Question about Sony KP-53S65 53" Rear Projection Television
No picture/vertical lines on screen
While watching TV, vertical colored lines (2 sets...pink, white, light blue on the left third of the screen and red, pink, green, dark blue on the right third of the screen). After awhile, the screen went blue...no picture at all and the lines are still visible. There is sound. Any ideas what may be the problem? Thanks.
  • Anonymous Mar 19, 2014
    seems to have 4 large green line vertical and circles inside of them
  • Anonymous Mar 21, 2014
    My TV has vertical white lines on the screen when watching shows and sometimes it doesn't.
    Sergeant:
    Champion:
  • 375 Answers
It's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Posted on Aug 18, 2007
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
Poor Picture
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the curser (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It taked time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
Hope this help....
Jun 26, 2010 | Sony Bravia KDL-32V4000 32 in. LCD TV
My five year old Toshiba 57H84 rear projection TV has a pink tinted screen when you first turn it on, then after it warms up, the colors are all fine but then the picture has evenly spaced blue tinted...
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 30, 2010 | Toshiba 57H84 57" Rear Projection...
Pink discoloration and vertical lines in light areas
Possibly a form of flare caused by including the light source in the image.
Jun 25, 2017 | Olympus FE-280 Digital Camera
Panasonic PT-47X54J Not working
I can't tell you how to fix this set, but I can tell you that its not a "lamp" issue as this doesn't have a lamp. Its a 3 picture tube projection TV. the three tubes are in a red green blue format, and average about $175 for each one, not including the labor to install them. your problem, may not be the tube, but just a power supply problem, but there is a chance it is.
Nov 21, 2008 | Panasonic PT-47X54 47" Rear Projection...
Samsung HLN617W
nope you just got blue screen on look in user manual and find how to turn it off - inside projection TV there are 3 bulbs full of special liquid red blue green
Jul 03, 2008 | Televison & Video
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
TV dropped
That's still repairable here some tips need to consider as follow:
1) Intermittent loss of syncronisation, both horizontal and vertical
The surface mounted power transistor on the teletext module requires resoldering. As there is evidence of scorching on the board the use of a more substantial component would be indicated perhaps with small heatsink
2) Picture displaced vertically, picture too high or low
This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
3) Vertical line at the left of the picture
Replace L506 on A board, replacement part number 1-407-366-00
4) Problems with screen size
Look out for 2 x 2.2uF electrolytics (sometimes red in color)
5) Vertical height oversize
The eprom was found to be faulty (nvm)
Please let me know any update.
Nov 28, 2007 | RCA F27676BC TV
Sony KP-53S65 53" Rear Projection Television Logo
464 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
