Question about DFI PE21-EL Motherboard
Best/Fastest CPU for DFI PE21-EL mobo
Hi I currently use the DFI PE21-EL motherboard with a 400mhz FSB and am looking to upgrade the cpu. I am currently running a 1.7ghz intel celeron cpu. The website http://www.firingsquad.com/hw/268/DFI_PE21-EL/ says that the mobo supports up to a 2.4ghz Pentium 4 with the 400mhz FSB. However the website http://www.cpu-upgrade.com/mb-DFI/PE21-EL.html says that the mobo will support up to a 2.6ghz pentium 4 with the 400mhz FSB. The DFI website has no information on this mobo anymore.
My questions are these:
-What is the fastest pentium 4 cpu that I can use in my 400mhz FSB mobo?
-If it is in-fact the 2.6 cpu that is the fastest, do I need a driver or BIOS update to do this, and if so where can I find this driver or BIOS update.
-On some mobo's there is a jumper you can switch to change the FSB, does my mobo with the 400mhz fsb have the ability to be switched over to 533mhz FSB?
-Lastly, does anyone have access to the owners manual for this mobo, and if so could I get a copy of it, preferably in digital so there's no mail/shipping involved.
Thank you for your time, it is much appreciated. Please let me know if there is anymore information you need from me.
Merry Christmas and thanks again.
-Jared Hicks
  • 2 more comments
  • jchicks87 Dec 26, 2008
    Thanks for the help.
    To make my intentions short and sweet, I want to put the fastest cpu I can in the mobo, can I go any higher than the 1.9 P4 @ 400fsb?
    could I get the" 2.8 GHz
    21 x 533 MHz, Northwood
    A
    1.525V not supported" and drop it below 1.525v? or does it just not
    work that way? (the reason I ask is because I currently have that cpu,
    it just didn't work in my computer, I figured it was the FSB that was
    off)
    Thank you again.
    Its funny that you just mentioned that because I just stumbled across the same information a few minutes ago. Thanks! I'm going to order the 2.53 and see what happens. I guess I'll update you in a few days or so.
    Thanks again.
  • jchicks87 Dec 27, 2008
    Alright, well just to add a little more to the plot:
    I took a look at the 2.8ghz processor I was sent, and on it there is an identifying code that reads :SL7E2. I looked that up at CPU-World and got this page:http://www.cpu-world.com/sspec/SL/SL7E2....
    http://www.cpu-upgrade.com/mb-DFI/PE21-E... shows the compatible cpu's for my mobo, and when I click on the link for the 2.8 this is where it leads:http://www.cpu-world.com/CPUs/Pentium_4/...
    Nowhere under that page lists SL7E2
    That 2.8 I have is different from the ones listed as compatible with my mobo.
    So now that I know this, is there still a chance that the 2.8 will work if I get one with the correct code, it should it not matter either way? Or if you could just take a look at the new information given and lend me your thoughts it would be much appreciated.
    Thanks again, and please let me know if that did not make sense and I will do my best to clarify.
    Well I wish there was an edit button but there is not.
    http://www.cpu-world.com/CPUs/Pentium_4/... shows the other processors that are like the SL7E2 that I have. Turns out that I have a Prescott CPU, but my mobo needs a Northwood. So I'm guess that I've now answered my own question, and that the 2.8 Northwood should work?
    Thanks
  • 22 Answers
Your motherboard supports 2 different fsb's.
look these up @ cpu-world
you can use:
Intel Pentium 4 processor (478-pin)
- 533MHz system data bus - supports up to 2.8 GHz
- 400MHz system data bus - supports up to 2.4 GHz
Intel Celeron processor
- 400MHz system data bus - supports up to 2.0 GHz CPU speed
and here are the suppoted cpus:
Intel Celeron RK80531RC029128 BX80531P170G128 1.7 GHz 17 x 400 MHz, Willamette Any A RK80531RC033128 BX80531P180G128 1.8 GHz 18 x 400 MHz, Willamette Any A RK80531RC037128 BX80531P190G128 1.9 GHz 19 x 400 MHz, Willamette Any A RK80532RC041128 BX80532RC2000B 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported RK80532RC045128 BX80532RC2100B 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported Intel Pentium 4 RK80532PC021512 1.5 GHz 15 x 400 MHz, Northwood Any A RK80532PC025512 BX80532PC1600D 1.6 GHz 16 x 400 MHz, Northwood Any A RK80532PC029512 1.7 GHz 17 x 400 MHz, Northwood Any A RK80532PC033512 BX80532PC1800D 1.8 GHz 18 x 400 MHz, Northwood Any A RK80532PC037512 1.9 GHz 19 x 400 MHz, Northwood Any A RK80532PC041512 BX80532PC2000D 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported RK80532PC049512 BX80532PC2200D 2.2 GHz 22 x 400 MHz, Northwood A 1.525V not supported RK80532PE051512 BX80532PE2266D 2.26 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PE056512 BX80532PE2400D 2.4 GHz 18 x 533 MHz, Northwood A 1.525V not supported RK80532PC056512 BX80532PC2400D 2.4 GHz 24 x 400 MHz, Northwood A 1.525V not supported RK80532PC060512 BX80532PC2500D 2.5 GHz 25 x 400 MHz, Northwood A 1.525V not supported RK80532PE061512 BX80532PE2533D 2.53 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PC064512 BX80532PC2600D 2.6 GHz 26 x 400 MHz, Northwood A 1.525V not supported RK80532PE067512 BX80532PE2667D 2.66 GHz 20 x 533 MHz, Northwood A 1.525V not supported RK80532PE072512 BX80532PE2800D 2.8 GHz 21 x 533 MHz, Northwood A 1.525V not supported
Posted on Dec 26, 2008
  • TweakX Dec 26, 2008
    CPU: P4(SOCKET 478), SUPPORT UP TO 2.53GHZ(533MHZ) OR 2.4GHZ(400MHZ)
  • TweakX Dec 27, 2008
    here is the link to the manufacturer specs,downloads ,cpu support.
    I believe that it will support the 2.8 northwood but I can't say for certain.Myself if I were in your shoes I would go for it.
    Here is the one that I would go for
    Pentium 4 Northwood 2.8 FSB :533MHz
    Hope it helps
I have a Pentium 4 1.7Ghz 478 socket 400mhz CPU in my Ps4800d-x motherboard. I want to upgrade to a faster processor. There are 3.2Ghz & 3.4Ghz available. But is there a maximum size I can install?
Open the link provided. These are the CPU's the motherboard can run.
http://www.asus.com/product.aspx?P_ID=tElmFMz0YPEK37pl&content=specifications
P4-3.40 GHz (800 FSB, L2 cache:1MB, rev.G1) is the fastest CPU listed. The 1MB cache makes this CPU the fastest of the bunch. You may need to flash the bios in order to run this CPU. Click the Go button to the right of the CPU listed to update you're bios if bios version No# 1006.002 is not installed.
Cheers'
Mike
Mar 31, 2010 | ASUS P4S800D-X Motherboard
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
Processor motherboard compatibility
Intel® Core™ 2 Duo T8300 (2.4GHz/800Mhz FSB/3MB) it is the Cpu that your mainboard support. no more faster.
May 27, 2009 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
Upgrading laptop CPU
Yes. Your motherboard only supports cpu's with a FSB of 400mhz. If you want to upgrade you would need a compatible cpu running 400mhz FSB. Hope this helps.
Dec 24, 2008 | Toshiba Pentium M, 1.5 GHz 715...
Cpu update
basing from MSI website cpu support for this mobo,
the best AMD processor you can fit on this mobo is
ATHLONXP 3200+.
Barton (0.13u) 200/400MHz FSB 512KB L2 Cache AthlonXP 3000+ 200 Auto OK AthlonXP 3200+ 200 Auto OK
http://global.msi.com.tw/index.php?func=prodcpusupport&prod_no=592&maincat_no=1#menu
Oct 13, 2008 | Intel Motherboard
Upgrade cpu
According to the product website your board supports all intel socket 478 cpu's. Maybe you bought a faulty cpu ?
M266A
  1. Socket 478 for Intel® P4 processor
  2. VIA® P4M266A chipset
  • FSB 533MHz
  • Supports Hyper-Threading Technology
  • Hybrid Booster - a safe overclocking feature
  • 2xDDR 266/200
  • Integrated ProSavage8 3D Graphic
Socket 478, Intel® Pentium 4 / Celeron
- FSB 533/400MHz
Jun 22, 2008 | Asrock M266A Motherboard
Motherboard
2.2Ghz should be the fastest for your motherboard, also the cpus FSB is MAX 400Mhz
the socket is S478
only old cpus work in your motherboard new and currently being sold, core 2 duo family prosessors wont work. they all have fsb 667 or higher and your motherboard only supports up to 400fsb
here is the best cpu for your pc
http://cgi.ebay.com/Intel-P4-2-2-Ghz-CPU-400-512-478-Socket-Northwood-SL6PL_W0QQitemZ260222969857QQihZ016QQcategoryZ14293QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I would recommend a whole new system.
Apr 05, 2008 | Computers & Internet
Fastest CPU available for the K7N2G?
Look for socket A processors and ignore the XXXX+ and focus on the XXXXMHz rating (the MoBo's manufacturer's support site will give you the max processor your Board will handle). Since you mention that your MoBo is 4 to 5 years old, you'll probably better serve yourself to replace the MoBo and processor (you'll be able to upgrade to a much better/faster processor by upgrading both, and shouldn't cost that much more), and probably be happier with the result. You may want/need to upgrade your Power supply while you are at it too.
Mar 29, 2008 | MSI K7N2G-L Motherboard
CPU Upgrade
Athlon XP 3000+ is 400mhz FSB according to the link(http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118_1274_3734^11672,00.html), means that in order to display the actual speed of your Athlon XP 3000+ you have to set your board 166mhz to 200mhz jumper setting or in CMOS utility overclocking option. and also just to inform you that your motherboard is in Overclocked condition when set, because it only supports processors up to 333mhz FSB (http://www.digital-daily.com/motherboard/soltek-sl75frv/)
Sep 11, 2007 | Soltek SL-75FRV Motherboard
DFI PE21-EL Motherboard Logo
235 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
