Question about Lenovo 3000V200 Laptop
The images appears on my Lenovo laptop are not clear
Display is not clear and comes with faded colors and pixels
    Problem Solver:
  • 17 Answers
The culprit, in all probability, must be your graphics card. Install the latest drivers using the CD that was provided by Lenovo when you bought the laptop. This should solve the problem.
In case the problem persists, you may have to get the laptop's screen checked by an authorized Lenovo dealer.
I hope that this has been of some help!
Posted on Dec 26, 2008
Error ce40
Read this
http://www.copytechnet.com/forums/toshiba/78223-toshiba-estudio-281c-error-ce40-total-491000-a.html
and this
PRINTERCAT : Hi this is Michelle and i will be assisting you. PRINTERCAT : Error CE40:CE40] Image quality control test pattern abnormality(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color. PRINTERCAT : (2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" tocheck if the low-density pattern abnormality occurs for each color. The values under 320 for Y, Mand C, and under 220 for K are defined as low-density pattern abnormality. PRINTERCAT : (3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" tocheck if the high-density pattern abnormality occurs for each color and identify the color whichpattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality. PRINTERCAT : (4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "0" (Invalid). PRINTERCAT : (5) Perform "Enforced performing of image quality open-loop control (05-394)". PRINTERCAT : (6) Output the image quality control test pattern (04-270) more than one time and check the patch ofthe color identified in step (3) to see if the image is abnormal (Note). PRINTERCAT : (7) Replace the image quality sensor. PRINTERCAT : (8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "1" (Valid). PRINTERCAT : (9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it iscompleted normally. (Error [CE40] does not appear.) Then perform "Automatic gamma adjustment"( Chapter 3.5.1 and 3.6.1).(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to576)". PRINTERCAT : Please note:Abnormal image:Blank print, Solid print, White banding, Color banding, White spots, Poor transfer, Uneven imagedensity, Faded image (low density), Uneven light distribution, Blotched image.''''''''''??320 or above (Y, M and C)220 or above (K)''??Under 320 (Y, M and C)Under 220 (K)Low-density pattern abnormalityCheck the transfer belt. If the cleaning is poor, correct thetransfer belt around its cleaning blade.'??To (9)''''''??Normal '??AbnormalCorrect the items related to the image.
Mar 24, 2016 | Office Equipment & Supplies
I have a 42 in Sanyo DP42647. If there is something like a logo or words that stay on the screen for more than a few seconds it looks like it is burned in. It eventually fades but by the time one fades...
Cause of screen burn typically is pixels are no longer showing full range of color. Typically a shop would cycle screens or blocks of very bright colors alternating colors to unstick any pixels not showing full range of some color. Setting tv back to factory default then adjusting could help also turning up brightness. Change color settings from cool to warm could help. Could also be a refresh rate. Verify tv is set to display at same rate as input device like cable box set to output 1080i while tv native is 720p. Just because there is a pic doesn't mean they are synced.if tv has to convert signal from 1080i to 540i then resize to fit 720p tv it may slow refresh rate tv is trying to display progressive scan image but not enough data is coming in so it redisplays previous image on every other line.and new data on every other line.
solution is check output video settings of source to match native resolution of tv. Hd cable box this is common as tech sets output to high resolution 1080i most inexpensive tv are 720p
Mar 14, 2014 | Sanyo 42 in. LCD TV
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Colour setting keeps reverting from 32 bits to 8 bits
Turn the laptop on and hold down the "Fn" key on the laptop's keyboard.
Tap the arrow key that has a picture of an open sun to make the laptop screen brighter.
The laptop will automatically save the adjustments after you release the "Fn" key.
Tap the arrow key that has a picture of a filled-in sun to make the laptop screen darker.
Screen Resolution
Click the "Start" menu. Click "Settings" and "Control Panel."
Choose "Display" and "Settings" in Windows 98, ME or XP. In Windows Vista, click "Appearance" and "Adjust Screen Resolution."
Click on the resolution bar and slide it to the right to lower the screen's resolution and to the left to raise the screen's resolution.
The optimum screen resolution usually depends on the size of the laptop screen.
The recommended resolution for a 15-inch screen is 1024 x 768, 17- to 19-inch screen is 1280 x 1024, and 20-inch screens is 1600 x 1200.
However, you can adjust the resolution to your personal preference.
Click ""Apply to see how the resolution looks on the laptop's monitor.
Click "OK" to save the resolution settings.
Color Setting
Click "Colors." Choose 32-bit for a high color-pixel ratio that will make the colors brighter and bring out image details.
Choose 24-bit for a medium color-pixel ratio if the screen is too bright or if images are somewhat distorted.
Some older laptops have a 16-bit color setting, but this setting is no longer recommended as it will distort images and text.
Always Click "Apply" to see how the color setting looks on the laptop's monitor.
Click "OK" to save the color settings
hope this helps
Oct 14, 2012 | Computers & Internet
Blotted screen in my hp laptop
1.Locate the problem pixel. Display a true black image on your HP's monitor. You can do this by playing a DVD on your HP laptop, and pausing it on the black screen just before the movie starts. Once you bring up a black image on screen, the stuck or dead pixel should be visible.
2.Try applying direct pressure to the problematic pixel. After you've located it, turn off your laptop. Place a soft cloth or rag over the pixel to avoid damaging your screen. A soft chamois works well. Using the tip of a pen, apply gentle pressure to the pixel. You don't need to press hard, as too much pressure can crack or scratch your screen. While applying pressure, boot up your laptop. This should force the pixel to begin working properly.
3.Tap the pixel. With your Toshiba booted up and an image on the screen, gently tap the pixel with the rounded end of a pen cap. Tap hard just hard enough to see a small white flash on the screen. Tap your HP's screen until the pixel begins working properly.
4.Download a stuck pixel program. Several programs, including JScreenFix, UDPix and Pixel Protector, are available for download and can help fix a malfunctioning pixel. These programs display rapidly changing colors and images on your screen. The flashing colors and images can force the pixel to begin functioning properly.
5.Contact HP. If none of the above methods work, your screen may have a pixel that is truly dead. If that's the case, the only option is to replace the display completely. Contact HP customer support at www.hp.com to find an authorized repair service near you.
Sep 19, 2011 | Computers & Internet
My laptop symptoms are faded lines, fonts not crisp, various shades of the same color in the lines. I have replaced the monitor but that did not ellimnate the problem. I have a Dell Inspiron...
  1. Turn off the Computer.
  2. Hold Down the FN Key on the keyboard and press the power button, then Release both buttons.
  3. This should start your PSA Diagnostics
  4. You will see two color bar screens appear in succession, on the second color bar screen there is a message asking you if you saw the color bars. Press the N key for No to start the LCD BIST.
  5. The LCD BIST will run several full colored screens in succession with a beeping sound.
  6. Check for any lines, distortions, or abnormalities you were seeing in the Operating System here.
  7. Once the Diagnostics are finished you will see an Error message appear, this is Normal. Press the N Key to end the Diagnostics or Press the Y Key to continue the PSA Diagnostics.
  8. If no sysmptoms were displayed please continue on to the next step, if they were displayed please go to the last step.
An out of date Video Driver or BIOS can cause abnormal screen issues.
Visit the Dell Drivers and Downloads website and input your Service Tag to get updates specific to your computer.
If you need assistance in Downloading and Installing Drivers or BIOS. Click here for Installation Instructions
Click Here to Launch the Dell Drivers and Downloads Website
Dec 03, 2010 | Dell Inspiron 6000 Notebook
My dell latitude D830 display colors have faded.An
I would check your graphics card control panel. You may have (or someone else) set the contrast or some other setting to low or high. If you are using nvidia you can run the optimization wizard.
Mar 12, 2009 | Dell Latitude D830 Notebook
Is my Camera broken?????
u need to set ur cam in the factory defaults^^
Aug 13, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
DISPLAY
they will have a low resolution . this is not computers problem try to zoom out hat pictures
Jan 22, 2008 | Computers & Internet
Pixel color fade
You are about reade to have a scan ic failure.Try to get it to a repair center asap.Have them replace the top 2 scan ic's
Jan 28, 2007 | Pioneer PureVision PDP-5030HD 50 in....
Lenovo 3000V200 Laptop Logo
81 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
