
  • Click Start
  • Click Run
    • Select User Configuration
    • Select Administrative Templates
    • Select System
    • Select Ctrl+Alt+Delete options
    • Select Remove Task Manager
    • Double-click the Remove Task Manager option
And as I mentioned above, since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
Mar 23, 2009 | Internet Grisoft AVG Security Full...
Taskmanager & regedit
When you press Ctrl + alt +delete, the task manager does not appear? Try right clicking on your desktop tool bar and clicking task manager: For regedit click Start > run and type regedit
Mar 26, 2008 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
