My HP Officejet 4355 keep show the error of "Paper Jam, clear jam and then press OK", but see no paper at all in the printer. I tried to restart, placed paper into the feeder, but nothing is working......
  • 39 Answers
Have you tried this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00621882&lc=en&dlc=en&cc=us&lang=en&rule=8836&product=1138373
if you satisfied, pls give me a fixya rating ;)
Posted on Dec 26, 2008
My computer says there is a paper jam but there is none on the display screen. I tried opening it up but it doesn't work, my computer still says it has a paper jam. My printer is HP Officejet 4355. My...
Turn the printer off.
Disconnect the AC power.
Disconnect the "data" cable from the computer.
Reconnect the AC power.
Turn the printer on.
Press the "paper-feed" button, to try to feed a few sheets of paper through the paper.
Reconnect the "data" cable.
If this fails, take the printer to a qualified technician, for professional trouble-shooting.
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
PAPER JAM / CARRAGE JAM
Hello there this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 05, 2010 | HP OfficeJet 6310 All-in-One Printer...
4355 papar jam error solution
THE PRINTERS MANUFACTURED BY HP ARE HAVING THIS PROBLEM IN COMMON ALL THE WAY. WE SHOULD TAKE FOLLOWING PRISCPRIPTIONS WHILE RUNNING THESE PRINTERS
1. LOAD PAPERS AT SOME DISTANCE FROM THE PAPER LIFTER THAT MEANS KEEP THE PAPERS SOMEWHAT BEHING YOU KEEP THEM
2. WHEN THE PRINTERS ARE OLD THEM GET THEIR PAPER LIFTER CHECKED AND TRY TO PRINT ONE PAPER AT A TIME.
THANKS
PROUD TO BE AN INDIAN
KAMAL DEV JHALLI
HAVE A GOOD DAY
Nov 25, 2009 | HP Officejet 4355 All-In-One InkJet...
Paper jam
Found this on the HP Web site.
Issue:
The product stops printing and the error message 'Paper Jam: Clear jam, and then press OK ' displays on the product.
HP Support
GOOD LUCK!
Oct 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Clear Paper Jam, then Press OK
Have you checked the access door in the rear of the machine?
Jan 05, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Carriage Jam -- Paper Jam
I have serviced an officejet pro L7580 which was showing a paper jam error when powered on. our customer had had a paper jam and removed the paper . I found small peices of paper in the pick up assy gears. If you remove the rear door, you need to check the 2 small white gears on the left. turn the roller slowly by hand and clear any paper stuck between the teeth. (they may be very small).
after doing this....no more paper jam errors for me!
Jun 18, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
288 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
