Question about Fujitsu Siemens LifeBook E8020 Notebook
Clear bios power on password
Please help me sir my laptop is Fujitsu E8020 Series just laptop power on. startup screen just power on password please guide how to reset (Power on Password).
Regards,
sunil tandel
india
  • 119 Answers
The only thing you can do is to remove the cmos battery for about 60 seconds and your problem will be solved.
Dont forget to rate
Posted on Jan 07, 2009
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
Password Bios
you can restart it, and use F2..and reset bios password in that screen
Mar 23, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu siemens s7110 laptop bios password
if youve forgotten the bios password you will need to remove the main battery, the power cord and disconnect the cmos battery to clear the bios password
its better to have a tech do this for you
Dec 07, 2011 | Fujitsu Siemens LifeBook S7110 Notebook
I have a Fujitsu-Siemens Lifebook e8110 which has bios password and I can not reset it. has both the administrator password and user. user password can only view the BIOS. administrator password I need to...
User and Administartor passwords are only for your OS. Windows® for Example
To reset your BIOS password, you must disconnect your laptop-battery. Wait a few minutes, and put it back in. Now your BIOS password has been reset and you can access your BIOS again.
Jun 02, 2011 | Fujitsu LifeBook E8110 Notebook
Have forgotten bios password, to resolve want to remove bios battery, replace and boot without bios password required. where can i download service manual.................thanks
Hello gwerty99nm, go to this "Website," there are different "listings" for Manuals, choose the one you need, or "Download all of them!"
The [PDF] files do not take up 'much' space , and are very informative.
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
http://search.fujitsu.com/us/search.jsp?q=Manuals&restrict=all_us&num=10&sort=date%3AD%3AL%3Ad1&entqr=3&ie=UTF-8&btnG.x=12&btnG.y=15
Feb 14, 2011 | Fujitsu Siemens LifeBook E8020 Notebook
Bios password Fujitsu Siemens LIFEBOOK E8020
Hi
i found this on ebay it may help you
httpcgi.ebay.co.ukBIOS-PASSWORD-RECOVERY-RESET-REMOVAL-PC-LAPTOP-200567780325pt=Laptops_Nov05&hash=item2eb2c573e5
If the link dont work
copy and paste it into your browser it should take you there
good luck
Jan 23, 2011 | Fujitsu Siemens LifeBook E8020 Notebook
I want to reset fujitsu siemens lifebook E8020 bios password
i want fujitsu siemans lifebook bios paasword
plssss............
Aug 11, 2010 | Fujitsu Siemens LifeBook E8020 Notebook
Not booting Properly.
have try to reset bios if not u have to reset bios.
Pullcmos cell for 15 seconds from mohter bord also u can reset bios with jumper settigns it is near cmos read carefully on motherbord u can find jumper u can see "clear cmos " on motherbord
May 06, 2009 | Fujitsu Siemens LifeBook E8020 Notebook
BIOS Password - UNKNOWN
Remove the battery. That will clear the cmos known as the bios. Check the manual there may also be a jumper that can also clear the bios. Remove the battery & unplug the power before doing this.
please vote...
Feb 05, 2008 | Fujitsu LifeBook S4510 Notebook
Fujitsu Siemens LifeBook E8020 Notebook Logo
945 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
