Question about Dell Inspiron 2200 Notebook
Wireless signal is very weak
Problem started when i got my note book back from the repair shop that istall a biger hard drive and more memory
  • 39 Answers
Signal strength is varies depend on your position,
Hardware type, wireless provider line-of-sight (how
many obstacles that blocking the signal), and other
factors.
Make sure you connect to the same wireless spot.
Or at least go to places with wireless spots and compare
signal strength.
If you never have a strong signal from at least 5 different spots
(make sure you check it's the top 5 best spots you find,
ask others who connect to the spot also to make sure)
then you go to your repair shop and ask them why.
But, if you at least have 1 strong signal then
your spot just having a weak transmission.
Posted on Dec 26, 2008
My xbox 360 is now showing flashing 1 red light on and off
These steps are taken from the support site as always, it's the first website where you should look.
Solution 1: Disconnect and reconnect cables
Here's how:
  1. Turn off your Xbox 360 console.
  2. Unplug all memory units, controllers, and accessories from your console.
  3. Unplug everything from the back of your console, including power and video cables.
    Don't remove the hard drive.
  1. Reconnect your console's power supply.
  2. Reconnect each accessory one at a time, starting with a controller.
  3. After you've reconnected every accessory, turn the console on.
Solution 2: Remove the hard drive
To see whether the problem involves the original Xbox 360 Hard Drive, temporarily remove the hard disk drive. Here's how.
Note Not all Xbox 360 consoles include a hard drive. If your Xbox 360 console doesn't have a hard drive, to go Solution 3.
  1. Turn off the console.
  2. Locate the hard drive on the top of the console (or on the left side, depending on how the console is oriented).
  • Press the release button on the hard drive.
  • Lift the hard drive away from the console.
hdseparating.jpg If these steps resolve the issue, reattach the hard drive to verify that the error occurs only when your Xbox 360 Hard Drive is connected.
Solution 3: Disconnect memory units or USB flash drives
Here's how:
  2. Unplug any memory units or USB flash drives attached to your console.
  3. Turn on the console.
If these steps resolve the problem, reattach the memory unit or USB flash drive to make sure the error occurs only when it's connected. If this is true, order a replacement memory unit or use another USB flash drive.
Solution 4: Request a repair
If the previous steps don't resolve the single flashing red light issue, there are no additional troubleshooting steps. Your original Xbox 360 console must be repaired at our service center. Start the repair process online.
Jan 09, 2015 | Microsoft Xbox 360 Console
Tip
How to turn on the wireless switch on your Dell notebook computer The first...
The first thing you need to do is locate your wireless switch. It is normally located on the left hand side of your notebook computer.
Next examine the switch to make sure that it is in the middle in the On Position. See the picture below. Note a common issue that will happen is when taking your notebook in and out of your bag that the switch with get knocked into the Off Position.
dc3cc28.pngIn regards to the Momentary Position this for the Wi-Fi Catcher. If you have you already have wireless networks configured and you are in range of the networks the computer will automatically connect to the network. Note this has to be setup through the Dell QuickSet utilities for Wi-Fi network connections.
Below listed are the different color indicators for the Wireless Activity Indicator
Flashing green - The system is searching for a signal.
Green - The system has detected a wireless signal and has good strength.
Yellow - The system has detected a wireless signal, but it is moderate to weak in strength.
Red - The system failed to detect a wireless signal, or the wireless signal is extremely weak.
on Sep 23, 2010 | Computers & Internet
Weak signal strenght
some usb adaptor comes damaged...u may need to show it to electronics repair shop
Nov 03, 2012 | NetGear WNA1000 Wireless-N USB Adapter...
My computer froze so I turned it off and when i went to turn it back on, it says no bootable disk insert boot disk and press any key. Ive tried everything but it wont start up. And there is no disk that...
Sounds like your hard drive is going bad. Best thing to do is to take it to a shop and ask them to check your hard drive. Or, if at all possible plug it into another PC externally with a external HDD kit and check it with programs such as crystal disk info.
Best of luck
May 23, 2011 | Gateway M-7315U Notebook
My book was working normal, I had only had it for 6 months
A first step might be to consult a reliable local computer repair shop (or a knowledgeable friend) and ask them to check it and - if necessary - to remove the hard drive from the case and test it separately.
If this reveals that actually the hard drive itself is damaged and if really your career depends on it, then it may be worth considering to send it to a professional data recovery service.
However, be warned that these services are very (incredibly) expensive!
Mar 19, 2010 | Western Digital My Book Essential Edition...
Laptop not connecting to wireless network
Don't wait tell you laptop is defective, at least buy a new wireless lan before its too late.
Sep 30, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
My USB WD Book 500Gb is not recognized by my computer.
it is possible that the drive is not formatted yet.
try to right click "My Computer" > Manage > and click Disk Management
look for your HDD and format it.
*note that by formatting it will erase all data stored on your hard drive
Jun 11, 2009 | Western Digital 500GB My Book World...
IS THIS A GOOD LAPTOP FOR GAMEING?
no not enough memory for a gamers computer alone for memory you would want something with at least 8 GB and hard drive space would be 1 Tb
Mar 13, 2009 | Computers & Internet
Hard drive
jamesroland1,
You have a computer with a 40GB hard drive and you want to add another hard drive (150GB), is that correct? Not knowing the rest of your system age, setup and configuration makes it hard to know what you may encounter. If you can add more memory (RAM) it is always helpful to make applications work faster and multiple ones as well. You may want to add an external hard drive if you don't have the room or don't feel comfortable with opening the computer and installing an internal hard drive. If you want to replace the lower capacity drive, you need to reinstall the operating system on the drive and start from scratch.
randy320sgi
Jan 18, 2009 | Western Digital (WD1500ADFD) 150 GB Hard...
Out of signal
Signal problem could be down a many reasons,
maybe weak signal area, or even a damaged hardware antena, but also can be a software problem too, so yes would be worth a try to reformat the phone. Note that all data stored on the phone will be lost unless backed up on to PC or microsd card.
You can hard reset the phone (Factory Settings - Reinstall)
Switch the phone "OFF"
Hold "3" (button) + "Green Call" (button) + "*" (star button)
Switch the phone "ON" while holding the above three buttons.
Continue holding for about 20 seconds then let go.
Please note this will format all the saved information stored in phone memory.
Jul 03, 2008 | Nokia 6630 Handheld
Dell Inspiron 2200 Notebook Logo
150 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
