Question about Panasonic Lumix DMC-FZ18K Digital Camera
Kodak memory card 4GB SDHC not connecting to my pc.
I have a printer that also reads memory cards. Well today I got my new card and took a toad of pictures of my day and I tried to upload it and my printer didn't even notice it was then. I have the same card just a 256MB card and it connects fine. What is going on?
  • 1 more comment
  • Nycki-moo Dec 26, 2008
    lexmark all in one I am sorry i don't know much more about it but it has a flat scanner too on it >.<
    Thank you jcdill I will try that now ^^
  • jcdill
    jcdill May 11, 2010
    What is the make and model of your printer?
    Novelist:
  • 121 Answers
The problem may be that your printer doesn't support memory cards this big - this is often the case with older printers. Two ways around this are:
1) Use the data cable for your camera and transfer the images off the camera (with the card in the camera).
2) Buy an external card reader you plug into a USB port on your computer. These are inexpensive (under $20) and you can buy them at most camera and computer stores.
Posted on Dec 26, 2008
My Kodak EasyShare V530, won't accept a memory card, you insert a memory card, and it doesn't even acknowledge that there is a memory card inserted.
I bet the memory card that you're inserting is a brand new 4GB SDHC card (your camera can only use 2GB or less standard SD cards). There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Apr 10, 2011 | Kodak EasyShare V530 Digital Camera
I can't seem to format my C875 easyshare with a 4gb kodak memory card. Help!
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Feb 19, 2011 | Kodak EasyShare C875 Digital Camera
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
Memory card compatibility. camera won't read or
The C875 works with SD and MMC cards, which max out at 2GB. It will not work with larger SDHC cards.
May 14, 2010 | Kodak EasyShare C875 Digital Camera
Memory card compatibility. camera won't read or format PNY Optima SDHC 4GB.
I am sorry to say that the C875 is not compatible with SDHC cards. Only SD or MMC cards.
You can get SD cards up to 2GB.
This is not unusual in cameras of a few years old.
Hope this helps.
Mar 23, 2010 | Kodak EasyShare C875 Digital Camera
Memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
Sep 10, 2009 | HP Photosmart 2710 All-In-One InkJet...
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
8G SDHC memory card is locked
there should be a little swith on the side of the card. switch to the opposite and then try
Dec 25, 2008 | SanDisk 4GB Secure Digital High Capacity...
PNY SDHC 4GB memory card
Hey Teelo,
I would try reinstalling your software, or updating your drivers. You could also try getting a card reader that connects to a USB port and try transferring your images with that instead of connecting the camera directly to the computer. I also have included a link to the manufacturer where you can download the latest version of your software, and troubleshoot your issue if still needed. I hope this helps!
http://www.kodak.com/global/en/service/products/ekn035115.jhtml?pq-path=12660
Sincerely,
Allan
Go Ahead. Use Us.
Jul 02, 2008 | Cameras
Open Questions:
Panasonic Lumix DMC-FZ18K Digital Camera Logo
79 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
