Question about Sharp CD-ES9 CD Shelf System
I have a Sharp CD-S9 shelf sysytem. Was damaged during shipment thru the US mail. Plastic face plate is broken across the top lefthand corner and down into the CD player. I believe this may be the reason why the CD drawers do not open at all. So I can not even attempt to see if th CD player itself even works. Secondly the faceplate on the bottom righthand corner is smashed into the #2 tape player and will not allow the door to function. The #1 tape palyer does work. The tuner itself does not appear to work either. Can this be fixed?
SOURCE: sharp XL-MP130 CD shelf sys. won't work...at all
Hi There,
The clicking noise is usually the power supply "tripping" because of an over load, your explanation of the fault is very good and helps us in advising you about the fault...
Because the clicking gets slower it means that you have reduced the current being drawn from the power supply.
The item that is causing the over load is the item that when you plug it in or turn it on causes the clicking to start up...
Tyhe power supply is called a switched mode power supply and is usually a collection of transistiors capacitors resistors and a transformer all specially set up to make DC Direct Current and AC alternating current power for your electronics to work with.
These power supplies are expensive and no fuses are employed to make them work but a special detector circuit is installed to close down the power when a high current draw down is detected, Once the high draw down is detected the power supply closes itself down, so then it sees no more high current draw down so it starts up again and this causes the click as the internal transformer and capacitors once again start the cycle to operate to make the DC/AC supplies. So once started up the High current is detected and the power supply closes it self down and the cycle is repeated over and over....
Its a specialised job to locate the problem so its not something you can do your self without electronics training...
Cheers From YUBEUT
Posted on Nov 24, 2007
  • 619 Answers
SOURCE: Sharp Microwave model R-1850A door won't open
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Posted on Jan 14, 2008
  • 4234 Answers
SOURCE: ER message for CD, Sharp GX-CH150
The optics assembly is having a problem. Either it can not read the disc at all or the disc is not spinning. In any case, the unit will require service. If you can reach the lens, try cleaning it using a cotton swab and alcohol. That may resolve the problem. If not, update this. Please try to see whether or not the disc spins and report that as well.
Thanks,
Dan
Posted on Apr 07, 2008
  • 4234 Answers
SOURCE: Sharp BA2100 3 CD mini component system - NO DISC
This is a relatively common problem when the optics get dirty. If you can reach the lens, try cleaning it using a cotton swab and alcohol. Don't bother with the "cleaning discs" available as all they can do is bruch off the dust. These lenses sometimes get a smoke or dirt film on them that the brushes can not celan.
Keep us posted.
Dan
Posted on Sep 17, 2008
MicrowaveSvc
  • 9149 Answers
SOURCE: Sharp R1480 door won't close
Very much so.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
The best place to order Sharp parts is Tritronics. Or you can call them at 866-779-5835.
Posted on Dec 15, 2008
I have a brand new sharp kb6524ps drawer microwave and the top face plate is loose. How can I tighten it?
Is this unit 'brand new'??
Call Sharp Electronics @ 800-BE-SHARP. If you received it this way, it may be shipping damage. Contact the seller.
Oct 09, 2013 | Sharp Microwave Ovens
My cd changer does not come out
The problem is most likely a broken rubber drive belt . Open up the unit and look for a small rubber belt broken
Apr 26, 2013 | Sharp Multi-System Mini Component System...
How do I install a waveguide in a Sharp microwave oven? The old one burned through because of corrosion beneath it. I sanded it & repainted with rust preventative paint. I don't want to break it during...
If you mean the waveguide cover, those are almost always mica or plastic.
They would normally install by sliding them into slots in the cavity or ceiling, and sometimes they are held in pl;ace with a plastic rivet, too.
If a waveguide cover is damaged, it should be replaced with a new one, not repaired in any way.
Arcing will occur, which can damage your magnetron, waveguide, and / or chassis.
If you mean the waveguide itself, which channels the microwave energy from the magnetron to the cooking cavity, that cannot be removed or replaced. They are welded in place. If the waveguide is bad, the oven has to be replaced.
We have quite a few Sharp service manuals which cover disassembly and parts lists, etc. If we have it, I can point you to a link to download it free.
Feel free to contact me directly with your model number.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 25, 2010 | Sharp Microwave Ovens
Top of tower (plastic) broken. How do I buy a new one.
It is very unlikely that you can buy another one for it. You should make an RMA.
Feb 10, 2010 | Azza Solano 1000 black/silver Japanese...
How can i take face plate off
With the unit switched off, push the open button top left of face, and pull downwards, too reinsert face put the lefthand side in first and then push righthand side to secure
Jan 29, 2010 | Dual XD-7500 CD Player
Removal of face plate on head unit
theres a spring loaded device behind face plate used to kick face out either the spring broke or became un seated
Jan 13, 2009 | Pioneer DEH-P77MP CD Player
Cd tray won't open
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Mar 01, 2008 | Sharp CD-PC3500 CD Shelf System
Sharp carolsel model r1505 on/off buttons broken
Unplug micro wave.
3 screws to remove top vent.
1-screw to remove touch panel from chassis.
tilts foward disconnect wires from board . I labeled for
reassembly .
1-screw holds the touch panel electrics to face plate.
There are 4-6 snap in plastic tabs holding it in place.
you have full access to the cheap plastic hinged buttons.
I hot glued mine once but they broke after 6 months.
I found this site:http://207.234.249.73/mwd/#brands
Good pics and you can see the buttons.
They sell a replacement button for $15 . There is also a
complete service manual for the Sharp 1505 for free download.
Did I mention to unplug the microwave before starting...
Rob H
Dec 17, 2007 | Jenn-Air JMV8208A Microwave Oven
Broken LCD on a Sharp 20SH3U TV
DO YOU STILL HAVE TV WILL YOU SELL FOR PARTS?
Aug 16, 2007 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
Sharp CD-ES9 CD Shelf System Logo
35 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
