Question about Sanyo Xacti DSC-J1 / VPC-J1 Digital Camera
Sanyyo xacti j1- doesn't react when shutter button pressed
Hi and Thanks!
My xacti j1 doesn't take photos when I press the button. The battery is fully charged but it shows red in the little spot next to the viewfinder.
I can still view photos on my sd card. It still speaks when I turn it on, so i don't think it's the battery even though it shows red.
The button does move down a little so i don't think it's broken inside.
Thanks you for any suggestions!
Shona, Melbourne, Australia
SOURCE: Sanyo Xacti (VPC C5E) digital movie camera NOT STARTING UP
This sounds like the same problem my daughter has with her camera (same model). Have sent it away to be repaired and have been told it needs a new MAIN PCB. The total cost is £232.65 !!! We are still looking around to see if we can get it done cheeper !
Posted on Jan 30, 2007
SOURCE: My camera stoped to work
MY DIGI CAM DID NOT WORK..
Posted on Dec 24, 2007
Steve5
  • 423 Answers
SOURCE: I cannot unlock the sd card in my Sanyo 7.1 camera.
On the card there should be a tiny sliding switch which may be set to the "lock" position. Slide away from the lock and it should be OK.
Posted on Mar 15, 2009
rossy65
  • 7 Answers
SOURCE: Sanyo camera shuts down and won't power up
Very likely your AC adaptor is broken and not providing power to the device.
I have a Sanyo VAR-G9 that failed.
Take your AC adaptor to Radio Shack, and they may be able to give you a "universal" replacement.
I am using a Radio Shack P/N 273-1696 adaptor and my Xacti HD2000 is now working again.
Posted on May 10, 2009
praky16
  • 744 Answers
SOURCE: When I press the power button the light turns
hi..
Try taking out your batteries and then taking out your memory card. Put back in batteries. Turn on camera.
If this works, just put back in your memory card and try again. Sometimes the memory card hangs and you need to pop it in and out.
thank u
rate me!!
Posted on Jul 15, 2009
Nikon j1 flash not working
Does the flash ready indicator also stay off, after you opened the flash and pressed the shutter release button half?
Because that could indicate there is not enough power in the battery to charge the flash.
If the light comes on, and still the flash does not fire, there would be a serious problem. My guess; that only can be solved at the service centre.
To be sure nothing else is wrong. Charge the battery first.
Then switch on the camera, open the flash, select fill in flash and press the shutter release button half. If the flash ready indicator lights, press the shutter complete and see if it works.
Succes
Jan 13, 2014 | Nikon 1 J1 10.1MP HD Digital Camera With...
Camera not working
Hi Jane,
When we press the shutter release the mirror flips up after the shutter opens and closes the mirror flips down. When it flips down we then see out the viewfinder.
At first blush is sounds as though the mirror flipped up but not back down. Remove the lens look inside the camera press the shutter release what happens?
Cordially,
Jul 25, 2013 | Canon EOS Rebel 2000 35mm SLR Camera
Canon t3i will not fire
Have you got the camera set for mirror lock up. Check and disable if appropriate. When mirror lock is selected the first press of the shutter button moves the mirror up the second press fires the shutter
Mar 23, 2017 | Canon EOS 600D Rebel T3i Digital Camera
Canon Powershot A495 Wont power on using the ON/OFF button
The problem is short on playback button due to humidity (see differences between the buttons on foto no.1), wich can be removed mechanically using a pin and making two holes(inlet/outlet) at the side of the button where no wiring running(!) and with a hypo carefully shooting air beetween the foils. It is useful to lift up little bit the spring button from the bottom foil to remove the short. A hair dryer can be also helpful to dry out the space between the foils. Please check the fotos and link too.
The camera will not power on by battery insertion when short is over. To protect buttons against repeted defects I used an adhesive tape to close the openings on the top of the buttons.
Canon Powershot A495 Wont power on using the ON OFF button page 2 General...9475eddd-e98e-40e1-9ff5-48f2b88aa22a.jpgimg_3172a-qpgfxpscyuxnmpq5faoemdbh-2-2.jpgimg_3180a-qpgfxpscyuxnmpq5faoemdbh-2-3.jpg
Nov 08, 2011 | Canon PowerShot A495 Digital Camera
All i want to know is if the canon a620 can be set to take a photo on its own without pressing the button to snap the photo....i want to take 'certain' photos of myself and no one to take...
No, you have to press the shutter release button to take the picture.
Press the FUNC/SET button. Use up/down to select Drive Mode (the rectangle, third item from the top). Use left/right to select the desired delay and press FUNC/SET. This sets the self-timer. Start the self-timer by pressing the shutter release button as usual.
Apr 06, 2011 | Canon PowerShot A620 Digital Camera
Well i have a Sanyo J1 Xacti Digital camera and i lost the CD with the software to download the pictures from camera to Computer. Is there any site where i can get download it? Thanks
Try Sanyo.com - look for support button.
Most newer computers with newer operating systems will detect a camera/camcorder when connected to USB. Have you tried it without the disk?
I have an older Xacti that records to SD card. You can use a flash card reader to transfer files without Sanyo software.
Jan 03, 2011 | Sanyo Xacti DSC-J1 / VPC-J1 Digital Camera
Camera powers down when pressing shutter button
I see this frequently on the E900. Every time it has been a battery issue. If you're using rechargables (the E900 came with batteries and charger in the Canadian market......not sure about the rest of the planet), they may have just worn out over time. Replace with new NI-MH (nickel metal hydride) rechargeables. If you're using throw-away AA's, try Energizer Ultimate Lithiums. I've solved many, many E900 shutting off problems simply by changing the batteries to Energizer Lithiums.
May 27, 2009 | Fuji FinePix E900 Zoom Digital Camera
No picture taken when shutter release is pressed
if you see no reation of the pressing of the button i.e. no focusing, no error message nothing , then most probably a simplest problem , the shutter release button may not be working for few reasons : 1) defective switch. 2) defective flex cable. 3) camera exposed to some physical jerk or dropping resulting into disalingment between inner switch and the shutter release button.
Jul 09, 2006 | Fuji FinePix S5500 Digital Camera
The camera takes too long to take a photo. What should I do?
Press the shutter button halfway and hold it to set the focus, then press it the rest of the way down to take a photo. If you press the shutter button down all the way at once, it takes time to focus and set the exposure before the shutter releases. It may take longer than when pressing the shutter button in two steps.
Sep 12, 2005 | Epson PhotoPC L500V Digital Camera
Sanyo Xacti DSC-J1 / VPC-J1 Digital Camera Logo
57 people viewed this question
Top Sanyo Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
