Question about GE Security Simon 3 Wireless Home Security System
Sensor alarm notice on GE Simon 3 system
How can I reset sensor alarm notice to no alarm announcement?
  • banufos Jan 10, 2009
    I have the same problem. Same model, GE Simon 3 Wireless is giving me a "Sensor 2 Backdoor Alarm" announcement only when I press the status button... Does not matter if system is armed or not.
  • Anonymous Mar 16, 2014
    how do I lower the volume of the system chime
Most likely it is remembering a alarm at that station. If you enter your alarm code following the "status", it will clear it. (That's how mine works)
Posted on Jan 19, 2009
I own a security company and can help you with this, but will not have access to Simon mnuals until tomorrow. This needs to be completed through programming.
Posted on Dec 26, 2008
I have a GE Simon Security System and I recently moved a door that had a sensor on it. Now that sensor shows as 'Open' and I can't get the system to reset. Any suggestions?
You could try taking the sensor out of the system and try reseting from there. Or Virtually close the sensor. To do this point the senor sender at the sensor receiver. The reset system. If, this sensor is not being used you could tape the receiver and sender together.
Hope this helps.
Apr 14, 2011 | GE Security Simon 3 Wireless Home Security...
GE/ADT DIY system will not accept master code./beeps twice/2 hour
Press the system status button on the top right and the system should announce the error message that is keeping it from accepting the code.
Feb 17, 2010 | GE Security Simon 3 Wireless Home Security...
We had to change a battery in one of the sensors, how do we reset the sensor?
Log into your control console. Delete the sensor from the system, then add the sensor back into the system.
Oct 12, 2009 | GE Security Simon 3 Wireless Home Security...
Sensor failure Simon 3 wireless home alarm
the sensor is going out, i would switch it out with another one in your house and see if the problem follows it there.
Sep 02, 2009 | GE Security Simon 3 Wireless Home Security...
GE Simon 3 low battery warning: Newer battery has 6.54V?
Read the battery voltage with the system on but with the ac power disconnected. I always suspect the battery from experience. Battery needs to be replaced every few years normally(but can vary).
Jun 23, 2009 | GE Security Simon 3 Wireless Home Security...
GE Simon reset
In order to do this, you must have the "installer code". This is not to be confused with your master code which you use to disarm your system. Once you have this code, enter it when prompted, press delete, press sensors, when proper sensor is announced press done to accept, system announces that sensor "x" has been deleted. There is a default "installer code" (1234 or 4321) but many suppliers such as ADT change it to prevent owner tampering.
Mar 19, 2009 | GE Security Simon 3 Wireless Home Security...
Goes off even when disarmed!
This is from page 19 of the Simon3 manual found here:
http://www.safemart.com/manuals/simon3.pdf
It appears you have the "CHIME on Motion" enabled. Follow the Option 41 steps to disable it.
Option 41 - Voice Chime
The panel will verbally announce which chime sensor has been tripped if the chime
feature is on.
Add enables chime voice.
1. Open panel cover. Panel announces, Use numbered keys to enter ID.
2. Enter Access Code using the numbered keys. Panel announces, Please select from
Start Menu.
3. Press Add from the Start menu. Panel announces, Select from main menu
4. Press Option #. Panel announces, Option 1, press again for next option or done to
select.
5. Press 41. Panel announces, Option 41, press again for next option or done to
select
6. Press DONE. Panel announces, Option 41 is on.
Delete disables chime voice. The panel will not announce which chime sensor has
been tripped but will still chime 2 times for doors and 3 times for motion sensors when
a given sensor is tripped.
Start Menu.
3. Press Delete from the Start menu. Panel announces, Select from main menu
select.
delete
6. Press DONE. Panel announces, Option 41 deleted.
Dec 26, 2008 | GE Security Simon 3 Wireless Home Security...
GE Simon 3 Add or Change a Sensor to my system?
You need to use an installer code to add/remove sensors. Depending on what number of digits your alarm code is set for will determine the number for the intaller code. Look in the installer manual for the code. Then follow these steps:
Open the panel.
Key in installer coe
Select Add
Select Sensor/Remote
Activate the sensor you want to add. Some sensors have a button, some have to opened to activate.
Choose sensor name and group. Groups are listed in the manual. Basically, if you want the sensor to arm when the doors arm (such as for a window sensor or door sensor) put it in group 10 or 13. If it's a smoke sensor, group 26; motion detector, group 17 and keyfob, group 01.
Press done when finished and run the test to make sure the system is reading the sensor.
Oct 06, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
903 people viewed this question
Top GE Home Security Experts
Bill
Level 1 Expert
Steve Allison
Steve Allison
Are you a GE Home Security Expert? Answer questions, earn points and help others
