Question about RCA P52960 52" Rear Projection Television
My rca p52731wk projection television will not power on
The fuse at the supply is good, when disconnected and reconnected, a low buzzing sound is faintly heard, almost like a discharge or something. if anyone can point me to where i can get schematics or any help, i'd appreciate it greatly.
thanks.
    Scholar:
  • 137 Answers
We are available for conference Today and Everyday. Wewill assist you in repairing your set. The Part you need is Transformer 226094. Please joinin conference for part price and location
LOGIN
Circuitcity
Posted on Jan 11, 2009
I have model RCS P52731wk. No power when i puch the power button on the front. Is there an internal fuse?
THERE IS A FUSE, it is located inside where the power cord connects.
Let me ask does power light come on for just a moment at all?
SD TECH
Nov 03, 2010 | RCA P52960 52" Rear Projection Television
Hello :i have a bad projection tv Symptom :power
sounds like my 32", its going to be one of three things,
Convergence board,
if it is this you will need to order one online and install it yourself, lots of guides online to help you with this process,
High voltage power supply,
again this can be purchased online and directions are available, if it is the high voltage supply, the tv will act like it wants to come one and maybe click a couple of times
Low voltage supply,
the tv will do nothing, now if the tv does nothing, the low voltage supply isn't the only possibility, but the most likely, check fuses on this one as they are easy
Jun 25, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My T.V. won't come on.
I would guess that the HV Block has failed. A very common failure. I would hesitate trying to replace it unless you are familiar with Projection HV circuits. You did good supplying
the Model # and Chassi #. both are required to get the proper part# if you try to get the part yourself or calling a service shop to fix it.
Hope this helps,
Skyassoc
Jun 22, 2009 | RCA P52926 52" Rear Projection Television
Rca hd52w59 making a high pitch buzzing sound
is this just a whine since you describe no problem with the picture it dosent jump or change color or flicker. there may be an easy fix this sounds like some coils oscillating and i tell you what can be done you can take some silcon and put on these coils to dampen then vibrations. now ther may be other problems but without looking this is my first gues ...where are these coils? ll037 on the power supply deflection board
Jun 17, 2009 | RCA HD52W59 HDTV Projection Television
Tv has sound ,no picture,power light comes on
Tihs would be the power supply unit gone bad.
1. Check power supply fuse if the fuse is blow so are the caps do not try to replace the fuse you will smoke this thing.
2. upon inspection you can remove the power supply unit and buy a new one. There about $150 bucks aftermarket for this unit. So I would be looking for other RCA's with this same series and pull some psu's to save money.
I hope this helps you find a solution for your TV these are nice to have and worth the repair.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 21, 2009 | RCA R56WH76 Projection Television
Rca p52731wk wont power on
check for bad or broken connections around the high voltage transformer......
Feb 24, 2009 | RCA P52960 52" Rear Projection Television
Unit will not turn on.
CAREFULLY Measure the voltage on both sides of the fuse to make sure that the fuse is actually good.
No fix?
disconnect and reconnect the wires from the low voltage and control side of the power supply board.
No fix?
Throw it in the garbage.
Feb 24, 2009 | RCA DRC8320 DVD Recorder/VCR
Rca p60752eb
Sounds like the flyback, can you look on the rear tag and let me know which chassis you have and verify your model number and I will post which flyback you need as well as where to get a replacement with free tech support to help you install it.
Jul 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Replaced convergence fuse tv worked then shut down
Sounds like the convergence power supply is defective. If you need more info let me know
Apr 29, 2008 | RCA HD52W59 HDTV Projection Television
RCA D52W19 52 in. Rear
open it up and see if any liquid is spilled on the boards, most squeals are from the high voltage transformer and or splitter
Jan 17, 2008 | RCA D52W19 52" Rear Projection Television
RCA P52960 52" Rear Projection Television Logo
155 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
