Question about Adobe Photoshop CS2 for PC
Black Background Around Layer Window
I hope I can explain this well enough for someone to help.
When I open a new document in Photoshop CS2, it comes up as normal. However, if I expand the window by dragging it out so I can view the edges of the work area there is a black background behind the working area of the document. In other words, if I open a new document using a black background, I can't see the document because it is black on black.
How do I get rid of this black background?
  • m_l_lane Dec 26, 2008
    I tried using the paint bucket several times to change the background with no luck...just didn't do it while holding down the shift key! Thanks so much for your help!
  • Anonymous Mar 25, 2009
    same prob here, fixed with the solution given, thanks!
    Novelist:
  • 121 Answers
The expanded area outside your document is called the "workspace". You can change this to any color you want by following these steps:
1) Select the color you want, this will make the selected color into your Foreground color swatch.
2) In the tool palette select the Paint Bucket tool (this tool shares the same space in the tool palette as the gradient tool).
3) Make sure your window is large enough for you to see the workspace.
4) Hold down the Shift key and at the same time click the paint bucket in the workspace.
This will change the color of the workspace to the color you chose as your foreground color in step 1.
Posted on Dec 26, 2008
  • jcdill
    jcdill Dec 26, 2008
    Then try resetting your preferences file. See this page at Adobe.com as there are several different ways to reset this file.
I have a document open, but I can't see it.I am able to save it and such, but I can't see it so therefore I can't edit the image in any way.
ok my first question would be do you have java script enabled , go to tools internet options , options2) check you preferances for vewinf pics or attachments.
my guess is that the java script is not enabled
additionally
Solution: Install the Photoshop CS2 9.0.1 update.
Download and install the update from the Adobe website at www.adobe.com/downloads .
Background information
Photoshop CS2 cannot open TIFF, PSB and PDF files larger than 2 GB if they were saved in Photoshop without compression or if they contain a pattern layer style or a pattern content layer. The 9.0.1 update allows you to reopen these files in Photoshop CS2.
Mel
Jun 07, 2010 | Adobe Photoshop CS2 for PC
Tip
How to turn your photo into cartoon
If you have Photoshop, you can also use it to turn photo into cartoon effect in your Windows 10/8/7 or Mac (macOS High Sierra included). The photo-to-cartoon effect in Photoshop is a popular effect and surprisingly easy to achieve. Here in this tutorial, you can learn to turn photos to cartoons using an assortment of filters and simple brushwork.
Step 1. Open Photoshop and add your photo into the program. Press Cmd/Ctrl+J to duplicate the background layer, then Cmd/Ctrl+ Shift+U to remove color. Press Cmd/Ctrl+J again, and then Cmd/Ctrl+I to invert the tones. Change the Blend Mode to Color Dodge. Go to Filter>Blur>Gaussian Blur. Set Radius to 8px and Click OK.
Step 2. Press Cmd/Ctrl+Shift+Alt+E to merge a new layer, then Cmd/Ctrl+J to copy it. Set the Blend Mode to Multiply, then copy the layer three times to make the lines stronger. Highlight the top layer, Shift+click the layer above the background and hit Cmd/Ctrl+E to merge. Rename the layer Sketch.
Step 3. Make a new layer, drag it below the sketch layer, then go to Edit>Fill Layer. Set Use to White and click OK. Next highlight the sketch layer and click the Add Layer Mask icon in the Layers Panel. Grab the Brush tool and set color to black, then paint to tidy up the skin, clothes and hair.
Step 4. Change the Blend Mode of the sketch layer to Multiply, then make a new layer and drag it below. Grab the Brush tool and choose a color for the skin, then begin painting. Make more new layers and paint different colors for the hair, eyes, mouth and jeans.
Step 5. Duplicate the background layer. Drag it to below the sketch layer. Go to Filter>Brush Strokes>Ink Outlines. Leave the default settings and hit OK. Alt-click the Add Layer Mask icon to add a mask that hides the layer, then paint with white to reveal the tattoos. Next highlight the white layer.
Step 6. Go to Filter>Textures>Grain. Set Grain Type: Vertical, Intensity 100, Contrast 0. Go to Filter>Blur>Gaussian Blur. Set Radius 4px. Go to Filter>Distort>Polar Coordinates and pick Rectangular to Polar. Hit Cmd/Ctrl+U, check Colorize, set Hue 211. Paint white over any lines that show through.
If you think it is difficult for you to turn photo into cartoon with Photoshop. You can also find other way in the detailed article.
Photo to Carton How to Turn Photo into Cartoon Easily and Effectively
on May 08, 2018 | Adobe Photoshop CS2 for PC
Tip
Remove complicated backgrounds from images using Adobe Photoshop
If you are a Professional user and can afford it I would use the Primatte Chromokey from Digital Anarchy it excels at removing just about any background even from flyway strands of hair.
Try the demo version first then decide v3.0 now costs $299 (£198)
If you can't afford it and you have only a two-tone background use either Photoshop's own extract filter on CS2 version that does a good job about 70% removal, you will need to use paths and selections to remove the rest.
OR this method below really does work.
1. Open your image
2. Double Click your background layer.
3. Press Ctrl+Shift+N to make new layer.
4. Fill the new layer with any color you like.
5. Move your 'layer 0' up, so now 'layer 0' is on the top layer
6. Make selection with pen.
7. Press Ctrl+Enter to make selection.
8. Click ad mask layer icon.
9. Ctrl+J to duplicate the layer
10. Click the mask icon.
11. Ctrl+i to invert the mask selection.
12. Click your mask icon on the layer palette.
13. Brush with black.
14. Click your 'layer 0' mask icon.
15. Brush with white to reveal the image.
16. Use shift to Select the two layer.
17. Ctrl+G to group it
Other Masking Plugins for Photoshop
You can also create a fairly decent removal using Extensis Mask Pro it has a great interface and makes short work of any complex masking situation its easier to use than the Primatte Chromokey and is just as good if not better than Procreate Knockout
on Mar 08, 2010 | Adobe Photoshop CS2 for PC
Even with standard window mode on I get a black frame around file
Try this:
  • Quit Photoshop
  • Rename your Photoshop Preferences file in Library > Preferences
  • Start Photoshop
Your settings will all be rest to the factory default. If you don't like this, you can always rename your Preferences file back to the original name.
Aug 03, 2009 | Adobe Photoshop Extended CS3 ( Macintosh )...
How to cut clear hair in photoshop
Sounds like you want to make a hair mask. If your subject is on a simple back ground, go into your color channels and duplicate the one that is the darkest for the hair. Apply levels to darken even more and then fill in other non hair areas of the head and body with black. Get in close and remove any artifacting around the edges of the hair so it is clearly black and white, no grey or at least try not to have any grey.
Inverse the tones so the hair becomes white and the background black. Make a selection and use it to lift your subject off the background. If you have any fuzzy areas, you can lock the layer and clone hair into them and/or remove them with the eraser or use layer mask.
Jun 15, 2009 | Adobe Photoshop CS2 for PC
Crop the photo in diffeent shaps like heart.
The crop tool will not let you crop in shapes like elements cookie cutter tool will. However, there is a work around to do what you want to do which indecently is the same as you would have to do in Photoshop CS4.
1. Create a new document file or press Ctrl + N.
2. Open an image you want to crop.
3. Press Ctrl + A then Ctrl + C to copy the image.
4. Select the new document file you created and press Ctrl + V to paste the new image in a new layer.
5. Select the Rectangle tool or press U for the hotkey.
6. Move the mouse over to the Rectangle Tool and hold down the left mouse button and select Custom Shape Tool.
7. At the top of the menu you will see a Shape: icon with a pull down option. Left Click on the arrow to expand the window to select the shape you want. If you want more shapes to choose from when the shape window is displayed click on the arrowhead with a circle around it and select a new library or all.
8. Use the mouse to draw the shape to the size and location you desire.
9. The shape will be in a new layer with a mask which will cover the image. Hold down the Ctrl key and left click on the Shape 1 layer in the layer window. This will mask the shape and only the shape.
10. Press Ctrl +Shift + I to invert the mask selection.
11. Use the Select pull down menu to Feather, Modify, Contract, Expand and Border if you want apply those effects around the edge of the mask.
12. In the Layer window click on the eye next to the Shape 1 layer to hide the image.
13. Select the image layer you want to crop and press delete which will delete everything outside the custom shape you created.
14. Do not forget you can right click on the image layer and select Blending Option to add drop shadows and other special effects for the cropped shape.
Jun 05, 2009 | Adobe Photoshop 7.0 for PC
Layers
use the pen tool to draw a selection around the faces. Once done convert that into a selection under the layers palette button to convert. copy and past into a new document or layer.
Jul 17, 2008 | Adobe Computers & Internet
My type tools does not work.
Perhaps you've got the text color set to the same color as your background (both white). With the text tool selected, left-click on your document once, then left-click on the 'set the text color' box in your toolbar. Choose a color that is dark enough to show up in your screen. Make sure your text size is large enough to show at your current screen resolution.
May 29, 2008 | Adobe Photoshop CS2 for PC
Text in CS2
Dear Roan,
It may be because your text is behind the background. That's what was happening to lots of people trying to use Photoshop CS2. Try going to Layer--then Arrange--then bring text to front.
This has worked for most of the people has fixed the problem. Hope thats helpful. If you still have problems you can go read the forums and also can access the help file in software's Help menu.
Nov 23, 2007 | Adobe Photoshop 7.0 for PC
Adobe Photoshop CS2 for PC Logo
115 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
